It is currently Tue Oct 17, 2017 5:39 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
PostPosted: Mon Nov 19, 2007 11:29 am
here it is.
All or nuttin
PostPosted: Mon Nov 19, 2007 11:31 am
here is mines going into the Escort Mk1.
All or nuttin
PostPosted: Mon Dec 17, 2007 1:28 am
pics please!!!! :shock: :(
PostPosted: Wed Mar 26, 2008 10:58 am
of which? the 2.7 baleno project has been scrapped and now coming RWD as it was impossible to get the drivers side axle fit.
The swifts being rebuilt using a 1000cc swift box hope the internals will last, planning on getting a 4.9:1 diff set.
All or nuttin
PostPosted: Sat Jun 21, 2008 8:37 am
compression n cams
Rebuilt the engine to 1.9 using F20b honda pistons...cr is now 12.75:1 engine is only being used for track now so thats no problem..
Last two weeks when i drive the car everyday it had amazing torque low down couldnt rev it, cause i pinked like mad above 2500 rpm....but still was able to tow my escort mk1 race car comfortably in 4th gear under 2500rpm.
Now that im using it for track use i'm wonder if the standard cams are capable or if i need new cams? cannt find manufacturers specs on these cams but by my measurements. Base cicle is 29mm and 11.75 max lift inlet and 29mm and 10.25mm exhaust. Uses hydraulic buckets so its a 1 to 1.
will post some rod data later today but from the engineering specs of this engine it should be a good performer wid standard items like a 1.8 gsr honda except the lift.
may run it on carbs to but not sure yet.
All or nuttin
PostPosted: Sun Nov 23, 2008 11:21 pm
Hey, I was looking for pictures on google about the J18 crank and came across you guys. You might have seen my vids on youtube. :wink: Anyways, I was wondering if you still have or have specs on the J18 crank. I want to do a build up to maybe a 1.9L using J20 parts. but Want/need specs on the J18 internals before I decide to go and buy a J20 for parts. I am/was a mod on Clubaleno. The owner recently pulled the site down. I am trying to buy it back to get it online again. I still have not heard back from him. Wish me luck. :mrgreen: Heres my car as it is atm.
What it should look like when I am done.
and my other leno 8)
>>>CLUBALENO<<<click me
Image2000 Suzuki Baleno (DD)Image2001 Suzuki Baleno (Overhauling)
PostPosted: Mon Nov 24, 2008 10:43 am
BTW, the white one is going to have the engine taken out is why I am inquiring about this. I may have to just rebuild it if I cant get the money in time to do what want to do with the J20 Dont want the whole J20 engine swapped in, I just want to build it up to a higher comp from the 9.8 to 10.5 if I can do it with OE parts. This car needs to be ready to go to Japan after May. Will need to ship it AFTER I get a Japanese license, that will take a while. :?
PostPosted: Mon Jan 26, 2009 6:49 pm
What flywheel did you use? I picked up a J20 today and the flywheel is too large for my bellhousing so I'll need to either source another bellhousing or a different flywheel.
PostPosted: Tue Mar 03, 2009 2:34 pm
from a while back i been lookig at this, now im thinkin seriously bout going larger engine. this is the baleno engine right (DOHC 1.8 baleno)?
would it be possible to replace my engine Image
with the vitara 2.0L engine? and boost it of course :D
PostPosted: Thu Mar 12, 2009 11:15 am
Sorry for the late reply, but is this a question for me? I am still using the J18, and after some reasearch using J20 parts is not in MY interest. I am working on using different parts though. I posted some info on my replacement site for the old clubaleno. Still need to buy a domain. haha :lol: >> http://clubaleno.21.forumer.com/index.php
Bye the way, I am completely tearing down my J18 so expect lots of specs to be posted.
Just some teaser pics for you. :P
 Post subject: Re:
PostPosted: Tue Mar 17, 2009 7:11 pm
yes on the escort pls!!!
Claude B,
good to see someone doing up a j18 but I think you have to be careful of the rods and perhaps a hollow style crank?.
PostPosted: Wed Mar 18, 2009 9:21 am
that pic, is it of a swift or baleno engine bay? in case i missed where it was said. getting vitara engines here in Jamaica is no problem in terms of availability, might be a bit pricey. i would like to know the technicalities involved in making that conversion into my swift and where possible not alter the chassis leg. thanks
western, maybe u and me could make a link and work out something.
PostPosted: Sun Apr 26, 2009 7:12 pm
flywheel was a lightened J18 which is the same as J20. u would have to use a G16 gearbox bell housing. or cut down the diamter of the 1.8 flywheel n use the standard 1.3 bellhosings. but the gti clutches slip on the 1.8 so better to keep using the 1.8 setup.
All or nuttin
PostPosted: Sun Apr 26, 2009 7:33 pm
Ok. So the 1.8 has a smaller flywheel. My engine comes out of a Grand Vitara and it has a much larger flywheel than the G16B as found in the Vitara.
PostPosted: Mon Apr 27, 2009 8:55 pm
baldurg, you can grab a flywheel from an aerio/liana with a J20, it's the same as a J18 andshould fit. the vitara flywheel is much thicker than the esteem one.
Suzuki Gold Master Tech
PostPosted: Thu Apr 01, 2010 12:49 pm
I NEED HELP URGENT I NEED THE J1.8L PINLAYOUT DIAGRAM .PLZZZZZZZZZ.SEND ME A COPY PERRYMLVR@GMAIL.COM
PostPosted: Thu Feb 07, 2013 6:56 pm
http://i21.photobucket.com/albums/b262/ ... 0_0730.jpg
so J18 cranks are not cast hollow units by the looks of it
PostPosted: Sun Jun 16, 2013 4:23 am
depends on the year.
some are hollow some are not... i have had both. All my engines where imported from the USDM.
All or nuttin
PostPosted: Sun Jun 16, 2013 5:10 am
2" weiner
The Australian J18 i have has solid crank pins, not hollow like G16a
(being in your locality d, id assume thats what you were seeking, AusDM and JDM halfcuts)
PostPosted: Sat Dec 28, 2013 11:51 am
Jus might be a part two of the jSeries Conversion. Will be building another but sprint/track only.
All or nuttin
PostPosted: Thu Mar 16, 2017 10:33 am
Hi from Germany,
I want to bolt a J18A to my Samurai gearbox: I am a little bit confused about the right flywheel and clutch. :?
Is it possible to cut down the diamter of the 1.8 flywheel and use the standard 1.3 bell housing?
And in this case will the J18A clutch will fit to the modified 1.8 flywheel?
Or do i have to drill 8 holes to accomidate the Jseries 8 bolt crank pattern in the G13b flywheel?
Which G13 clutch will not slip in the samurai bell housing.
Regards
