It is currently Wed Feb 21, 2018 11:53 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
PostPosted: Sat Nov 29, 2003 3:06 am
Update Nov 2006
This thread is a relic from the early days when Teamswift exclusively catered to Swift GTis. Issues with file hosting have now been resolved. I will be preserving the information in this thread due to massive linking this thread has received over the years. Information for non-GTi vehicles can be found in their own specific forum sections. Any future information will also be added to those sections as well.
Update Apr 22 2007
This thread has now been moved to the GTi section. To keep this from getting clutter, I've also separted all extra comments that were once in here into a separate support thread. If you're having problems with the files here or have other comments or concerns please direct it to the following thread:
http://www.teamswift.net/viewtopic.php?t=31759
Update Apr 29 2007
I just ran across some wiring diagrams that were originally on the GTicouple website, but were never hosted here because they were too large to uploaded as attachments. There here now that we have proper FTP server for larger files.
Update Sept 18 2013
A number of images in this thread had broken links, and in some cases the files were missing completely since the last server migration. Links have all been fixed, and replacement images have been uploaded to replace the lost files. If any links are dead in the future, please PM me so I can fix it.
Swift GTi PDF files originally from the long-dead GTicouple website:
Full vehicle wiring diagram, 1989 M/T (TIFF):
http://www.teamswift.net/Lihtan/gti/89-GTI-Wiring-Diagram-G4.tif
Full vehicle wiring diagram, 1990 M/T Canadian market (PDF):
http://www.teamswift.net/Lihtan/gti/90-GT-MT-schematic.pdf
Full vehicle wiring diagram, 1991 A/T Canadian market (PDF):
http://www.teamswift.net/Lihtan/gti/91GTAutomaticCDN.pdf
Canadian Daytime Running Light (DRL) system:
http://www.teamswift.net/Lihtan/gti/DRL.pdf
ECU circuit inspection (includes pinout, and correct voltage levels):
http://www.teamswift.net/Lihtan/gti/ECM-Coupler.pdf
Ignition circuit diagram:
http://www.teamswift.net/Lihtan/gti/Ignition.pdf
Fusebox circuit diagram (also includes fuse position legend):
http://www.teamswift.net/Lihtan/gti/junction-fuse-block.pdf
Idle Speed Control (ISC) solenoid check:
http://www.teamswift.net/Lihtan/gti/Solenoid-Valve.pdf
Location of timing marks:
http://www.teamswift.net/Lihtan/gti/timing01.pdf
Allowable range of camshaft movement with timing belt removed:
http://www.teamswift.net/Lihtan/gti/timing02.pdf
Throttle Position Sensor (TPS) check and adjustment:
http://www.teamswift.net/Lihtan/gti/tpsadjustment.pdf*
Warning buzzer operation and circuit diagram:
http://www.teamswift.net/Lihtan/gti/warning-buzzer.pdf**
*In the original factory service manual, the resistance between pins C - B is stated as being 0 - 500 Ω (ohms). This was later revised in TSB # TS4-1606082 to 0 - 2000 Ω (ohms)
** This data has textual errors corrected in a later Suzuki TSB (not currently online)
EDIT Mar 07: fixed links, oops.
 Post subject: part 3
PostPosted: Sat Nov 29, 2003 3:11 am
Update Nov 2006:
These links are now duplicates of ones at the top of the thread. When these were first uploaded as attachments, there was a limit to four attachments per post, resulting in multiple posts. Due to this post being previously linked to, I've ensured it still links to the same information it originally contained.
Idle speed control (ISC) solenoid valve diagnostic:
Timing belt position, index mark locations:
Turning range for crankshaft, camshafts:
Adjusting throttle position (TPS) sensor:*
* Regarding TPS adjustments, according to Suzuki TSB # TS4-1606082
TPS impedance should read 0 - 2 K Ω (ohms) during idle.
Link to this post:
http://www.teamswift.net/viewtopic.php?p=41602#41602
PostPosted: Sat Nov 29, 2003 3:13 am
That's all of them. Enjoy! :D
I plan to add comments soon to the files as well.
PostPosted: Sat Dec 11, 2004 3:02 am
How to adjust your base timing (and test your ignition ignitor):
image_id: 2864
click for full image
How to adjust the duty cycle on the IAC:
image_id: 23355
page 1 click for full image
image_id: 23356
EDIT Sept 2013 fixed image links, and uploaded new images to replace missing files
PostPosted: Wed Mar 09, 2005 10:09 am
I just ran into a stash of various servicing procedures and tech info. Here's some more documents for everyone.
A/C compressor refridgerant oil checking
http://www.teamswift.net/Lihtan/gti/tech/AC%20Compressor%20Refrigerant%20Oil%20Checking.pdf
A/C compressor servicing
http://www.teamswift.net/Lihtan/gti/tech/1989%20AC%20Compressor%20Servicing.pdf
A/C system general servicing
http://www.teamswift.net/Lihtan/gti/tech/AC%20System%20General%20Servicing.pdf
A/C system specifications
http://www.teamswift.net/Lihtan/gti/tech/AC%20System%20Specifications.pdf
PostPosted: Wed Mar 09, 2005 10:22 am
A/C clutch disassembly
http://www.teamswift.net/Lihtan/gti/tech/AC%20Clutch%20Disassembly.pdf
A/C compressor servicing (various types)
http://www.teamswift.net/Lihtan/gti/tech/AC%20Compressor%20Servicing.pdf
Alternator and Regulator servicing
http://www.teamswift.net/Lihtan/gti/tech/Alternators%20and%20Regulators.pdf
Brake system servicing
http://www.teamswift.net/Lihtan/gti/tech/Brake%20System%20Servicing.pdf
PostPosted: Wed Mar 09, 2005 10:31 am
Drive shaft servicing
http://www.teamswift.net/Lihtan/gti/tech/Drive%20Axles.pdf
Electrical component locator (1.3 L TBI)
http://www.teamswift.net/Lihtan/gti/tech/Electrical%20Component%20Locator%201.3L%20TBI.pdf
G16 engine servicing
http://www.teamswift.net/Lihtan/gti/tech/Engine%201.6L%20%28Esteem%20G16%29.pdf
Radiator fan servicing
http://www.teamswift.net/Lihtan/gti/tech/Engine%20Cooling.pdf
PostPosted: Wed Mar 09, 2005 10:43 am
Fuse box locations, and fuse/circuit info
http://www.teamswift.net/Lihtan/gti/tech/Fuses%20and%20Circuit%20Breakers.pdf
G13 engine adjustments
http://www.teamswift.net/Lihtan/gti/tech/G13%20Engine%20Adjustments.pdf
MK3 instrument cluster testing and wiring diagram
http://www.teamswift.net/Lihtan/gti/tech/MK3%20Instrument%20Panel%20Testing.pdf
Power mirror testing and wiring diagram
http://www.teamswift.net/Lihtan/gti/tech/Power%20Mirrors.pdf
PostPosted: Wed Mar 09, 2005 10:53 am
Starter servicing
http://www.teamswift.net/Lihtan/gti/tech/Starter.pdf
Ignition and combo switch servicing
http://www.teamswift.net/Lihtan/gti/tech/Steering%20Column%20Switches.pdf
Steering column servicing
http://www.teamswift.net/Lihtan/gti/tech/Steering%20Columns.pdf
Steering rack servicing
http://www.teamswift.net/Lihtan/gti/tech/Steering%20Manual%20Rack%20and%20Pinion.pdf
PostPosted: Wed Mar 09, 2005 10:58 am
Front suspension servicing
http://www.teamswift.net/Lihtan/gti/tech/Suspension%20Front.pdf
Rear suspension servicing
http://www.teamswift.net/Lihtan/gti/tech/Suspension%20Rear.pdf
Automatic transmission removal
http://www.teamswift.net/Lihtan/gti/tech/Transmission%20Removal%20and%20Installation%20AT.pdf
Automatic transmission adjustments
http://www.teamswift.net/Lihtan/gti/tech/Transmission%20Servicing%20AT.pdf
PostPosted: Wed Mar 09, 2005 11:03 am
Wheel alignment specifications
http://www.teamswift.net/Lihtan/gti/tech/Wheel%20Alignment%20Specifications.pdf
Wiper/washer testing and wiring diagram
http://www.teamswift.net/Lihtan/gti/tech/Wiper%20-%20Washer%20Systems.pdf
Wiring diagrams
http://www.teamswift.net/Lihtan/gti/tech/Wiring%20Diagrams.pdf
PostPosted: Mon May 16, 2005 7:36 am
The entire manual transmission section from the Suzuki Swift factory service manual is now available here:
http://www.teamswift.net/viewtopic.php?p=110462#110462
PostPosted: Mon Jun 13, 2005 9:33 am
TPS Tech: functional explanation of the TPS sensor mechanism, and diagnostic flowcharts for codes 21 & 22. Combine this data with previous TPS calibration info (above) for a full TPS diagnostic suite.
TPS Operation
image_id: 4461
Code 21 TPS Diagnostic
image_id: 4462
Code 22 TPS Diagnostic
image_id: 23358
MAF Tech: MAF sensor principle of operation, bench testing, diagnostic flowcharts for codes 33 & 34.
MAF Operation
image_id: 23357
MAF testing
image_id: 4465
Code 33 MAF Diagnostic
image_id: 4466
Code 34 MAF Diagnostic
image_id: 23359
PostPosted: Sun Jul 31, 2005 4:57 pm
Front suspension torque specs
image_id: 23360
image_id: 23361
Rear suspension torque specs
image_id: 23362
Steering torque specs
image_id: 4934
PostPosted: Sun Apr 22, 2007 10:01 am
1992 Suzuki Swift Supplementary Service Manual:
Section 3C Steering Wheel and Column 3C-1 contents
Section 3C Steering Wheel and Column 3C-2 general description
Section 3C Steering Wheel and Column 3C-3 on car service remove and install steering wheel (for GT model)
Section 3C Steering Wheel and Column 3C-4 on car service remove and install steering wheel con't
Section 3C Steering Wheel and Column 3C-5 checking steering column for accident damage
Section 6A Engine Mechanical (for GT model) 6A-1 contents
Section 6A Engine Mechanical 6A-2 camshaft timing belt pulley, engine mounting
Section 6A Engine Mechanical 6A-3 special tool
