It is currently Thu Feb 22, 2018 7:51 pm
PostPosted: Sun Aug 11, 2013 8:22 pm
can someone give me the audio wiring diagram for mk1?
just bought a 1988 forsa turbo and here's what the radio slot looks like:
also do I have to remove dash to take the front speakers out?
thanks in advance
1992 Geo Metro Convertible (with mk2 g10t)
PostPosted: Wed Aug 21, 2013 4:46 pm
hey pascal,
is that your old blue turbo3 vert on kajiji? :huh:
PostPosted: Fri Aug 30, 2013 8:11 pm
hey pascal,
no it's not my car, mine still sit in the garage like a "garage queen" =)
PostPosted: Fri Aug 30, 2013 8:30 pm
I don't have a diagram but you should be able to pop the covers off and remove the speakers with a very short screwdriver. The white plug facing the camera looks like it's for the speakers. checking the colours at the speaker should verify that. If it's a 4 speaker system the other plug should have a pair of green wires and a pair of (usually purple) other wires. Generally green or grey is left side and white and the other colour is right side. Yellow goes to constant power to hold memory, red to switched power so the deck turns off with the key and black to ground. Blue is power antenna or to trigger an amp. You can wire the yellow and red to the same constant power if you don't mind turning off the deck yourself every time you park the car.
Hope that helps
PostPosted: Sat Aug 31, 2013 12:33 am
LF - orange
LR - lt green
RF - red
RR - gry
ign - wht/blk
bat - wht
Sprint Electical Diagnosis Service Manual Supplement, 8A-150-0
Diagram should be in the technical service section...
PostPosted: Sat Aug 31, 2013 6:40 pm
thanks for all the reply, end up bring it to a shop to get it installed
