It is currently Thu Oct 19, 2017 7:52 am
Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Sep 18, 2008 6:09 pm
a.k.a Bum head
turbohull wrote:
not in my case, simply because they don't break loose, hey it's a 3 banger, it's probably making +- 120hp not more.
In your case it's all about the redistribution of stress. Something will break eventually... there's nothing you can do short of building something custom. These transmissions weren't made for the abuse we give them.
PostPosted: Thu Sep 18, 2008 10:12 pm
i have raced several years on the same transmission...after 275,000 street kms. tore it down and it looked beautiful inside. synchromesh and rev-matching took care of it...
the KUZUKI
PostPosted: Fri Oct 10, 2008 9:20 am
the tranny i got now is all to specs, i replaced the shims to adjust the preload, adjusted the differential height in the case, etc.
i removed the spring pin in the diff and replaced it with a solid pin. So far it's holding the abuse of 23 psi of boost. I use what suzuki recommends, straight 75W90 GL4 gear oil.
Suzuki Gold Master Tech
PostPosted: Wed Mar 18, 2009 5:57 pm
This carnage was caused by an improperly staked 5th gear (driven) nut:
5th gear driven (on right) shows significant shredding.
Here, you can see it more clearly.The damage also included some missing/broken teeth on 5th gear (drive) on the left.
Once the case was split, the effects of trying to 'nurse' this tranny became more apparent:
The pinion gear has lost a bit of metal.
Here's another view:
It's a black box MK2/3 tranny with a 72/19 ring(crownwheel)/pinion final drive (3.79) single pin (not a GT/GTi tranny) which I pulled out of an 89 GTi.
If the 5th gear nut isn't tight and 'staked' properly, it can work loose. 5th gear can wander on the shaft, with the resultant shredding. The broken teeth eventually found their way into the final drive gear set, and ruined those.
The other gears seem fine. The case was scored, but is reuseable.
Solution? Assemble the boxes clean. Oil residue can work against you, allowing the 'fasteners' to loosen.
PostPosted: Sun Apr 05, 2009 11:08 pm
I wish I had pics of the carnage but I had a mazda v-6 that I managed to shift into 2nd and 4th at the same time and as you can imagine that doesn't bode well as 4th was instantly destroyed into many little pieces that rattled around in the tranny for the next month as I drove the car without third and forth because the shift fork was stuck in forth and so I could get it into third.
http://vids.myspace.com/index.cfm?fusea ... d=38221906
I would drive this Honda (engine) or put a GTi motor in it
PostPosted: Tue Jun 09, 2009 7:21 pm
Tranny on my car is/was making some bad noises, so I dropped out the old fluid.
What would this be from?
My cars:
PostPosted: Tue Jun 09, 2009 11:42 pm
That's the "cage" that holds the balls in one of the bearings.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Wed Jun 10, 2009 1:20 am
Ooooo, you get a cookie, for getting the right answer! 8)
Now to find out where the balls went... It's from an output bearing as it only moans and groans when the vehicle is in motion.
Edit: Looking over the reciepts, the previous owner spent $1000 to get an overhaul kit put in, and 2000km later he had to replace 1st to 4th gear and 1st gear to 5th gear syncros. They made him pay for used parts, but the labour was free, so it was their screw up... Gotta love the "labour warranties" these honest business folk around here use. :roll:
My cars:
PostPosted: Fri Jun 19, 2009 9:54 pm
The end result of a 1000cc Transmission being fitted to a GTi DOHC, lol
I actually had a GTi Diff, and when I sat them down next to each other, the size difference in the spider gears was VERY apparent!
1994 Suzuki Swift GTi
PostPosted: Fri Aug 28, 2009 2:44 am
You mean that a 3 cyl sprint/Geo tranny will bolt up to the 4 cyl motor???? I didn't even think that you could switch the Sprint and the Geo trannys. Will the GTi tranny fit on a 3 cyl?
PostPosted: Fri Aug 28, 2009 6:53 pm
yes, it would also make an improvement
PostPosted: Fri Aug 28, 2009 7:34 pm
A few months ago I had to rebuild a gearbox that was fitted to a GTi, and it turned out to be the 1.0L version gearbox, I noticed a few differences with the 3 (1.3L GTi, 1.3L non GTi & 1.0L) gearsets (besides the ratio differences of course). I've posted pics of the 1.3L GTi, 1.3L non-GTi & 1.0L diffs below, I've also noticed that the 4.38:1 final drive pinion to be shorter in length than the 1.3L (non-GTi) & 1.3L GTi. look at the pictures below to see the obvious differences I've noticed;
The GTi Diff.
another view
And the 1.3L non-GTi Diff. (notice the different color diff pin, and how much smaller the spider gears are in this example)
another view
And the 1.0L Diff.
Another view
Above is the 1.0L (4.38:1 pinion) and below is the GTi (4.1:1 Pinion)
PostPosted: Sun Aug 30, 2009 9:24 pm
Ahh, I see a Mini in the background! Do you have a 1.0 in it? I am doing the same, as soon as I find a pick-up. Hope to get 70 MPG eventually(US)
Cheers.
PostPosted: Mon Aug 31, 2009 7:19 am
Cheers.
actually that's a mk. 2 Cooper S Longman stage 4 1332cc engine. not too much economy in that, lol.
PostPosted: Mon Aug 31, 2009 4:44 pm
just finished a non-economy Mini myself; Honda B16 vtec swap. Time for a MPG car now.
PostPosted: Wed Aug 03, 2011 5:54 pm
what happens @ 25 psi of boost
this was a cultus fwd gearset!!! :oops:
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Thu Aug 04, 2011 9:51 am
fordem wrote:
Now - I could be wrong - but the GT/GTi differentials are bigger & stronger than the "non GT/GTi" diffs, but I think the output or countershaft gears - the other gear that you destroyed - are pretty much the same material & strength.
I know this post is old, I just wanted to emphasize the pics posted above and how the material looks to be cut wider... the gears themselves on the countershaft are stronger, unless that is ONLY the 4.39 which seems strange. how much money could that really have saved them??? this thread makes me sad to know my fwd pulsar transmission running on my meth'd out, bolt on ca18det is gonna look like in another month or so :(
the lolcar family
PostPosted: Thu Nov 24, 2011 12:15 am
My Gti tranny dead
PostPosted: Wed Jan 25, 2012 1:51 am
last swift trans to ever be in my car ever.
image_id: 21221
this is the diff pin i didnt toutch it other than pull the whole diff out.
image_id: 21219
greeted by this when i seperated it from the motor.
image_id: 21218
the carnage
image_id: 21220
1990 swift GL Twincam swap
PostPosted: Wed Jan 25, 2012 2:16 pm
how much more powerful is your engine from stock ?
PostPosted: Wed Jan 25, 2012 10:30 pm
cant be much. i have a full 2in exhaust, ram air intake and a serious p&p. the motor pulls harder than a buddys camed 1.5 civic. 7300 rev limiter when stationary. 7600 when moving.
PostPosted: Sat Mar 31, 2012 8:50 pm
Finally got to see how effed it is. VOILA!
Nick Manning
2006 Scion xB (fun-mobile)
PostPosted: Sat Mar 31, 2012 10:30 pm
three words. WEAK ASS DIFF. on the plus side you might be able to make a spare if the rest of the internals are oK. A new diff and case and you have a spare.
PostPosted: Wed May 28, 2014 4:47 pm
Not much carnage, but I'll say this didn't work to well above 2nd gear...
PostPosted: Thu May 29, 2014 12:39 am
Yep looks familar :lol: mine lasted 3 laps before the pre existing stress fracture between 2nd and 3rd gave way.
