It is currently Thu Jan 18, 2018 7:09 am
PostPosted: Wed Mar 29, 2017 9:24 pm
I have a 91' Metro that im transplanting the G13B DOHC in to. I have several questions will 1994 Swift GA transmission directly fit up to the G13B engine, Are the output shafts on the GA the same diameter as the GTI out put shafts . Also does the GA transmission have the same rear transmission mount as the GTi Transmission witch is not on the metro transmission?
The other reason im asking is because i want to swap out the metro front hubs and brakes to the GTI hubs and brakes.
Any guidance would be greatly appreciated
PostPosted: Wed Mar 29, 2017 10:02 pm
Will bolt up. Worst possible choice for a dohc swap due to final ratios
