It is currently Sat Jan 20, 2018 10:19 am
Post new topic Reply to topic  [ 270 posts ]  Go to page 1, 2, 3, 4, 5 ... 11  Next
PostPosted: Tue Jan 09, 2007 4:21 pm
Date 4-29-09
Two years and still not done :mrgreen:
Things have changed over the years.
It's going to have a Honda CX500 engine and drive train in it. Hopefully converted to electric later.
john :D :D
I'm building a mini based three wheeler that will have a metro 3 cylinder engine and transmission.
john :D
PostPosted: Tue Jan 09, 2007 4:53 pm
why not put a suzuki race bike engine in it:P would be cool...but thats alot of work your doing and its comin along great. hope it works out well in the end for you
PostPosted: Tue Jan 09, 2007 5:11 pm
Thanks,
I have a Honda cx500 bike frame (with title) that I'm going to use for the back wheel.
I want to get it on its wheels by summer.
Then get it running with a gas motor by the end of summer.
The plan is to make it a hybrid electric.
john :D
PostPosted: Tue Jan 09, 2007 5:22 pm
johnsn wrote:
Personal Gallery of johnsn
http://www.teamswift.net/album_personal ... er_id=7199
john :D
PS. sort acending and it will make more sence. Maybe.
.Image
John a three wheel suzuki powered Mini
"Wow" that's just nutier then a shite house rat
---------------------I love it !!-----------
Wish a I had the scones to do something like that
please keep us posted on how it goes with pictures
PostPosted: Tue Jan 09, 2007 6:07 pm
The blue mini is going to be "restored"
It will look like a mini, but it will have a Suzuki engine and trans.
Also it will have a Honda torsionbar front suspension.
You can see the left half sitting on the drivers crosmember.
john
PS. how do I rearrange my photos in my gallery?
PostPosted: Tue Jan 09, 2007 7:00 pm
johnsn wrote:
PS. how do I rearange my photos in my galery?
You can't you just have to deleat them and add them
in order that you want ---JV&S
PostPosted: Wed Jan 10, 2007 1:25 am
johnsn wrote:
...PS. how do I rearange my photos in my galery?
You can't, but you may want to directly embed them inside this thread.
Info on how to post images:
http://www.teamswift.net/viewtopic.php?t=4
PostPosted: Wed Jan 10, 2007 4:03 am
You got big cahones.
Had a guy call the shop a couple weeks ago looking to get us to weld a motorcycle front end onto a metro, didnt elaborate any more and we had to turn him away (liability reasons) Now i'm curious as hell since the guy is local.
Keep up the good work, your making it a convert?
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Fri Jan 12, 2007 11:18 am
quot
Thanks Scott. I don't know if I'll go to the trouble of a folding top.
No top to start. Maybe a removable top later.
john :D
EDIT:As you can see later in the thred I put a top on it. It rains too much in Oregon to not have a top.
PostPosted: Fri Jan 19, 2007 10:44 am
I learned how to post pictures
Image]
first mock-up in the garage last winter
Image]
lots of air not much metal
Image]
this summer, more metal. still too much air
Image]
still too much air
Image]
I don't know if I want to use a fiberglass front end
john :D
PostPosted: Mon Jan 22, 2007 11:58 am
I want to make this all electric someday.
I think I'll start making it all gas to get it on the road.
Then add an electric motor and some batteries.
image_id: 10776
Here is a model with two seats all electric.
I think it's too long.
image_id: 10780
Here is a model with one seat all electric.
Not too long, but crowded with batteries.
I'll go with this.
Now to building.
Image]
mini sub-frame, crosmember, and toe-board.
Image]
Fabricate the firewall
Image]
weld the firewall to the cowl.
Image]
weld on the crosmember
Image]
weld on the toe-board
Image]
fab inner fender-wells
:D
PostPosted: Mon Jan 22, 2007 4:14 pm
Then I moved it in the garage
Added 1.5" tubing to re-enforcements for the A pillar
Used threaded rod and conduit to pull the post into position
Like this, everything held in position
Then welded in place
Added filler metal and door mounting brackets
I like to weld :D :D
But I don't like to get burnt Image :shock: :censor:
john
PostPosted: Tue Jan 23, 2007 3:46 pm
Pictures almost caught up with the work.
bottom cross tube
rocker re-enforcement
steering rack mount
door mount brackets and shock mounts
left rocker
with left rockers and a and b pillar and door step :D :D
PostPosted: Tue Jan 23, 2007 4:17 pm
was playing around...
steel front end mock-up
the wheel will stick out a little :ez_l0l:
I need to be able to rotate the car
johnsn :D :D
I need to be able to weld at different angles.
so I built this adapter to fit my cherry picker.
I'll need some kind of support for the other end too.
drivers brakes and suspension
PostPosted: Wed Jan 24, 2007 11:06 am
This weeks work.
repaired L inner sill
inner sill. silver weld through primer
left rocker tube gusset and self etching primer
left rocker tube gusset and weld through primer
inner sill clamped in place
inner sill welded in place
the self etching primer burned from the welds on the other side. that's ok, it was there to prevent rust
inner sill welded in place. two colors of etching primer
L door surround with part of the quarter panel
silver weld through primer. red rust encapsulating primer
inside B pillar view
inside L inner door step view
PostPosted: Tue Jan 30, 2007 2:06 pm
Had a productive weekend. :D
Left inner sill and support tube, red rust encapsulating
conduit cross bracing
sanded and ech primed
turn buckle to pull right tube into place
right tube in place. gusset welded in, and cross brace
It was sunny out. :D
I bought a inner sill/outer rocker assembly. but I took it apart because it was not rust treated between the panels
right inner sill welded in. the camera shutter didn't open all the way
right inner sill welded in. I decided to weld patches in the holes after welding the sill in. Less warping.
welded in the start of the seat mount
silver weld through primer. sunny day :D
image_id: 10934
doing some CAD work on the model
PostPosted: Tue Jan 30, 2007 2:40 pm
found old pictures of a wheel arch mock-up
:ez_l0l: :rollin: :oops:
:puker: :thwack:
maybe something like this :D
Anyone reading this?
:poke:
PostPosted: Tue Jan 30, 2007 3:40 pm
thats a lot of pics. looks like it will turn out pretty nice
Project Page
Image Image
PostPosted: Tue Jan 30, 2007 5:19 pm
Very cool project john
"Very cool"
I'm watching just don't want to clutter up your post
Have you thought of a color yet ??----------JV&S
.Image
PostPosted: Tue Jan 30, 2007 5:39 pm
:D Something bright that will show up :D
It'll be a small car. So I want it to be seen. It will be multi colored for a long time.
It has a name. Sparky. edit maybe not :-P
john :D
PostPosted: Wed Jan 31, 2007 4:00 pm
Ive been working on the frame design.
this will tie into the motorcycle frame.
PostPosted: Tue Feb 06, 2007 4:54 pm
This weekend I got the Honda motorcycle frame on.
I used pipe and conduit with turn buckles to line everything up.
side view
setup to mount Honda frame. Turnbuckles for adjustment.
Vice grips for a stop to keep the bike frame from sliding down too far.
Honda frame installed the first time.
long :shock: Think how long it would be with two seats. Add 24 inches
Plywood floor boards. Will be replaced with steel.
conduit bracing
conduit is cheep and useful :D
Do I need this hump?
side view with rear suspension and wheel. That wheel is too low!
turn buckle to pull the frame into place.
cut frame to put stiffener between shock mounts
As I was building the cross-brace I ran out of welding gas :-P
Also when I cut out the bracing for the upright, I found out the turn buckles to the windshield posts where not stiff enough and the Honda frame went out of alignment.
So back to the drawing board. :furious:
PostPosted: Wed Feb 07, 2007 12:37 pm
re-enforcing tubes, and conduit cut to hold wheel at full spring compression.
New bracing
Old swivel chair adjuster used as a jack
Turn buckle to pull the frame into place. Used the jack to raise the honda frame. You can see how much I raised the Honda frame.
All done. (I wish). Still need to replace the conduit that goes to the front.
It's on one wheel! :D
PostPosted: Wed Feb 07, 2007 6:31 pm
Senior Member
Just one question, You live in 'merika yeas? So what are you doing with a mini AND a morris minor???
That morrie would be worth a mint there, surely?
PostPosted: Thu Feb 08, 2007 3:28 pm
They imported Morris Minors and Minis in to the USA.
I like them. Morris Minors don't cost a lot compared to the Mini. Maybe 1/2 to 1/3.
I'm thinking of putting a Suzuki engine and a samurai transmission in the Morris.
john :D
