It is currently Thu Oct 19, 2017 2:25 am
PostPosted: Mon Jul 19, 2010 9:41 pm
This review is for the rubber and felt pieces which fit the doors on the MK1 Chevrolet Sprint style cars.
World Class Rubber Profiles is one of the last manufacturers of OEM style replacement door rubbers, gaskets, window channel, fuzzies, molding, or whatever you want to call it.
With shipping charges I obtained a set of such material and it added to roughly $200. This should be enough to complete one of our 4 door vehicles.
Here we go.
One of the problems with owning an older vehicle is that the sun will shrink the rubber over time. Here is a close up of the problem:
as you can see, the rubber no longer reaches to the length originally intended, allowing air to enter the passenger compartment.
New extruded door gaskets are the definitive fix.
Here is a sample door
to show the application. Now if you look at the series of circles, you will notice one large circle:
in the upper right which is the molded angle corresponding to the necessary curve in the door.
The smaller circles show the OEM style plastic push pins which match perfectly the holes in the door.
Last, notice the red circle. It indicates a pre-cut area of the extrusion which corresponds to this area of the gasket:
Here is a close up of the specific area:
You will need to transfer your old plastic trim piece from the old gasket. That is the only part you reuse.
I will give an update on the quality of the ride once all the pieces have been installed. At this point, I can state that the pieces that World Class Rubber Profiles produces are in every way identical to the pieces I've witnessed here on our particular cars, including all the necessary angles and ribs. This product should receive a 5 star rating or an A+++. I would expect that upon installation, the car would again be quiet at high speeds.
PostPosted: Tue Jul 20, 2010 1:43 am
Very impressive! Looks great, the install looks simple, now the important question; how do I get a set for my mk1 turbo? Any contact info for the company?
This obviously took a lot of digging and patience to find, kudos on the detective work!
1987 Sprint Turbo - under construction!
PostPosted: Thu Jul 29, 2010 12:23 am
+ 1 on that, searched for World Class Rubber Profiles but couldn't find it.
PostPosted: Fri Jan 07, 2011 2:05 am
hi there im new here... i'll just ask anyone here have experience using Window & Windshield Weatherstripping parts and accessories? i've check their products and i dont have idea if they are good quality product... Thanks
:vibe: :buzz: :vibe: :buzz: :vibe: :buzz: :vibe: :buzz: :vibe: :buzz:
PostPosted: Tue Jan 11, 2011 3:20 am
Spam from JC Whitney? :huh:
PostPosted: Thu Feb 17, 2011 10:07 pm
Is this company still around? Did a google search but no hits. Have some contact info? Recently got my 87 Sprint turbo on the road and my seals look like the ones in the photos. Drafty, noisy at speed. Also need now window channel.
Any leads appreciated.
1996 Geo Metro Hatchback, 1.0, 5 speed, w/air
1992 Suzuki Swift GT, 5 speed w/air
1987 BMW K-75
!976 BMW R90/6
PostPosted: Thu Feb 17, 2011 11:57 pm
I haven't received a reply on the 4 door rubber as yet.
mxmikie says there is an easy part interchange for the two door so that you can order new easily.
