It is currently Wed Jan 17, 2018 10:38 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Thanks Suprfly
PostPosted: Tue Sep 26, 2006 6:07 pm
I cannot change the head or cam unfortunately :( because it's stock class
If there's anything else you can think of that would assist the performance of the car, which is within rules, it would be wonderful
Vinay
Last edited by flickeringflame on Thu Sep 28, 2006 4:08 pm, edited 1 time in total.
 Post subject: rules attachment
PostPosted: Tue Sep 26, 2006 6:10 pm
I have attached the rules for our class
Thanks,
Vinay
PostPosted: Tue Jun 29, 2010 1:12 pm
hello im looking for someone to help me get my crank and cam gear back on timing, as they were moved separately while timing belt was off!!! i do not have a timing belt and my marks disappeared! car is off road back private drive reading pa
PostPosted: Tue Jun 29, 2010 1:18 pm
search. there are pics al over the place here. The crank pulley has a dot that points to an arrow on the oil pump, basically straight up. the cam has a mark that lines up with a notch on the front of the valve cover. Also there is a dowel on the cam that aligns the pulley, it will be pointing straight down when the cam is in place with the top mark line up with the valve cover notch. Pics will show this when you find them.
PostPosted: Mon Aug 30, 2010 2:30 am
Is adjustable cam gear worth on a Suzuki Baleno 1.6L G16B SOHC stock engine ?
http://www.connect2in.com
