It is currently Thu Oct 19, 2017 3:24 pm
 Post subject: New things on my 1.6
PostPosted: Wed Jan 03, 2007 11:08 pm
The crank trigger is installed!
And the GSXR coils have been test fitted, not yet installed because I didn't have the transistors to drive them last saturday.
PostPosted: Wed Jan 03, 2007 11:32 pm
lookin good! what are the benefits for both mods? :huh: :oops:
EngineWhisperer wrote:
v-tec ain't $hit honda sucks and b16-18 are like tampons every pu$$y needs one.
PostPosted: Thu Jan 04, 2007 8:54 pm
the crank trigger gives more precise ignition timing, free from all the jitter associated with a timing belt and distributor drive.
The coil-on-plug just gives a more reliable ignition and less electrical noise.
PostPosted: Sat Jan 06, 2007 7:01 am
hmm any chance on a full write of where these parts got sourced, how to, and costs :)
-Santos :furious:
<i>Can you rent Karma?</i>
PostPosted: Sat Jan 06, 2007 10:05 pm
The crank trigger was cut by a local machine shop using an Omex CNC waterjet. Another source would be emachineshop, their software has a gear wizard so its quite easy to make things like this with it.
The sensor I used was an ABS sensor from the rear axle of a Toyota 4runner.
The coils come off a GSXR600 and were sourced on eBay.
And to control the lot I use a Megasquirt.
PostPosted: Sun Jan 07, 2007 3:39 am
Bozo the crying clown
any idea on a dwell setting for those COPs?
Matt
Megasquirt Specialist.
www.mtmotorsport.ca
PostPosted: Sun Jan 07, 2007 9:35 am
No, I will just use the scope to work it out. Should be something like 7ms.
PostPosted: Fri Jan 12, 2007 1:07 am
Id love an electromotive setup to run carbs but this seems a great little upgrade if I used a cheap ignition only setup.
Some bikes used ignition only crank angle setups but electrics are my weakness. will be nice to see the results of your setup.
PostPosted: Mon Feb 26, 2007 12:46 pm
Certified (nuts)
So are u still in Dublin Baldurg?
When can I have a look at ur modifications/cars/jeeps etc?
Are you any good building custom exhausts?
:wink:
 Post subject: Re: New things on my 1.6
PostPosted: Wed Mar 14, 2007 2:55 pm
Nice job! I'm working on doing the same thing at the moment, it's going to be tricky getting the pulley and the trigger wheel concentric. I was thinking of tack welding it on but i'm going to have to make sure I have the trigger angle 100% correct before I go doing that.
It would be nice to have and adjustable setup, similar to how adjustable cam pulleys work.
 Post subject: Re:
PostPosted: Mon Sep 14, 2015 5:25 am
Hi mate,
I'm going to setup a megasquirt for my Swift gti. I saw your post, and I was ondering to get those ignition coils from GSX-R. That ignition coil it's "plug n play" it fit well? Did you connect them in Parallel or Series (check the pic)? I said something about a transistor's?? What for?
Sorry for the bad english and also sorry for digging this old thread...
Regards from portugal.
DaRK
