It is currently Fri Feb 23, 2018 1:24 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Mar 17, 2007 11:39 pm
hybrid metro wrote:
you just made a direct port fuel injection. dude that is on the new audi r8 and mazdaspeed 3 wagon. it would be easier to turbo the motor now!!!! :twisted: :twisted: :twisted:
Not quite. He's doing MPFI, not GDI.
PostPosted: Sun Mar 18, 2007 12:57 am
a.k.a Bum head
Heh. Beat me to it by just a little bit, Lihtan. :lol:
Chris
PostPosted: Sun Jul 08, 2007 11:18 pm
Any update on this project?
PostPosted: Fri Aug 10, 2007 10:12 am
Whats new??? :D :D
http://www.ftwclans.com
http://www.4deuce.com
PostPosted: Fri Aug 10, 2007 10:27 am
abby normal
I am looking at wideband o2 sensors/controllers to make sure the new injectors don't run too lean or rich.
Then a new 2" exhaust will be put on the car. :)
Anybody found a good wideband o2 at reasonable price?
PostPosted: Fri Aug 10, 2007 6:14 pm
Try these guys
http://www.techedge.com.au/
PostPosted: Sat Aug 11, 2007 3:46 pm
abby normal
Thanks Dattman,
Your stuff is in a cardboard box and will be shipped (finally) on monday 8-13 :shock: :oops:
PostPosted: Tue Jan 15, 2008 8:31 pm
odd... i'm the only questioning reply of
update?
since august 07?
need more boost!
PostPosted: Tue Jan 15, 2008 8:34 pm
Hey 87, This thing runnin yet? Are you planning on using the tbi as additional fuel for boost along WITH the port injectors? Seems like there would be enough fuel there for much boost. Also, are you changing your fuel pump to a sprint turbo pump?
Think zuke.
PostPosted: Tue Jan 15, 2008 8:40 pm
i do believe he stated at one point that he is using an 01 swift fuel pump.
read back a little bit... it'll say.
need more boost!
PostPosted: Tue Jan 15, 2008 8:51 pm
damn, missed that.. thanks for the heads up :)
I'll go give it another read over!
Think zuke.
PostPosted: Wed Jan 16, 2008 12:28 am
Hopefully 87t1 doesn't mind me commenting but he has had a few things going on in his private life so he hasn't done much with this project recently, it's on the back burner for a little while but he is going to continue with it as far as I'm aware.
The point of the project is to convert a non turbo head to multi point injection similar to the turbo head, there are few issues apparently with where the injectors spray into the head, no he won't need the original tb injector.
The aim is to see how the relocation of the fuel delivery point effects the hp, torque, engine response and fuel economy by using the same ECU.
PostPosted: Wed Jan 16, 2008 7:34 pm
thanks dattman.
need more boost!
PostPosted: Tue Mar 11, 2008 10:47 pm
Dattman wrote:
I bought a 2A0 unit, works great! If you don't have much coin, get a JAW wideband. I'll be testing one out here in a little bit. :wink:
Corviar Turbo, G10 turbo Inno Mini, Turbo VW bug.....Next?
 Post subject: Re: G10 MPFI
PostPosted: Sun Jun 01, 2008 9:31 pm
I'm looking at doing this mod. I have a lightly modified 1994 G10 with TBI. I hate to ask a stupid question, but...
I can get 1.3 injectors all day long, but how do I hook them up? I assume the three injectors will work, as has been done here. But there's a lot of info still missing here for us wanting to do this.
Any help would be greatly appreciated.
BTW, thanks for the write up,
Bradley
Middle GA
PostPosted: Fri Aug 15, 2008 10:11 pm
As a slightly related note, I've personally done a TBI to MPFI swap on a 1991 Chevrolet Cavalier 2.2L 4 cylinder. Instead of having to fabricate lots of parts, I just got them off of a newer MPFI car. However, I still used the stock TBI computer. At idle the car ran rich. At cruise though it ran great. According to Gtech, the swap increased hp from 92 hp to 108 hp. It also gave the car a wider power band.
In short, it did work and it really woke up that motor so I think it is definately possible for this to work for you. You might just want to get something to pull some fuel out while the car is at idle.
PostPosted: Thu Feb 26, 2009 11:42 am
:bump: :bump: :bump: :bump: :bump:
PostPosted: Mon Mar 16, 2009 9:26 pm
bump: been there, done that as of the last month.
Check it out:
http://geometroforum.com/topic/1269063/1/
It works. It works really, really good. So does the ram air. All the theoretical discussion is crap until you bolt it on and go driving in truly demanding circumstances.
Badbent, you're spot on. The mouth breathers are just making noise. I love your car. I hate my stock HVAC but I can't get myself to carve the hole in the roof (yet.....) It's just a matter of time before I get fed up and join you.....
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Sun Mar 22, 2009 3:09 pm
thinking of doing this conversion the easy way. I know to get any power out of that motor the tbi will be useless. I aim to hit 100 whp when I am done (or more). what about a return line? is that necessary? it probably is in ontario for emissions purposes.
I wanna get a t3 head done up and swap out the computer, hook up the o2's and do up the rail. would I need a new sender? intake manifold? advice in this direction maybe? we all want the same thing.
PostPosted: Sun Aug 23, 2009 1:25 pm
parkaveultra93 wrote:
IVE BEEN TRYING TO FIGURE OUT DIRECT ...
:vibe:
My eyes are bleeding and my head really hurts. Thanks alot.
PostPosted: Sun Aug 23, 2009 11:21 pm
My eyes are bleeding and my head really hurts. Thanks alot.[/quote]
Sad part is my brains runnin even faster than i could type, so half of it got left out, sorry, performance is my thing.
------------Educated Redneck------------
RIP-91 geo metro lsi convertible 1.0 liter 5speed
I TOTALED A 05 EQUINOX WITH IT! HEAD ON!
- 84 K5 Blazer, 12 inches of lift on SS 44's
- DD: 99 F150 4.6L V8 Ext. Cab, Longbox
PostPosted: Tue Oct 27, 2009 7:32 pm
any progress one it yet? have you finished it? what ecu have you used to run it?
PostPosted: Tue Apr 23, 2013 9:10 pm
where did da pics go?? :cry:
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
PostPosted: Tue Apr 23, 2013 9:44 pm
I think t3 ragtop has them.
