It is currently Mon Oct 16, 2017 5:47 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Aug 27, 2013 4:30 pm
:cheers: Got mine!
'91 Vert... Rebuilt 1.0, Clutch, KYB GR2 Shocks, Control Arms, Tie Rods, Motor Mounts, Wheel Bearings, Black Topper, 14" LuxAlloy Wheels, Bad Red Paint
PostPosted: Wed Aug 28, 2013 9:51 pm
Still waiting.
PostPosted: Wed Aug 28, 2013 11:40 pm
me 2 =)
PostPosted: Fri Aug 30, 2013 12:26 pm
Got mine. :P
1993 Suzuki Swift GT bringing back from the dead.
PostPosted: Sat Aug 31, 2013 7:51 pm
got mine on Saturday,but they were most likely here on Friday.looks good,has new mounting bolts .cant wait to install one for the metro,one for the vert,and last but not least one for the turbo.
THANKS!
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sun Sep 01, 2013 12:18 am
Got mine! :razz:
PostPosted: Tue Sep 03, 2013 9:24 pm
The mad quebecer
The mad quebecer
THANKS!
There has been a mistake with the mounting bolts. The gold ones will not fit in there (wrong thread size). contact me if you can't source them locally.
PostPosted: Tue Sep 03, 2013 11:00 pm
what is the proper size of bolt needed? if you could post it here for everyone to know that would be great.
I have a few suppliers of metric hardware in this town,but for some other buyers they may not be that fortunate.
THANKS for the update!
3 tech 6*gear
gti brake swap
PostPosted: Wed Sep 04, 2013 12:12 am
Got my 2 braces today. (unfortunately with the incorrect gold colour bolts). I do have one spare pair of new OEM bolts I can use but l will likely need to find another pair of bolts for the second brace, as the current bolts on my cars will likely be corroded.
In the rare cases where factory bolts are in good shape, like on my Cultus vert, using anti-seize compound will keep them that way. I wonder if Jess might be able to send 2 bolts in a regular mail envelope.
Tom
PostPosted: Wed Sep 04, 2013 10:42 pm
PROPER BOLT SIZE IS AS FOLLOWS:
DIAMETER 10 MM x LENGTH 40 MM 1.25 THREAD NF HEX CAP 8.8 GRADE
make sure to get split(lock)washers and flat washers as well.these bolts are longer than stock,but you need the different length to make up for going thru the brace.plus a few extra threads here wont hurt.
INSTALL WAS EASY! had to use a come-along to pull my frame horns back in(out by half an inch) and one rear hole I had to use a punch to line it up......oh well(car was hit on the front at one time)
Brace clears everything,car handles better esp on the hiway.
GREAT HANDIWORK,JARD!!!!! 8) :cheers: THANKS AGAIN !!!!
3 tech 6*gear
gti brake swap
PostPosted: Sat Sep 07, 2013 5:42 pm
installed the brace on my vert today,fully expecting more problems to line up the bolt holes(car is rusty underneath) but to my surprise all the holes lined up perfectly!!!!! 8) this install was VERY easy
Its nice to see good quality craftsmanship,a sign that someone actually takes pride in their work.
THANKS AGAIN,JARD!!!!!
3 tech 6*gear
gti brake swap
PostPosted: Sun Sep 15, 2013 10:30 pm
How long should I wait until I express concern that I still havent gotten my two braces left
Would like to install before it snows, already has turned cold out :evil:
PostPosted: Fri Sep 20, 2013 7:29 pm
ahh my paypal went to dot org not dot ca
problem fixed
PostPosted: Sat Sep 21, 2013 5:56 pm
Still waiting for my brace :roll:
PostPosted: Sat Sep 21, 2013 7:21 pm
another gt saved by turbine tech. :wink:
PostPosted: Tue Sep 24, 2013 9:53 am
This brace is an awesome upgrade. Put it on the convertible, could tell the difference as soon as I opened the door and dropped my fat self into the seat. Recommend this strongly to anyone, especially convertible owners.
The favorite: Red turbo 3 swapped 90 firefly convertible with 3 tech cam and gear running 10psi rolling on 7 spoke GTI rims. Needs paint, a top, and more power, but lots of fun.
Honorable mention: 61 ford falcon money pit, 90 5.0 Lincoln LSC coupe with emotional attachment, supercharged teal 99 F150 for carrying firefly parts, and a black turbo volvo wagon with a dog gate to use every day.
PostPosted: Thu Sep 26, 2013 7:47 pm
Ok what's the update on all the people that got the brace. How many people do we have that are still waiting???? :huh:
PostPosted: Thu Sep 26, 2013 9:55 pm
I swapped catalytic converters with my dad's '93 XFi this weekend. His XFi had a '95 cat installed & I had a '96 or '98 Magnaflow on my '95. The '96+ cats hang down a little lower to get access to the post-cat O2 sensor. Upon installation, I had an exhaust leak at the exhaust manifold. I replaced the doughnut gasket & no more leak. I didn't have a leak before, but for whatever reason, the '95 cat didn't like the gasket. Once I installed the '95 cat, the Turbine Tech frame brace fit just fine. It slipped right over the control arm studs & aligned perfectly with the rear holes. The cat still rests on the frame brace, but doesn't seem to affect anything. At first the shifter linkage was hitting the cat in 3rd & 5th gear, but after a little adjusting, there's no more interference. I gotta say, the car does feel more secure & sturdy. I feel like I can take corners faster and this should definitely make any Metro last much longer in the rust belt.
PostPosted: Wed Oct 02, 2013 8:42 pm
The mad quebecer
The mad quebecer
What is your name sir?
PostPosted: Wed Oct 02, 2013 8:43 pm
The mad quebecer
The mad quebecer
problem fixed
Yes, we received your payment. We were missing a MK2 brace for your order but everything will ship next week as soon as they come out of the fab shop. We have been waiting after the payment for a loooong time :)
PostPosted: Wed Oct 02, 2013 8:44 pm
The mad quebecer
The mad quebecer
Thanks everyone for the kind words. Do not forget to have the car aligned after install, especially if you had to use a come along to put the brace. It will make a world of difference.
Cheers! :cheers:
PostPosted: Wed Oct 09, 2013 10:16 pm
i have turbine tech front lower and rear upper braces. i need the front upper strut tower brace.
anyone who has one available, send me a pm. :wink:
PostPosted: Sat Oct 12, 2013 4:23 pm
Rudy i contacted you via email.
PostPosted: Tue Nov 05, 2013 1:47 pm
Cheers! :cheers:
Still waiting. can you give the tracking number via email or pm. appreciate your help
PostPosted: Fri Nov 08, 2013 12:44 pm
Bump
