It is currently Wed Oct 18, 2017 7:38 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 07, 2006 11:59 am
do a search. theres even a section on engine managment.
tempo
PostPosted: Thu Dec 07, 2006 8:03 pm
i just ordered a megasquirt kit for the turbo motor I’m building for my metro. From what I’ve read, there are many people who have had some serious success with these "build it your self" units. With the on board map sensor and it's already integrated water injection control circuit, the free software, support group, ect. It’s all there. Just solder it on!
;) :lol:
PostPosted: Fri Dec 08, 2006 12:23 am
Really thats awesome b/c I curently am living off a student loan so any way to save money is perfect. I was given the tdo4l and the cooler and bov were cheapies from a friend. The only money i want to spend is on a wideband to make sure my poor man set up even works. I want something that works then i will spend the money on the electronics. Another thing..what about say greddy e-management or something like that.Its alot cheaper than mega squirt. Can the stock MAF adjust for boost with large enough injectors.
PostPosted: Fri Dec 08, 2006 9:13 am
HEY THIS IS A STICKY TOPIC TO DESCRIBE TURBO SETUPS.
So... please start your own thread if you're looking for advise, or you can use the search tool also.
PostPosted: Fri Dec 08, 2006 6:59 pm
that truely is a pitty...the search option is ok at best. I am describing my setup..its just not complete. Sure i found some info but it wasnt that informative at all. Another thing is im just getting into stand alone system so therefore i dont understand the lingo. This is were ive come to find the advise i need. I am adding a turbo just like the forum index states so why does someone always have to tell to me search. Cant they resist the temptation to be an a$$. Oh sorry this forum isnt for bitching its for adding turbo or nitrous so ill continue on the you people are useless forum Thankyou
 Post subject: My little setup
PostPosted: Mon Dec 18, 2006 1:24 pm
What engine management are you running ?
Microtech LT-12S
What’s done to your engine ?
Port/polish head
SuzukiRD Titanium valvetrain + solid lifters
SuzukiRD Titanium Oversize valves
Catcams customised Turbo cams
Catcams adjustable cam gears
Top Secret 1.2mm turbo MLS gasket
Dave Homer Forged 76mm Turbo Pistons
Dave Homer Forged Spool con rods
Dave Homer upgraded oil pump
ARP head studs
Custom Blockguard
How much boost ?
High boost - 22psi
How many horses you got at the wheels ?
300hp on wheels.
What octane fuel ?
RON 98
Which turbo/supercharger you using ?
IHI VF22 turbo.
Tial 41mm External wastegate
If Turbo what manifold are you using ?
Customised tuned equal length manifold
What RPM do you start pulling boost ?
Full boost 4500 RPM - 9000RPM.
And anything else you think might be worth sharing !?
-Cultus Intake bore matched to 60mm SuzukiRD TB
-MSD SCI + HVC coil
-NGK 7 racing cold plugs
-Aurora cables / Ultra Racing cables
-560cc EVO 9 injectors
-RZM Fuel Rail
-Sard 280lph intank Fuel Pump
-Aeromotve fuel regulator
-60mm SuzukiRD Throttle body.
-Garrett 350Hp FMIC
-Greddy Type-RS BOV
-ACT Custom turbo clutch 4-puck rated 395Nm
-Rospen LSD
-2.5" downpipe
-2.5" Borla centre muffler + Borla rear turbo muffler
-Apexi Exhaust Valve controller
-Apexi AVCR Ltd Edition (Black)
-Custom water tank 2L
-TurbineTech Aluminium radiator with Spal fan
-Relocate Air-con condenser and 2 Fan
-Apexi EL gauges(Boost,EGT,Water,Oil temp,Fuel press)
-PLX devices wideband AFR gauge
-SuziTech Strut with engine damper
-Hotbits adjustable coilovers
-Whiteline ARB
-Wilwood 4-pot
-Rota Slipstream 15x6.5 ET40 + 15mm H&R spacers.
-Toyo R1R 195/50/15, 195/50/15
-Momo race Steering wheel
-Momo gearknob
-Momo handbrake lever
-Birba racing dails
-Recaro Pole Position "L" size with railings.
-Suscus reclinable seat
-Sony head unit with sound system.
-Apexi turbo timer
-V-cool whole car
-70amp alternator
-Battery relocated to rear
- Cusco oil catch tank
WIN LOSE never mind, PATTERN must be nice!
PostPosted: Tue Mar 13, 2007 11:40 am
*4year project (swap from 93 1.0L metro to built and turbo 90 swift GT) about to get running in the next week or 2 http://www.cardomain.com/ride/579001/7*
What engine management are you running ? - Greddy Emanage Ultimate
Wiseco Forged 9:1 pistons
bored .040" (1mm) over
honed block
blanaced bottom end
ported and polished head by turbinetech...extreme style, unmask valves, 3angle valve job, combustion chamber reshape for +5cc each,
.5mm oversize stainless valves
high volume oil pump
stage 3 SPEC clutch kit
255lph walbro (whinebro) fuel pump
1G DSM SMIC
1G crushed BOV
Compilation of 1G DSM and Galant VR-4 IC piping
2G DSM 450cc injectors
turbinetech fuel rail
aeromotive rising rate (1:1) fpr
oil filter relocated to infront of right drive wheel but behind bumper
older ford ranger oil cooler
sandwich plate oil thermostat
50mm throttle body
2.5" downpipe
2.25" straight exhaust with just cheapo muffler in back
oil pressure gauge
oil temp gauge
AEM UEGO Wideband gauge and output to emanage for autotuning
30/30 Boost/Vac gauge
How many horses you got at the wheels ? unknown
What octane fuel ? US 92octane
Which turbo/supercharger you using ? Mitsu TD05H-14b
What manifold are you using ? Turbine Tech Equal Length
What RPM do you start pulling boost ? dont know yet...give me a week or two
And anything else you think might be worth sharing !? 16" wheels with 205/40r16 tires, will be trying to find a td05h-16g compressor side for my turbo soon...thats about it.
Project Metro
~Possibly For Sale~
PostPosted: Wed Aug 15, 2007 12:27 pm
Engine = Stock Cb80 Daihatsu
Boost = 12 Psi
WHP = Unknown
Fuel = I dun Understand I Use Simple Hi-Octane.
Charger =Orginal Daihatsu Stock Turbo.
On Boost = 3500 Rpm Its takes The boost
Manifold = Orginal Daihatsu GTti Manifold.
Anything else = HKS Blow Of Valve, ACT Clutch Plate.
its with total Stock internals, Just overboosted It from 8 -9 Psi to 12 Psi Exact.
Rebuilting My GTti, The KiCk @$$ Machine... Ahsan GT.
 Post subject: setup
PostPosted: Wed Sep 05, 2007 3:44 am
mitsubishi tdo4 turbo
custom cooler
microtech computer lt10
nitto external w'gate
msd 6a ignition
custom plenum
fully rebuilt engine
1mm oversize pistons (vitara)
440cc injectors
turbosmart dual stage boost
jim berry clutch
turbosmart supersonic bov
walbro 550cc fuel pump internal
2.5 inch stainless exhaust
pwr radiator
ford xf falcon throttle body
PostPosted: Wed Sep 05, 2007 10:26 pm
What engine management are you running ? SDS Stand alone
Stock knife edged,polished and balanced crank shaft.
Stock rods were giving a treatment to make them stronger(don't remember the name) and polished.
Every bearings and gaskets are new.
Custom 4mm oversized Venolia forged pistons.
Port and polish head,reshaped combustion chambers.
T3/T4 turbo with 3'' downpipe.
Custom 3'' mandrel bent exhaust.
Tial blow off valve and waste gate.
Custom 2.5'' mandrel bent piping.
Adjustable cam gears.
Oversized to 50mm stock T.B.
Walbro 255lph fuel pump.
Bosch fuel regulator.
Turbine tech fuel rail.
440cc injectors.
Jaz oil catch can.
Turbine tech oil filter elocator kit.
Spearco intercooler.
ARP head studs.
How much boost ?15psi
What octane fuel ?94
Which turbo/supercharger you using ?T3/T4
If Turbo what manifold are you using ?Turbine tech equal length ceramic coated
What RPM do you start pulling boost ?3500rpm
Polyurethane bushings all around.
4 cross-drilled KVR discs.
KVR carbon pads all around.
Apex coil springs.
I probably forgot some things...
1993 boosted Suzuki Swift GT
PostPosted: Sun Nov 18, 2007 3:41 pm
Stock motor
Stock fuel pump
Long runner turbo header custom made by me
honda highflow fuel rail
TD04hl 15g turbo off a 95 Volvo 850 high pressure turbo
Spark plugs-BR7ES
Megasquirt 1 fuel and spark msnsextra gm hei ignition module
330cc turbo mx6 injectors
Saab viggen intercooler
94 pump gas
272 cams
15 Psi
2.5 downpipe
2.5exhaust
straight thru muffler
197whp 168tq on the dyno 200-205 While driving moving air through intercooler.
Steve
04 Acura tsx - daily driver.
Image, Image
Last edited by black_striped_GT on Fri Mar 25, 2016 10:33 pm, edited 2 times in total.
PostPosted: Tue Jan 22, 2008 1:07 am
Garndi turbo eprom chip
Stock internals, 2.5" exhaust with magnaflow high flow cat and flowmaster 3 chamber muffler mounted in center of car
How much boost ?
6.6 psi
119.3 @ 5700
What octane fuel ?
92
IHI RHB5 off of a JDM subaru 2.0
Homemade custom extra ugly manifold.
3k, full boost at 4k.
And anything else you think might be worth sharing !? Needs a LSD! First gear floored is useless. Ebay intercooler, 2.5" charge piping.
PostPosted: Tue Jan 22, 2008 2:40 pm
Adaptronic 420C
Stock engine, MK1 gti fuel rail. 4pads clutch plate + double diafragm pressuregroup (good for 500Nm)
How much boost ?
8-10PSI
No idea, think about a 150hp
What octane fuel ?
98RON
Garrett TB0253 (volvo 460 1.7 turbo)
Home made
about 7psi @ 3000 rpm
 Post subject: Re: Got Boost ?
PostPosted: Mon Oct 11, 2010 5:50 pm
tread revivied!!!!!!!! i was wondering no 3cil turbo here???? :huh:
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Tue Oct 12, 2010 11:13 am
I never posted mine, and since I have no dyno proof i'm not gonna get in details.
engine management : Megasquirt 2 alpha code 3.0.3
engine : minor port job, polish, SS standard size valves, 226/375 cam, stock bottom end.
boost : 25 psi
power guesstimate : 140-150ish WHP (could spin 2nd gear from rolling at 60km/h up to 90km/h, 3rd gear felt like it broke loose when I rode on cracks in the pavement)
fuel : 91
turbo : subaru WRX TD04L-13T
manifold : homemade
at what RPM you see boost : 1 psi under 3000, full 25 at under 5000rpm, no redline,
other thing to mention : pulls strong up to 7500rpm, can rev over 9000rpm.
like I said it didn't last long I couldn't do any 1/4mile runs with it. I think the fuel pump was the culprit (stock GT pump)
Suzuki Gold Master Tech
