It is currently Sun Feb 25, 2018 1:37 pm
 Post subject: is this a stock '98 ?
PostPosted: Mon Nov 28, 2011 2:18 pm
I recently bought a '98... and it seems way more zippy than a '97 I bought a couple years ago (and converted to full-electric). I will be selling this engine soon, and would like to know if it is stock, or probably a swap or replacement. ODO reads 204k miles, and this thing seems to have lots of life left, so maybe someone will want it....
111128_ICE_motor3.jpg [51.81 KIB]
Downloaded 602 times
so, what's your guess? is this a '98, or likely a transplant from something else?
111128_ICE_motor1.jpg [102.43 KIB]
111128_ICE_motor2.jpg [112.03 KIB]
Dan
'97 Swift, converted to Electric - www.envirokarma.org
PostPosted: Mon Nov 28, 2011 3:29 pm
looks stock to me. check with your local dealer for certaintly. give them your vin and they will give you the info you seek
PostPosted: Mon Nov 28, 2011 3:42 pm
Other than the air filter....yes
Why sell engine? If to do a conversion please find a 97
PostPosted: Mon Nov 28, 2011 4:32 pm
cool, it might have some resale value then. The 1.6L is certainly better than the older one I have driven w/ the 1.3L ;)
I bought the car for fairly cheap because the interior is in great shape and no dents. paint is not good so I'll have to either paint or do a vinyl wrap. Swifts make great electric cars... small, light, still fit 4 adults plus 'stuff' around town.
I have the whole process documented at envirokarma.org
Dan
PostPosted: Mon Nov 28, 2011 5:11 pm
that should be a sohc 16 valve g13 1.3 liter engine. if it's a 1.6 liter engine then it is probably a transplant. the 1.6 was in the tracker/ sidekick and looks pretty much the same.
look for the "g13" cast cast into the front, flywheel end of the block just under the head.
PostPosted: Mon Nov 28, 2011 7:12 pm
ahhh, ok. I will take a look.
Dan
PostPosted: Mon Nov 28, 2011 8:48 pm
Yeah I doubt its a 1.6
Its not exactly a bolt in swap. But yes the sohc 16v g13 does run pretty good.
PostPosted: Mon Nov 28, 2011 11:51 pm
yes it is. the 00-01 had coil packs right on the cylinder head (for #2 and #4), 98-99 had something half-way in between.
Users browsing this forum: Google [Bot] and 3 guests
