It is currently Fri Feb 23, 2018 10:00 am
PostPosted: Sat May 02, 2015 6:09 pm
Im almost about to guess that the passenger axle is the same between a manual and a automatic. Where the driver axle is different between the two, am I right? Im thinking that only becuase of the passenger axle shaft.
Vogtland lowering coils
Ngk plugs
8mm silicon wires.
PostPosted: Sat May 02, 2015 7:42 pm
AFAI both the gearbox side and engine side driveshafts from the automatic are slightly shorter than the manual versions.
PostPosted: Sun May 03, 2015 4:33 am
Sweet. Thanks for the info. I eventually need to have a full parts number catalogue printed.
Ngk plugs
8mm silicon wires.
PostPosted: Sun May 03, 2015 6:36 pm
and the shafts are fatter. :wink:
PostPosted: Sun May 03, 2015 6:58 pm
So true!
PostPosted: Thu May 07, 2015 4:29 am
pacapo wrote:
So true!
Good picture man. Thanks. I am getting new axles and wheel bearings. I have never seen an automatic swift in person yet.
Ngk plugs
8mm silicon wires.
PostPosted: Thu May 07, 2015 8:55 am
BikeAmusPrime wrote:
pacapo wrote:
So true!
Update your profile and many things will be revealed...
