It is currently Thu Oct 19, 2017 4:10 pm
 Post subject: Ebay Suppliers
PostPosted: Fri May 27, 2011 7:00 pm
Senior Member
I think we need to start a thread on best suppliers of spare parts from Ebay. I am going to kick it off.
Mods, perhaps a separate place for these under Parts & Supplies.
Here's a starter.
Timing belt kit complete with tensioner and water pump.
http://stores.ebay.com/CNSAutoParts?_rdc=1
Sparkplug leads and ngk plugs
http://stores.ebay.com/autodinamics?_rdc=1
Gasket sets
http://stores.ebay.com/Mizumo-Auto-Parts?_rdc=1
Stainless brake lines
http://stores.ebay.com/Silverstone-Modification-N-Racing?_rdc=1
 Post subject: Re: Ebay Suppliers
PostPosted: Fri May 27, 2011 9:31 pm
I just had a bad run of head gasket from CNS off ebay selling Eristic Brand. As a seller they seem really good, genuine concern and full refund of unused sets offered when i talked to them. So zero complaints about service just be aware that they seem to be risky gaskets. How risky? 7 failed g13's, 1 g10(g10's were by far the best, only one failure, many built 20+), 1 g16, 1 honda d15. Let em tell you that was a lot of damage control and warranty work to do! All felpro gaskets used the second time around, not one comeback. This was in a 6month time span.
They consistently make it about 5000kms or a couple months, give or take.
PostPosted: Fri May 27, 2011 9:57 pm
NTK Brand (NGK Company) Oxygen Sensors:
Gear Head Parts Stores (Ohio)
Ebay price for NTK #21002 = $15.61 shipped.
Sample Link:
http://cgi.ebay.com/NGK-21002-Oxygen-Se ... 20b7826b56
These are OEM parts, new in the box at a very competitive price.
PostPosted: Wed Jun 22, 2011 9:06 pm
http://cgi.ebay.com/ebaymotors/1989-1994-SUZUKI-SWIFT-GTI-Stainless-SS-Brake-Lines-F-R-_W0QQcmdZViewItemQQhashZitem415a823b58QQitemZ280691358552QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Has anyone tried these?
Thanks Chris
'00 Integra Type R 96k miles I/H/E p/s & a/c delete ITRawrr ~ Because Racecar
Down to one car and no suzuki's :(. Maybe I will get a gixxor :)
PostPosted: Mon Jun 27, 2011 3:38 pm
I've got a set of those lines on my car, no problems. I think I offered $40 and they took it :D
