It is currently Sat Jan 20, 2018 2:33 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3  Next
Yes 11%  11%  [ 19 ]
No 71%  71%  [ 125 ]
Total votes : 175
PostPosted: Wed Aug 31, 2005 7:05 pm
Electric turbo/superchargers
Fuel Magnets
Tornado/spiralmax
Please make me a stickey!!
PostPosted: Wed Aug 31, 2005 7:07 pm
Fuel additives/octane boosters are a scam too....
PostPosted: Thu Sep 01, 2005 12:12 am
Octane boosters will enhance performance provided you advance your timing or increase boost. Vehicles with knock sensors will automatically adjust their performance when higher octane fuel is used.
PostPosted: Thu Sep 01, 2005 1:22 am
Uhhh, no they won't...
Okokokokok, so the old school "TETRAETHYL LEAD" boosters work....
STP type of boosters don't work...
NOTHING is free...
PostPosted: Thu Sep 01, 2005 2:21 am
i did try one fuel injection cleaner with fuel additives once and i did save about 5%... only working durning you add it into your gas tank.
its not worth anyway. ( i need fuel injection jets to be cleaned)
PostPosted: Thu Sep 01, 2005 8:05 am
Sparky
V8's
PostPosted: Thu Sep 01, 2005 9:00 am
The only MPG gimick that I have fallen for was the acetone in the fuel tank. I am not sure if it is really a gimick. I did notice a change in the cars peformance and how it started but there was no increase in the MPG that I could see. I know some people did notice a gain.
M3----"M" body "3" cylinders.
Now Turbo'd
"M3 like the BMW?"
PostPosted: Thu Sep 01, 2005 9:19 pm
Fuel Magnets
Tornado/spiralmax
Uli,
it.
John
Fuel: Unleaded petrol
ambient temp: 19.5 deg C
Rel. humidity: 80%
Uli Xxxxxx
Right ON dude!!
Sam
"In fuel economy, there is no replacement for less displacement"
"Less IS more!"
PostPosted: Thu Sep 01, 2005 9:49 pm
OOOh, the
"CHIPS/MODULES" avaliable on e-bay are also a scam. The ones that claim 20hp increases, nonsence... They modify the reading the ECU receives from the ambient tempeture sensor, adding some fuel. That's the WRONG way to get more power...
A REAL/CORRECT chip would be something like "Tom's Chip", the ones found here. These are REPROGRAMED chips that are installed INSIDE the ECU/Computer.. Ignition maps and fuel maps are modified.
PostPosted: Thu Sep 01, 2005 10:26 pm
Nowhere wrote:
OOOh, the
This is true, the resister type modules do nothing for you at all.
It doesn't matter if it has a variable potentiometer or not.
Reprogramed chips are the way to go, I agree 100%.
Check out this neat system that turns your gameboy into a tuning tool.
http://www.turboxs.com/
That's some serious business...
Sam
"Less IS more!"
PostPosted: Thu Sep 01, 2005 11:10 pm
i wonder have you heard or tried "powerchip" at [ http://www.powerchipgroup.com/choices.a ... roup%2Ecom ] to imrpove hp/torque and save more gas?
PostPosted: Thu Sep 01, 2005 11:11 pm
edit: sorry i forget to add something...
is it working or better than buy aftermarket ecu ( which i don't know if they improved gas or whatever)
PostPosted: Thu Sep 01, 2005 11:44 pm
Quote from them:
Your Nissan 300ZX 3.0 V6 Twin Turbo utilizes a plug-in plug-out chip (EPROM). Fitting is simple and the Powerchip can be installed in about 30 minutes with basic skills and equipment. To install the upgrade software, simply locate the computer and un-plug the standard chip. Place the Powerchip performance chip into the socket and insert fully. Then, close the computer, re-install into the vehicle and start the engine to fully complete the installation process.
Looks like they are a legit EPROM burning/chipping company, not a knock off temp sensor mod...
They don't make anything for suzuki though....
PostPosted: Fri Sep 02, 2005 2:11 am
i see
http://www.powerchipgroup.com/interact/ ... id=Suz0004
try austrialla.. i don't know what different between aus and na
PostPosted: Fri Sep 16, 2005 6:29 pm
Kento87 wrote:
V8's
LOL
PostPosted: Sun Sep 18, 2005 12:36 am
Found another one
"Electronic Fuel Injection Enhancer"
Found here:
http://www.eagle-research.com
:ez_lol:
PostPosted: Sun Sep 18, 2005 4:54 am
I was just looking at that device recently. It claims to work by modifying the voltage the ECU sees from the O2 sensor. Leaning out your fuel mixture may save some fuel, but your NOx emissions will go up. In a worse-case scenario you may damage your engine from knocking or melt a piston.
PostPosted: Sun Sep 18, 2005 5:08 am
:cheers: Image
PostPosted: Sun Sep 18, 2005 8:16 am
This is one thing that I use. The claims are true. It does exactly as described.
I've used it for several years with absolutely no problems.
My NOx does not go up because of the other stuff I am doing to the engine.
Everything, HC's, NOx...you name it are down as a result.
This is the best $50 I ever spent.
Sam
"Less IS more!"
 Post subject: Wiseman's EFIE
PostPosted: Sun Sep 18, 2005 8:32 am
Instead of posting what it "may do", why don't you try one and see what it DOES do???
If you've never put one between your ECU and O2 sensor, then any comments made here about it are a moot point.
Do programmable engine management systems work?
Would you like to be in control?
Think about it...
Experience it, then come back here and post what it does.
Sam
"Less IS more!"
PostPosted: Tue Sep 20, 2005 1:27 am
I like to know what something does before I go slapping it on my car. Both good and bad. Products like air flow controllers, nitrous and turbo kits all have warnings that if you mess with them beyond the boundaries of your knowledge, you may damage or destroy your engine. Despite these warnings, people still manage to destroy their engines using "safe" products. This O2 sensor voltage modifier has no such warning. Now don't get me wrong. The theory itself is valid. There's a number of ways you can fool the ECU to change to a different location on the fuel map. Airflow converters like the Apexi SAFC modify the signal from the MAF/MAP sensor. The T3 guys like tinkering with the output from the coolant temperature sensor. The O2 sensor is just as valid as an input. All of the above can also damage your engine if you don't know what you're doing. However, so far, I've been the only voice of reason to examine possible negatives from this device's installation. Selling a bolt on, one step "fuel saver" that neglects to mention that knowledge of engine tuning is required is irresponsible. Myself, I would only ever install a device like this if I had a secondary wideband O2 sensor to tell me what the real air/fuel mixture is. Narrow band O2 sensor are notoriously inaccurate for tuning an engine with. If that's your only source of data, and you're also deliberately tinkering with it's readings, you'd have better luck groping in dark.
 Post subject: EFIE
PostPosted: Tue Sep 20, 2005 2:15 pm
I agree with you totally. If you don't know what is going on, it is best to leave well enough alone. I can only describe what I have done and how I've done it to the best of my ability. I have 5 years experience with the EFIE, so I feel safe and secure myself. I know others who can say the same.
I took big risks with my little $200 XFi and I'm glad I did. It's paid off.
Buying the EFIE manual beforehand is a safe bet though. I doubt you could damage anything buy reading about it. If you are up on your electronics skills, the circuit diagram is there in the manual as well.
Sam
"Less IS more!"
PostPosted: Tue Sep 20, 2005 6:26 pm
:clap:
Instead of posting what it "may do", why don't youtry ( :roll: )one and see what it DOES do???
C'mon, gimme your money!, just buy it, no really gimme gimme gimme!!!!!!!!! :stfu:
Are you also involved in quixtar/amway? Do you have prepaid legal services? :roll:
PostPosted: Tue Sep 20, 2005 6:39 pm
Or... you could just be satisfied with what you are getting at the present.
Actually, this stuff is in the public domain.
As in FREE.
:shock:
But if you aren't down on your circuits, then ya gotta pay da Moanaye
if you want to play.
Wiseman has a "no patent" philosophy on the things he creates. He puts them in public domain to prevent anyone else from patenting them.
But, you would have known that if you looked into it.
"Less IS more!"
PostPosted: Wed Sep 21, 2005 1:05 pm
It's fairly safe to add this because the oxygen sensor is only really used at light throttle / closed loop operation.
When the car is running closed loop it purposely cycles between rich and lean because that's the way the oxygen sensor and cat work best. You end up with an average that is stoichiometric. If you shift the voltage of the oxygen sensor you can end up with an average that is a little rich or a little lean depending on your settings. It will probably save you a few MPG but it might also cause your cat to wear out a few thousand miles early. (not a really big deal)
ed
