It is currently Wed Oct 18, 2017 7:03 pm
PostPosted: Wed Mar 06, 2013 9:31 am
Somebody is selling these Gti forged pistons for a really good price... don't know anything about compression yet. Can you see the little holes on top? The sellers says there are still "usable"... what do guys think about this?
edit: they are 75mm
525417_10151368753302968_555379979_n.jpg [74.35 KIB]
Not downloaded yet
image_id: 22616
1993 Swift Gti
PostPosted: Wed Mar 06, 2013 10:04 am
Yup. They still look good
For scrap metal.
PostPosted: Wed Mar 06, 2013 11:27 am
For scrap metal.
:goodpost:
Sometimes a deal which seems 'too good to be true' is indeed, not worth your time or effort.
If you are going to build, consider using new pistons.
PostPosted: Wed Mar 06, 2013 12:10 pm
edit: they are 75mm
That should have been your first (and only) warning, mate.
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Wed Mar 06, 2013 4:21 pm
haha just wanted to double-check with you guys... the seller even just admitted his engine went too lean under boost, causing that damage. It is too good to be true indeed... $40 for the pistons with con-rods :shock:
image_id: 22616
1993 Swift Gti
PostPosted: Fri Mar 08, 2013 12:19 pm
Unless those rods are original suzuki sport ones, or aftermarket forged, there's no deal there.
~the other Ralph~
PostPosted: Thu Mar 14, 2013 5:58 pm
that's the classic sign of out of control pre-ignition. all those pits are where the aluminum in the piston crown melted. the little aluminum balls went straight to the spark plug, then fell off and went out through the exhaust valve.
the rods are probably beat to hell, too. :wink:
PostPosted: Thu Mar 14, 2013 6:28 pm
I can imagine the rods were on the same engine as well... too good to be true indeed!
image_id: 22616
1993 Swift Gti
PostPosted: Fri Mar 15, 2013 12:45 pm
shot-peened rods by detonation eh? lol
~the other Ralph~
