It is currently Thu Oct 19, 2017 6:33 am
PostPosted: Wed Apr 11, 2012 8:48 pm
hi, i have just become a club member, im also a menber of a similar club in argentina and i´m contacting you because i´m in the need of a new carburetor for my 1991 Suzuki swft glx. many people in my country are in trouble with this carburetor beacuse it is very rare and expensive to repair, find and buy. it is for the model G16a , AH-14s and the engine is sf-416. corresponding to the european version of the swift i believe. so i was wondering if you could help me with this problem by telling me if there is a webpage where i can buy it and import it to argentina or if you could lead me to somebody who can find that carburetor in the usa and i´ll find a way to bring it here. thank you very much and sorry for becoming a member without being able to get to know you personally. Regards, Agustín
here are some pictures of the model i have (this one corresponds to 1993):
http://www.google.com.ar/imgres?q=suzuk ... 0,s:0,i:77
http://www.google.com.ar/imgres?q=suzuk ... 6,s:0,i:90
this is the webpage of the argentinian swift club if anyone wants to check it out: (it´s in spanish)
http://www.foroswift.com.ar/
PostPosted: Mon Nov 05, 2012 9:31 am
I know this was a while back but there is someone in the uk breaking one of these. I may be able to get the carb for you/ put you in touch with the guy.
Just out of interest, what was wrong with the carb?
PostPosted: Mon Nov 05, 2012 1:01 pm
i´ve already fixed the carb, thanks anyway :mrgreen: it was just too old and nobody knew how to fix it the right way, luckily i found a place where they could find all the pieces needed and make a complete repair. it was just too tired too work the right way, when it was cold it wouldnt start and before being repaired it injected too much fuel.... now its working perfectly... :D
PostPosted: Sat Nov 10, 2012 8:03 am
I suggest you save this to your hdd ( most of it is a list of mitsubishi engines etc but nearer the bottom of the pdf there is a lot of info reg our carb. )
http://www.mitsubishi-motors.kiev.ua/Manuals/Engine/pwee9007/13B.pdf ( Ignore the mechanical fuel pump though, ours is electric )
