It is currently Sat Oct 21, 2017 11:23 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3
Yes 11%  11%  [ 19 ]
No 71%  71%  [ 125 ]
Total votes : 175
PostPosted: Mon Feb 22, 2010 10:26 pm
SO what is the consensus on replacing the stock air filter with a K&N. Or is it just better to replace the stock filter more frequently or blow it out and replace?
Stock filter approx $12 Last about 30K
K&N filter Charger $48 Last Over 100K+
PostPosted: Tue Feb 23, 2010 5:25 am
K&N costs more, lasts forever, flows better, sounds better, doesn't filter as well. Tough decision as the long engine life you need to make your filter investment pay off, may be compromised by the added dirt going in. Personally, I don't think dirt going in the intake is going to have much effect, but that's just my gut feeling, based upon nothing. Then again, the exact same intake and filter feed the four cylinder version of the G engine just fine, I would think they're more than adequate for the G10, so the better flow is going to be less evident.
PostPosted: Fri Feb 26, 2010 5:59 am
I have tried many things to improve MPG but none worked better than the following in that order :
1. Light foot on the pedal, try to drive in higher gears.
2. Correct tire pressure
3. Clean spark plugs
4. Right engine and tranny oil change intervals depending on type of usage
5. Clean contacts of all ignition related components - cables, distributor, rotor etc etc
6. No excess baggage
7. Water injection in IM to clean the carbon
8. Adding 10 ml motorcycle 2T oil in 40 litres of Petrol (Does wonders to smoothness with zero side effects)
9. Finely powdered graphite (ordinary pencil lead) mixed with grease - applied to all ends of ingition cables before fixing.
Other things that aided me in achieving optimum fuel economy are :
1. Using an air filter with a larger surface area >>> less restriction
2. Blow cleaning filter every 2/3 weeks
3. Larger (dia & length) intake tube and ported and polished throttle body
4. Removed CAT
5. Replacing stock silencer with a less restriction type from an Opal 1.6 L
RESULTS :
I was getting 10 kilometers to a litre of petrol earlier but now I am getting 14 (40% improvement) in city driving conditions and 23-24 kilometer to a litre on a highway.
The things that I tried and havent helped much in the long run are - side gapped plugs, IAT sensor mod, acetone in fuel, boric acid in engine oil, injector cleaner (they screw my spark plugs), tornado in intake tube, magnets etc.
Havent tried fuel cells, octane boosters and do not intend to.
That translates in MPG City 24 MPG to 33 MPG
and 56 MPG on highway.
PostPosted: Fri Feb 26, 2010 9:46 pm
i use injector cleaner on occasion,dont think it really works,just makes you feel better...???my wife was up late one night watching tv,saw a infomercial on that product called "Z-MAXX",told me it was awesome,i dont believe the hype,bought it after many weeks of her nagging,used the product as outlined,saw no change in performance,gas mileage or engine wear....."soaks into metal" more like "soaks money from wallet" LOL!! but i guess if CAROL SHELBY endorses it,it must be good,right guys? yeah,right!regular maintenance works for me!!
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sat Feb 27, 2010 1:18 am
i was always wondering about the zmax.
my brother got me a can of some stuff, i can't remember what its was called
looks like a pop can, you pour it in your 710 cap, and the engine idles and revs a lot smoother, its really thick, i think that the key ingredient
08 Civic Wife's car
PostPosted: Fri Jun 18, 2010 1:45 am
I read a few lines and quickly scanned down to reply...you are quite gullible and no one should pay any attention to your advice.
Sam Dabbs wrote:
Nowhere wrote:
Electric turbo/superchargers
Fuel Magnets
Tornado/spiralmax
Uli,
it.
John
Fuel: Unleaded petrol
ambient temp: 19.5 deg C
Rel. humidity: 80%
Uli Xxxxxx
Right ON dude!!
Sam
PostPosted: Fri Jun 18, 2010 1:47 am
owlafaye wrote:
I read a few lines and quickly scanned down to reply...you are quite gullible and no one should pay any attention to your advice. This is a reply to NoWhere...who is certainly nowhere
Fuel Magnets
Tornado/spiralmax
Uli,
it.
John
Rel. humidity: 80%
Uli Xxxxxx
Right ON dude!!
Sam
PostPosted: Fri Jul 09, 2010 6:37 am
Well it works for his pocket book, Gotta have that retirement income.
PostPosted: Tue Jul 13, 2010 1:29 am
:twisted: @ Ralph, scammers will get richer as they are smarter and know that there are enough fools out there to buy and try their snake oils.
PostPosted: Tue Jul 13, 2010 5:04 am
Yep, it pisses me of daily. Oh well, I'm not contributing to their funds, Good enough for me.
PostPosted: Wed Apr 13, 2011 11:08 pm
Have used xylene and tolulene to boost 92 octane to 107. Ran advance from max 25 BTDC to 41. More power, same fuel economy. In 55 gal barrels price was about $.50 per gallon higher than pump gas. Can't remember the mix ratio.
PostPosted: Mon Jan 23, 2012 4:58 pm
the advice he gives fitsandy knew several of them are good some not, should be tried and try to save more gas
luis013
 Post subject: Re:
PostPosted: Wed Feb 11, 2015 11:34 am
Kento87 wrote:
V8's
i actually got really good gas mileage in my 1986 firebird. 305 5 speed. 270k kms. 400k to a tank on the highway with the t tops off. woukd have gottn better if the engine was rebuilt and the tranny actually had a mount lol
 Post subject: Re: Re:
PostPosted: Wed Feb 11, 2015 4:00 pm
95pontiacfirefly wrote:
Kento87 wrote:
V8's
and I got 700k in my Suburban but it cost $180 to fill it :roll: .
