It is currently Thu Oct 19, 2017 9:47 pm
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
PostPosted: Mon Jun 28, 2010 4:08 pm
I've been busy.
And now for something completely different.
I put a dent in the vans right front fender. It's welded on. :(
So I got one off a 96 at the "you pull it".
image_id: 19030
Not a perfect fit. But good enough.
One problem I had with the van is, I can't put a 4x12' piece of Sheetrock in it and close the door. It's long enough, but the floor kicks up at the front seats.
image_id: 19031
So I cut out the floor. :alien:
image_id: 19034
And lowered the support.
image_id: 19033
Also I extended the floor almost to the door.
That's not all.
image_id: 19035
I covered the tent with corrugated plastic. And I just finished making the door go up and down. I'll take photos later.
john :D :D
I'll keep fixing it 'till it doesn't work
PostPosted: Tue Jun 29, 2010 3:32 pm
Here is where the door is now.
image_id: 19036
I narrowed the door two panels. And shortened the top panel.
image_id: 19037
The curved track had too big of a radius, so I cut 8 slots in it and welded it back together. Then it fit.
This door had a spring on a shaft over the door. The spring was way too strong. I kept the shaft and drums to wined the cables. Then I made a drum to wined a cable connected to an extension spring.
image_id: 19038
This photo shows the drum and extension spring.
image_id: 19039
Because the shed is made from a canvas carport, I made a support to tie the extension spring to the shaft mount and the garage header.
image_id: 19040
This doesn't look pretty, but it should keep the extension spring from folding up the shed.
john :D :D
PostPosted: Thu Jul 01, 2010 11:04 am
image_id: 19137
Still working on the van.
image_id: 19138
Extending the cab area as far as I can.
So, what do you think.
john :D :D
PostPosted: Thu Jul 15, 2010 5:36 pm
image_id: 19139
image_id: 19140
image_id: 19141
image_id: 19142
image_id: 19143
image_id: 19144
image_id: 19145
image_id: 19146
image_id: 19148
image_id: 19149
image_id: 19150
Got to get it done.
john :D :D
PostPosted: Mon Aug 23, 2010 2:49 pm
More van pictures.
image_id: 19254
Painted the heater cover white so it would show in the pictures.
image_id: 19255
Cut out part of the drivers fender to convert to 1996 headlights.
image_id: 19256
When I cut the fender, it moved down a little. So I put this block on it and jacked it into place. Worked good.
image_id: 19257
This is it all welded up. Just need to grind it, and paint it.
image_id: 19258
Put the heater blower in.
image_id: 19259
And the radiator overflow tank.
image_id: 19260
I'm using the later hood prop. I've clobbered myself to maney times with the scissors type that is used in 1974.
image_id: 19261
Put the interior release hood lock in.
image_id: 19262
The passenger side foot well. You can see the radiator overflow tank.
image_id: 19263
Got to fix the dash.
john :D :D
Finished the heater.
image_id: 19509
image_id: 19510
I painted it all black after I took this picture. Black doesn't show up good in pictures.
image_id: 19511
Like my plumbing defroster setup?
john :D
PostPosted: Sun Aug 29, 2010 10:04 pm
looking forward to our regularly scheduled program :-P
PostPosted: Thu Sep 09, 2010 5:39 pm
OK!,OK!
Let's see I cleaned up the tent enough to roll the three wheeler in to it.
first time it's moved in a year.
The tent is supposed to be dry. It's not. :thwack: :thwack:
Another thing to add to the list.
Anyway worked on the three wheeler.
Made this pressure vessel to pre-oil the engine. Its 4" ABS drain pipe. I filled the oiling system with this.
I cranked the engine over until I got pressure. Good pressure too.
This was my clamped together setup.
Last night I hooked power to the ignition and checked for spark. I got spark! Image
Then I hooked up a small gas tank and cranked it over.
It popped and farted, and was blowing flames out of the exhaust.
So I though "the timing is off. How do I change the timing?"
Then I remembered way back to high school automotive class, when some guy put the distributor in 180 off. It acted just like that. Hmm, I swapped the connectors to the coils and tried again.
IT STARTED!!! ImageImageImageImageImage
Now I gotta put in the radiator.
john :D :D :D
PostPosted: Thu Sep 09, 2010 9:50 pm
way to go !!!!
quick, get it up and driveable
so we can see more pics befor the snow flies
i'll bet most folks have forgotten what the little fellow looks like :-P
PostPosted: Tue Sep 14, 2010 3:46 pm
Took it to the work car show.
Ready to go.
Had to move a lot of cr... uh stuff.
I made an oval air cleaner.
Some guys where really interested in it.
Radiator just hanging there for now.
I like the flip front. It gets out of the way.
There it is in all its glory.
Oh yeah, I got it to idle really well. Sounded cool.
john :D :D
PS Questions? Comments?
PostPosted: Fri Sep 17, 2010 6:50 pm
Little car is surprised to see you.
A trip around the little beasty.
What the heck?
john
PostPosted: Fri Oct 08, 2010 6:42 pm
So the thing doesn't run smoothly. I checked the coils and they don't seem to hot.
This is one of them.
I popped off the valve covers.
And modified them to...
Bolt on Toyota coil thingies.
It runs a little better,but I think I'll have to take the carbs off again, and go through them again.
Now to the exhaust. It is too loud for me.
On my crappy set of extra down tubes, I cut off the adapters. Look how rusty this one is.
These have an inner and outer pipe. They where full of rust between them.
I machined the adapters and made adapters for the adapters. That makes sense, :-P
The parts with the holes in the side are the Honda parts. The others are the ones I made.
This is how they go together. One set is backwards. They get plug welded and and welded where the taper is on the inner piece.
Wouldn't you know I welded them both backwards. :thwack: :thwack: :thwack:
Lucky for me I noticed before I welded the taper. So I drilled out the plug weld, turned the parts around and re-welded them.
john :?
PostPosted: Mon Oct 11, 2010 10:38 pm
Ha.... old man honda put the whodo on you for bastardizing his design perfection :-P
cut, weld, recut, reweld....turn more air blue :evil:
bet the problem is with the carbs, ..whats it doing?
PostPosted: Tue Oct 12, 2010 2:27 pm
It pops and snorts, and runs on one cylinder or the other, or both.
john :huh:
PostPosted: Tue Oct 12, 2010 3:50 pm
That type of CV carb is notoriously difficult to set up without the stock airbox. Do you have them correctly balanced?
PostPosted: Tue Oct 12, 2010 4:15 pm
Nope. I need to find a tac that will let me set the idle speed at 1100 rpm +- 100 rpm.
Where do I finde one of those?
john
PostPosted: Sun Oct 17, 2010 10:09 pm
what happened to the rest of the 500
can't you use the instrumentation from it ?
what year is the motor from and i think i asked before
do you have a FACTORY manual for that 500 series ?
PostPosted: Mon Oct 18, 2010 12:31 pm
Let's see, I never had the whole bike, just the frame and back wheel.
I did get a tac and speedo, but the manual says it's not accurate enough.
The motor is from a Silver wing ~82.
I have the Claymer manual. It has a supplement for my motor.
I won a electronic tac on ebay, so once it shows up I can sink the carbs.
john :D
PostPosted: Mon Oct 18, 2010 6:39 pm
i have the honda FACTORY manual 1976 - 82
if you get stuck, give a yell
really, ditch that clymer crap... its better than nothing
but like most it falls short on the critical stuff
PostPosted: Tue Oct 19, 2010 3:50 pm
Thanks, I'm fixing the shed roof because it leaked.
When I'm done I'll get back to doing the exhaust.
Once that's done I'll get back to the carbs.
John :D :D
PostPosted: Fri Feb 04, 2011 5:29 pm
Hi, It's been a wile.
Let's see, I rebuilt the garage roof, now it doesn't leak.
I've been working on the exhaust, but not getting much done.
Also I took the carbs off. One had the idle adjust needle broken off. And the rubber plug in the float bole where disintegrating
I'm re-cleaning the carbs and modifying them.
I'll get pictures.
john
PostPosted: Tue Feb 08, 2011 10:42 pm
subscribing............
PostPosted: Wed Feb 09, 2011 10:31 am
Paul Jr.
You must get a serious kick out of the 6 or 7 guys at a time scratchin their heads around your car lol. I know I would for sure! :lol:
Great work :thumb2:
PostPosted: Wed Feb 16, 2011 9:27 pm
yes, yes, pictures soonest and working runningear... cheers 8)
PostPosted: Fri Feb 18, 2011 4:34 pm
Started working on the drive shaft.
I'm using a Honda CX-500 frame, a Honda Silverwing swing-arm, and a Honda CB-900c final drive.
So I have to sort out the drive shaft.
Here it is with the wheel and final drive out.
In this photo, on top is a Silverwing drive shaft.
I the middle is one off a CX-500.
On the bottom is a CB-900c drive shaft.
You can see they are all different lengths.
The splines are not the same between the CX and the CB.
The coupling on the CB-900c is held on with a c-clip, and is way down in the stupid thing and is hard to get out.
Of course I got it out :mrgreen: and turned the splines off.
The coupling on the CX-500 is held on with a roll pin. That was easy :alien: The blue tape is where I cut it so I could mate it to the CB-900c coupling.
Another view of the machined CB-900c coupling.
I cut a CX-500 shaft to use as a concentric holder for the CX-500 coupling.
Then I machined the inside and outside of the coupling and pressed in a plug.
Then I made a sleeve.
Welded it on the CX-500 coupling.
Then took it home, assembled the parts measured what the length of the new coupling should be.
On the bottom is the new drive shaft. It's the longest of all.
The only problem is, it won't fit through the swing-arm assembled.
No problem, just cut a hole :lol:
And assemble it in the swing-arm.
The final drive fits and the splines line up, but the drive shaft was hanging up on the roll pin bosses.
And to get the roll pin out I had to drill a hole on the other side of the swing-arm.
john :D :D
PostPosted: Fri Mar 11, 2011 4:57 pm
I want to know how fast I'm going, so I'm putting the speedometer drive on the back wheel.
Parts from left to right.
Wheel bearing retainer/seal holder, Spacer, Speedometer dog, Speedometer drive gear, Speedometer drive housing and worm gear.
Speedometer drive assembled onto rear wheel and axle.
Speedometer drive, caliper bracket, wheel, and final drive (not in picture) on swing-arm to figure out spacer thickness.
I welded two caliper brackets together, so I can make a hydraulic emergency brake, as the go kart parking brake didn't seem to work.
Now to put it back together.
john :D :D
