It is currently Mon Nov 20, 2017 6:50 pm
PostPosted: Mon May 16, 2005 7:33 am
This is the entire manual transmission section from the Suzuki Swift factory service manual. I fed the library photocopier about $10 in change to get all 41 pages of it. This will help complete the existing electronic version of the manual, which is entirely missing the transmission section.
7A-01 Manual Transmission (Table of Contents)
click for full image
7A-02 General Description
7A-03 Gear Train Exploded Diagram
7A-04 Gear Shift Mechanism
7A-05 5th & Reverse Shift Cam
7A-06 Diagnosis
7A-07 On-Vehicle Service - Oil Change
7A-08 Differential Side Oil Seal
7A-09 Differential Side Oil Seal con't
7A-10 Gear Shift Control
7A-11 Gear Shift Control con't
7A-12 Speedometer Driven Gear
7A-13 Speedometer Driven Gear con't
7A-14 Unit Repair Overhaul - Dismounting of Transmission
7A-15 Remounting
7A-16 Disassembling Unit
7A-17 Gear Shifter, Main Shaft and Counter Shaft
7A-18 Gear Shifter, Main Shaft and Counter Shaft con't
7A-19 Right Case
7A-20 Sub Assembly Service - Right Case
7A-21 Left Case
7A-22 Input Shaft Assembly
7A-23 Input Shaft Assembly con't
7A-24 Input Shaft Assembly con't
7A-25 Countershaft Assembly
7A-26 Countershaft Assembly con't
7A-27 Countershaft Assembly con't
7A-28 Gear Shifter
7A-29 5th & Reverse Gear Shifter
7A-30 Differential Assembly
7A-31 Differential Assembly con't
7A-32 Assembling Unit - Differential to Left Case
7A-33 Differential to Left Case con't
7A-34 Fifth Gears
7A-35 Fifth Gears con't
7A-36 Gear Shift & Shaft Assembly
7A-37 Gear Shift & Shaft Assembly con't
7A-38 Recommended Torque Specifications
7A-39 Required Service Materials
7A-40 Special Tools
7A-41 Special Tools con't
PostPosted: Tue May 17, 2005 12:21 am
Lihtan you are a legend, I'm about to strip a MK2 box, Karma for you! :worship:
PostPosted: Mon Oct 31, 2005 5:13 pm
El Pimpo del Geo
hey this is great is this for the 1.3 or the 3 cylinder? i would like to know cuz im doing a clutch job soon thanks alot-rob
PostPosted: Mon Oct 31, 2005 6:38 pm
They're essentially the same, there are some differences in part numbers where the gear ratios are different, but the assembly/disassembly doesn't change.
PostPosted: Thu Nov 10, 2005 3:06 am
This was scanned from the GTi factory service manual.
PostPosted: Wed Aug 02, 2006 4:15 pm
TRYING TO REBUILD TRANNY AFTER ANOTHER TOOK APART.. NEED DIAGRAM.[/b]
PostPosted: Thu Aug 03, 2006 6:08 am
Well the entire manual is right here in this thread, don't know what else you need. Please turn off your caps lock.
PostPosted: Thu Jun 12, 2008 1:32 am
I have a tip for making it easier to get the nut off the counter-shaft (step 6 on page 17) without the special tool to keep the counter-shaft from spinning.
Go ahead and do steps 1 through 7 under "Gear shift, main shaft and counter shaft" to remove the shift selector first. Then you can reach into the case and move all three shift shafts up or down, locking up the gearbox. That way, the counter-shaft can't turn when you try to turn the nut.
PostPosted: Wed Mar 31, 2010 2:26 am
How ya like me now?
http://www.flickr.com/photos/drimportracing/sets/72157623615093823/
For slideshow:
http://www.flickr.com/photos/drimportracing/sets/72157623615093823/show/
Click on "Show info" and pause as needed.
It took longer to photo, organize, write and post than it did to do the swap.
All mechanical expertise goes to Louis Tucker. Enjoy!!! :mrgreen: - Dale
PostPosted: Wed Mar 31, 2010 10:32 pm
Thanks for all the excellent tutorial type pictures.
I realize it's a lot more work to make meaningful pics,
but it sure helps owners figure what & how to do it.
'89 -made in Japan
PostPosted: Thu Apr 01, 2010 1:51 am
drimportracing wrote:
How ya like me now?
Thanks to you and Louis for your great work.
If you could fix the info on the second picture; it kinda threw me for a loop. :oops: :oops: :oops:
For a minute there, it looked like you were putting in a 3.36 gear set. And for our cars, that would be a first.
A little help? Here ya go:
http://geometroforum.com/topic/3016184/3/#post247132
PostPosted: Tue Apr 06, 2010 6:45 pm
Phil N Ed,
Thanks for the correction. Louis caught it too. Totally my fault. I'm dangerous with a keyboard!
Great link on the geometroforum too! - Dale
PostPosted: Mon Aug 15, 2011 12:46 pm
Hey all ... I came in here looking for the 5-speed manual transmssion oil capacity for my CAMI-produced '95 Pontiac Firefly (3 cyl. 1.0 litre) ... excellent resource Lihtan! Thanks for all the work you put into copying the 7A section of the manual.
Wikipedia says I have a '1995–1997 Pontiac Firefly 3dr hatchback, Gen III'
in one place (photo) http://upload.wikimedia.org/wikipedia/commons/thumb/c/c4/%2795-%2797_Pontiac_Firefly_Hatch.JPG/120px-%2795-%2797_Pontiac_Firefly_Hatch.JPG and a 'Mk4 - 95-97 (Guppy mouth) Corresponds to Generation III' in another: http://en.wikipedia.org/wiki/Suzuki_Cultus#North_America, however, I'm reasonably confident the transmission is identical to the MK2/MK3's, therefore 2.4 litres of GL-4 or GL-5 should suffice. I got most of 2 US qts of Red Line MTL SAE 70W-80 GL-4 into it yesterday, so it probably still needs a little better than 1/2 a litre more - meaning L*rdc* gets another $21.82 out of me for another bottle of MTL.
Any comments on the use of the Red Line MTL? Or the viscosity range L*rdc* supplied?
I'm trying to address slightly cranky synchro operation into 2nd and am hoping this MTL will help.
My old oil was fairly metallic-y-looking with a couple of little metal chips and there was a nice gob of metal sludge on the magnetic drain plug. But for 256,500 kms total mileage, I suppose I shouldn't complain too much.
PostPosted: Sun Sep 11, 2011 4:01 pm
i made a pdf from all the big images. however something would not let me upload it to the post, so if someone can do that for me ? easy to print the whole thing and view it now. 8)
http://www.megaupload.com/?d=6KO6K4TU
PostPosted: Fri Nov 11, 2011 9:58 pm
Thank you so much TheSilverBullet for this manual transmission pdf file. This will be of very big help for my second- hand Suzuki Swift. :wink:
Norman Summerville
:::NEXT PROJECT::: Suzuki Engine Parts Mods
:::NEXT BUY::: Suzuki Parts, Suzuki Accessories
PostPosted: Sat Nov 12, 2011 12:43 am
heh, good thing i did that as the last server move killed 50% of all old images.
PostPosted: Sun Feb 19, 2012 4:37 am
Whoa. Spoke too soon. I don't think anyone predicted Megaupload's demise. Anyhow. I would love a copy of the PDF that was here. I have been searching everywhere for one.
The first person that posts it becomes my hero.
…Thanks in advance hero. :buzz:
PostPosted: Sun Feb 19, 2012 2:28 pm
LayCraft ... I tried uploading the file to this thread in the forum here, however, I think it is too large (8.52MB). PM me an e-mail and I'll get it to you via YouSendIt or ?
FFF
PostPosted: Sun Feb 19, 2012 5:00 pm
FFF
why not just upload it somewhere else and then just post the share link here :huh: :huh: :huh: :?: :?: :?:
I don't have the original file anymore.
PostPosted: Sun Feb 19, 2012 5:07 pm
Don't worry. I'll post a link on the forum as soon as he sends me the file because I can host files. I will definitely share. :D
I just need the file now.
PostPosted: Sun Feb 19, 2012 6:30 pm
TheSilverBullet ... what upload site compares to Megaupload these days (for free & easy large file sharing)? emoticons x 3? ... don't worry, be happy mon ...
LayCraft ... check ur e-mail ... the YouSendIt link is:
http://www.yousendit.com/download/M3Bsc ... YlA0WjlVag
and expires 26FEB12 ...
FFF
PostPosted: Sun Feb 19, 2012 10:11 pm
Alright, so I'm going to leave them on my hosting for now until I can find somewhere else to put them. My hosting has been the same for years so it should stay there for a long time.
Here is the one I got from Frankenstein.
http://laycraftdesign.com/PDF/manual_transmission.pdf
Here is the one that I cleaned up and indexed. You can search this one easily.
http://laycraftdesign.com/PDF/manual_transmission%20index.pdf
PostPosted: Mon Feb 20, 2012 2:04 am
actually converting the orig. jpgs to pdf file was a bit of a chore, I had to use change it to black/white and use a few irfanview extensions and etc so it could be printable.
PostPosted: Mon Feb 20, 2012 2:22 am
Hey, I'm not complaining. :mrgreen: Your efforts are valiant. I did see your program that you used in the metadata. I just figured people may find it handy to do the control-F thing. Pssh, who likes to read things when a computer can do the reading for you? (Illiteracy once again rears it's ugly head.)
I just pulled it into Acrobat Pro, did OCR, background cleanup, and page straightening. It's all built in and automagical if you know where to look. I only know this stuff exists because I do stuff like this for a living. I didn't do any work really it was all my computer. I swear.
PostPosted: Fri Nov 09, 2012 2:30 pm
Hi, I am trying to download the sections of the transmission manual but I am getting an error code instead.
What am I doing wrong? Any sugestions?
Thanks in advance Herb
