http://www.teamswift.net/
Will an '89 5 spd bolt up to a '00 g10?
http://www.teamswift.net/viewtopic.php?f=9&t=61136
Page 1 of 1
Author:  RicedOutMetro [ Sun Dec 27, 2015 11:02 am ]
Post subject:  Will an '89 5 spd bolt up to a '00 g10?
I know someone with an '89 or '91 5 spd connected to a g10, which came from a Pontiac firefly. I am just curious if I can take the transmission and put it into my 2000 chevy metro, which already has a 5 spd.
Author:  codyb76 [ Sun Dec 27, 2015 12:04 pm ]
Post subject:  Re: Will an '89 5 spd bolt up to a '00 g10?
It will bolt up.
That trans will likely be 4:10 ratio and the '00 will be 4:39. If you aren't picky, it won't matter to much but you should make sure to use the speedo gear for the older trans in order to make speedo read properly. It will have slightly less rpm on highway and pickup with the 4:10 ratio
Author:  RicedOutMetro [ Thu Jan 14, 2016 3:12 pm ]
Thank-you, I'm looking forward to getting it swapped out this spring.
http://www.phpbb.com/
