It is currently Fri Jan 19, 2018 7:13 am
PostPosted: Mon Dec 17, 2007 3:36 pm
I`m doing a mikuni carb setup and ive been thinking of using my standard injectors + ECU as a water injection system as i run a very high compression piston and have to retard my timing otherwise i get detonation. Would the standard gti injector be ok for water delivery or would it deliver too much water for the cylinder chamber ?
Also im thinking if i make a water tank slightly higher than the fuel rail would it work ok gravity fed like how fuel tanks work in motorbikes, but obviously with water? would save having to have a water pump.
Sam
2000 Suzuki Swift GTi (MK2 1991 Engine)
PostPosted: Sun Mar 23, 2008 5:44 am
I run high compression to but not this high lol good luck and let us now wat compression you running mnines will be above 12-1 shortly is that high?
Flat To The Mat
