It is currently Thu Jan 18, 2018 5:17 pm
PostPosted: Tue May 10, 2011 11:52 pm
Car: 1987 Chevrolet Sprint 1.0L, naturally aspirated.
-California Air Resources Board (CARB) catalytic converter (Magnaflow)
-New MCS in carburetor
-Timing at 9 before TDC
-no vacuum leaks
-fairly low compression:
even so, she blew pretty clean.
viewtopic.php?p=372368#p372368
This car was not in a special 'test only' category, but like the man said, these tests seem to be 'coming soon to a theater near you'. Using your home tools, some careful thought, and some luck, you can pass any test they throw at you!
It blew lower than average in all but the low RPM HC.
CO was 0.00/0.01 (low RPM/hi RPM)
NO was 108/42
Tech who ran the car was pretty impressed with how clean it blew.
PostPosted: Mon May 16, 2011 6:37 pm
The car above had an ignitor which was going out.
(It had a little hesitation at a certain rpm and on hard acceleration not cured by a new MCS.)
But it still passed the smog test. Since the new ignitor was installed, it runs much smoother.
Now let's test a DOHC:
Today, this one blew about the same as the three cylinder above (HC 84/42 vs 99/57)
and the NOx is about the same.
It has a brand new CARB compliant cat, just like the one above.
Try using one of these:
to check the CO coming out the exhaust before you run it down to the smog shop.
PostPosted: Fri Jul 22, 2011 7:35 pm
Here's another one.
'94 Swift GA
t3 ragtop wants this shell, as it's rust free.
Compression in 2007 wasn't the greatest:
and it is due for a rebuild.
(gutless wonder; doesn't use much oil though)
Taking a page out of wizewun's book, we installed a Magnaflow CARB compliant cat.
Check out the numbers:
HC is within range, even though the compression is low, but the CO and NOX is WAY BELOW average.
That's it for this year.
No smog tests til this time in 2012.
How low can YOU blow?
8)
PostPosted: Sat Jul 23, 2011 2:08 am
I have 6 cars, but all are emissions exempt. It took some doin' but I got there, and that's where I'll stay.
PostPosted: Sat Jul 23, 2011 12:36 pm
Because they're all 1975 or older, electric or diesel?
Question for all my California brothers - who has the best price on the CARB approved cat?
Thinking of doing a pre-emptive strike and order one for mine now in preparation for when it comes up for smog next March.
- MPGuino
PostPosted: Sat Jul 23, 2011 3:23 pm
Atlantic Muffler.
See what he quotes you over the phone (out the door, he pays the tax, blah blah blah) and PM me.
PostPosted: Fri Jul 29, 2011 3:41 am
yes, newest one is registered as 66 .....for the record anyway. :wink:
PostPosted: Wed Nov 02, 2011 1:20 pm
Since you asked, here's mine. (91 Turbo) I hope I'm not treading on your original thread but my latest AirCare report has me a little concerned. Have not done a compression test yet but a couple of things have changed recently. Not getting that characteristic whoosh sound when upshifting and the revs are pulling back back. Is that the waste gate not doing its thing? I thought the turbo might not be spinning but I could spin it by hand easily when I took off the intake pipe to get at it. Did notice a tiny amount of clean oil in that area though (grrrr!!! rebuild soon?). I wonder if anyone has the time to check my readings and can recognize what's happening. Is my Cat Con toast? Compression/Ring problem? Turbo......? All 3? Starting to look for parts again. Another learning experience coming for sure. Thanks anyone..... This part >> I just added after some people commented on my spread sheet. This is just me copying all my AirCare reports over the years and tabulating them in one chart so you can see the worsening trend. With the hood open and me just blipping the throttle, should I be able to see the waste gate vacuum plunger opening the waste gate....or does it have to be under load? As always, eternally grateful to those whose experience and expertise are light years ahead of my own. And BTW, I think this testing process is a bit haphazard as evidenced by the irregular NOx readings (25, 1, 0 then back up again). But I am only concerned about the big jump this year - NOx going from 51 to 813...!?! WTF?? OK, I'll shut up now.
If it was made by a human or robot, it can be fixed by a human.....but maybe a lot slower with a few missteps and wrongly ordered parts.
PostPosted: Wed Nov 02, 2011 2:05 pm
That's exactly why I started this thread.
Check out #4 and #11 here:
http://www.ratwell.com/mirror/interro/techgas.html
Nice 6 year overview of your engine!
California, we only get the current test results, however we can go online and look at our records
(most people don't know how) :oops: , or ask the tech who has the records in front of him when he does the testing.
Edited to add:
Here's another good link since you failed HC:
http://www.autohausaz.com/html/emission ... nsors.html
Also, you can check the catalytic converter using a laser type thermometer.
There are several you tube videos about the technique.
The more test results we post-no matter what Country, the better the database will become.
PostPosted: Wed Nov 02, 2011 4:23 pm
may have to try and get one of those exhaust testers. my dad owns a 1991 GMC rally stx, 350ci, that fails aircare every single year. he deserves to waste his money getting it fixed at a shop.
PostPosted: Sun Sep 30, 2012 3:03 pm
Vehicle: 1986 Suzuki Samurai, 1.3l 4cyl with Hitachi DFB306 carburettor.
MY first try. I failed due to the vacuum check valve missing on the vacuum line going from the TCAC thermostatic control to the intake manifold.
I replaced the check valve and returned promply.
The only things I could see causing these emissions is the original 26 year old MCS and an EGR valve that has a minor leak. Otherwise, I welcome your criticism.
1986 Suzuki Samurai - in the works
PostPosted: Sun Sep 30, 2012 4:14 pm
Thanks for adding to our database with your 1.3L '86 Samurai test results.
Not bad for a 26 year old vehicle!
How old is the cat?
PostPosted: Sun Sep 30, 2012 9:47 pm
The catalytic converter is probably original. When I had the exhaust apart the back end of it looked clean and white. I could not see the front end at the time. By now you probably all noticed the 108ppm HC on my first 15mph run. I cringed when I saw that the max was 108ppm for HCs. :shock: fortunately it did better on the second run. 8)
PostPosted: Wed Mar 06, 2013 11:16 am
Retest of first vehicle in thread (two years later):
-new NGK V Power GR5's gapped at .040
-new air filter
-new Catrol 'Edge' 5W-30
-CARB cat now 2 years old
Other notables:
-car not driven hard til warmed up
-synthetic and new filters changed regularly
-stock engine, high speed final drive set (3.79s)
...thank you Teamswift :lol:
PostPosted: Thu Mar 07, 2013 3:43 pm
Correction on above: NGK plugs were gapped at .045... :oops:
PostPosted: Tue Apr 02, 2013 10:26 pm
2013/14 Smog Test Results
PostPosted: Wed Apr 17, 2013 5:35 pm
Old post, but seems fun. Amazing how clean a +20 year old car can burn. For what I know, it's all factory.
PostPosted: Sun Sep 21, 2014 10:59 am
@ssclown
I don't do emissions tests. I give the pieces of shit at ICBC an address just outside the mandatory emissions testing zone and I register my vehicles in other peoples' names. Mandatory Government Emissions Testing ends forever in British Columbia on December 31, 2014 anyway.
PostPosted: Sat May 09, 2015 5:15 pm
'87 Chevy Sprint NA
Stock 4 door
HC measured 9 and 2 ppm (107/89 allowed)
CO measured 0.0 and 0.02 (.64 and .56 allowed)
NOx measured 562/419 (906/845 allowed).
First number is the low speed result; second number is the high speed result.
This engine is going on 10 years since last refresh.
The oil is very clean and there is little consumption between changes.
5W-30 Mobil 1 EP
Catalytic converter? CARB compliant CAT about 4 years old.
This smog test result tells me it is time to roll up my sleeves and get busy with the emissions equipment.
That EGR valve and/or its passages are probably getting clogged, or it could be the EGR modulator.
Maybe the carburetor is in need of a rebuild.
Still, in 15 years of driving the car, I am not complaining.
I don't know who has bad luck with Suzuki cars, but not me.
Odd ball items have occurred come to think of it:
-alternator went out in Oregon
-float valve stuck about 10 miles from home a few months ago...I didn't even bother to rebuild the carb. I just fixed the float valve. :lol:
People who post threads trashing Swifts, Metros, and Sprints probably approach their cars with a different attitude.
Or they don't know how to properly work on their cars.
You pay someone to do your dirty work and you may get screwed.
It isn't anything fancy to look at,
but it gets the down the road just fine, thank you.
I'm not sure how fast it goes, but I did run the needle over to where the 7 or 8 o'clock position is once or twice.
Cops?
They don't even give me a second look.
There are too many high end cars on the road begging for a speeding ticket; why stop a Sprint?
Ha!
I'll admit I was a bit lax before taking it in for the 2015 smog test.
Next time I run it through the State's dyno/sniffer, hopefully that NOx will be down, down, down, to Chinatown.
Clean the EGR and put a new oxygen sensor on it.
Meanwhile, it's still clicking off decent mileage - 44+mpg on the last tank, and you can see I DON'T drive 55.
:twisted:
Smog tests don't scare me.
They used to.
If you know what you're doing and understand the fundamentals, you can get your cars to pass a smog test.
If your car burns clean, you'll see it when they sniff your tailpipe.
And this vehicle is OBD I - more difficult to maintain than the OBD II's.
My friends outside California?
They get REAL NERVOUS when I innocently offer to pay for them to run their car through a smog test station out here.
If they're great mechanics, these California smog tests will show how great they've brought their car into specs.
BTW: I'm talking about daily drivers, NOT vehicles modified for another purpose.
:mrgreen:
Who's afraid of the big bad smog???
:-P
Bring it on!
PostPosted: Tue Sep 20, 2016 1:08 pm
I'm worried that California will confiscate my vehicle after yesterday's smog test.
It's almost an electric car type result!
Here's the vehicle:
93 Geo Metro.
Here's the test:
A few months back I replaced the timing belt.
Over the weekend, a new Magnaflow 332005 converter was installed.
Otherwise, the vehicle is bone stock.
Additionally, I had a new resonator installed because it has been running a straight pipe in that location for a few years - (we couldn't afford one previously).
It has been fed Mobil 1 since the rebuild back in 2007.
No regrets, looking back.
And I'm NOT a big vert fan.
But this car chooses to burn clean as a whistle years into the rebuild and 184,000+ miles on the clock.
Low speed: HC 2 parts per million and nothing in the CO and NOx.
High speed: 0.05 parts per million CO and nothing in the HC and NOx categories.
:shock:
And - engine noise is practically nil at highway speeds.
That's one heck of a catalytic converter.
$200 installed.
How low does your engine blow?
:twisted:
PostPosted: Sun Oct 16, 2016 9:24 am
Hello there!
Is this a place to only post passed smog results, or can I post about failing smog and get some feedback?
Glad this thread exists!
Those low numbers BLOW my mind! =)
PostPosted: Mon May 15, 2017 9:20 pm
2017 Smog results ave arrived
PostPosted: Sun Jun 18, 2017 12:13 pm
A month after wizewun and it looks like his Turbo trounced my NA!
His HC 12 vs. my 24 at low speed is significant. His high speed HC 6 vs. my 9 doesn't make me feel as bad, but the State of California smog sniffer told me what I suspected:
even though the car runs smoothly, there is room for improvement and an obsessive compulsive mechanic/technician would swap in a fresh carburetor.
HC is the unspent/unburned gasoline coming out the tailpipe. If I can get that down, it should translate to better fuel economy.
Most people use the dollar sign to dictate what to do: if I put a rebuilt carburetor on the engine, how long will it take to pay for itself?
Let's estimate a rebuilt carburetor would increase my mileage by 5 miles per gallon.
Using 10 cents a mile as a normal ballpark operating figure, a 6 gallon fill up would net a savings of about $3 per tank.
To get $300 in savings, I'd have to drive a good 100 tanks.
Figure 300 miles per tank times 100 tanks, that's 30,000 miles to break even (if I paid $300 for a rebuilt carburetor).
Now you see why the majority of the NA versions were driven into the ground.
People were less concerned about fuel economy, and would only change carburetors if they caused severe driveability issues.
Continuing with the test results:
His CO .01 vs my .03 at low speed is almost the same. High speed we again almost tie: his - .00 mine - .01.....very close.
Carbon monoxide is low on both cars, so we almost tie.
Last the NOx, which is the bane of many a DIY enthusiast.
His Nox 117 vs my 266 at low speed probably signifies my cat is getting old. The high speed results of (him) 4 vs. (me) 79 are quite significant.
Probably my catalytic converter has been working longer than his, has processed more exhaust, and may be losing its original efficiency.
(Like me, ha!)
To be fair, with test results like that, both catalytic converters work fine, and do not need to be changed.
You could conclude that my car's cat has lost 30% of its efficiency.
Thus, looking at a smog test result when purchasing a car can tell you if you will need to buy a catalytic converter.
Smog test results are also an impartial 'third party' way of finding out the overall condition of your powerplant.
You would think the more powerful Turbo would burn dirtier than the humble NA, but you can see from the above results that although both burn pretty darn clean, a turbocharged engine can indeed outperform a carbureted version both on the street and in the laboratory.
Wizewun, thanks for doing such a great job under the hood, and congratulations for winning this round!
:worship: :worship: :worship:
Before I run this car through smog again, it would indeed be wise to slap a rebuilt carburetor on it.
