It is currently Wed Jan 24, 2018 5:01 am
PostPosted: Fri Nov 11, 2016 8:12 pm
i am looking for this gearbox..
picture is from swift gti fia homologation..
i know it's bad quality but it's all i have..
it looks like it have hydraulic clutch, those 3 bolts with springs and balls for selector forks look like form large frame one, also there is plate to adjust shims over tappered roller bearing on diff..
so i guess it's large frame version of suzuki 5 speed manual gearbox.. but i cant find one with part of diff housing bolted from side??
PostPosted: Tue Jan 03, 2017 10:46 am
hi. this looks like a 1,6 gearbox - mine 1,6 AWD has a bolted seal on the driver side. 1,3l gearboxes don't have this. also 1,6 have hydraulic clutch.
Suzuki Swift 4door AWD GTi with GT2554 controlled by IMF Soft Master Standalone ECU
PostPosted: Fri Jan 19, 2018 2:00 am
A cleaner picture can be found here, http://historicdb.fia.com/car/suzuki-swift-1300-aa34s
89 Swift GTi, Big Cams, Adj. Cam Gears, Gsxr 1100 Carbs, 100whp
