It is currently Thu Jan 18, 2018 10:13 pm
PostPosted: Mon Aug 17, 2015 3:05 am
i have 99 pontiac firefly 1.3L 3 speed automatic and i changed dif bearings now i ran into the issue where my reverse is soo slow at backup when gas in applied and also wont shift above 40kmh i checked solenoids they test 100% good so im stuck on what else it could be fluid levels are full no burnt smell
PostPosted: Mon Aug 17, 2015 10:41 am
Sounds like it is low on transmission fluid.
Did you check it warm, idling?
PostPosted: Mon Aug 17, 2015 3:20 pm
no its not my fluid my fluid level is just a tad above hot which is perfect
PostPosted: Mon Aug 17, 2015 9:12 pm
:drunk:
PostPosted: Tue Aug 18, 2015 12:52 am
if anyone has a idea that would be awesome i miss driving my car
PostPosted: Wed Aug 19, 2015 9:18 am
Listen to those who know. Replace transmission, alternately get a trans shop to go through it and repair what's wrong. Did you tear the whole trans down and clean the valve body etc?
I believe it's been almost a year since you had the initial problem and I advised a used trans. The auto trans is just tricky enough that it's usually not worth dealing with vs sticking a used one in and driving away. Also the failure rate is much lower on the autos than manuals, so odds of getting a bad used one are pretty slim. I know you told me to basically f-off last time, but figured you might understand my initial advise better now. I have been down the repair road before and came up short, so I'm speaking from experience here.
PostPosted: Wed Aug 19, 2015 2:12 pm
only thing i did too the transmission was change the dif bearings didn't touch any clutchs or valve body or anything after checking the solenoids tho by giving them 12vand hearing them click good its 100% sure its valve body sticky valve or passage in there i'll have to take it out and find out look after then over n see
PostPosted: Wed Aug 19, 2015 3:08 pm
Bearing material and filings will be throughout the trans. This is why it needs to be completely disassembled and cleaned in order to work reliably again. A manual trans is much more forgiving as far as dealing with a bit of leftover gunk after a bearing failure than an auto trans is due to all the passages and precision valves etc.
PostPosted: Wed Aug 19, 2015 5:14 pm
i took the dif right out of the tranmission and worked on it then put it back together i did brush off silcone when i did the pump seal and tryed to get it out of the tranmission before i put it together maybe some small pieces of it got stuck in valves or something
