It is currently Tue Oct 17, 2017 6:34 pm
PostPosted: Wed Sep 11, 2013 9:32 am
So I got a cheap one from E-bay and it's apparently not holding pressure properly, cuz I'm running lean at upper rpm's. When I unplug the vacuum line, fuel pressure doesn't increase either. Even when revving the engine on neutral (no load), I can see the pressure dropping on the regulators gauge. Anyway the regulator has so many issues I won't even bother opening it to inspect.
So what FPR do you guys use normally, that won't cost me an eye? A link would be highly appreciated it
PS: this is a nearly stock NA car, so no need for fancy regulators for boost applications.
image_id: 22616
1993 Swift Gti
PostPosted: Sat Sep 14, 2013 7:38 pm
I would suggest that before you attribute your issue to the regulator that you ensure your fuel pump is not at fault...you may be surprised.
Also, some FPRs are designed to work best when plumbed into the fuel return loop...others work best plumbed into the inlet from the tank.
If no specific instructions were included with the FPR perhaps you can try plumbing in the FPR opposite of how you have it now and note the results.
Regards,
-Rogelio
"Drive it hard, drive it fast...expensive aftermarket parts will make it last!"
- 1993 Suzuki Swift GT
- 2008 Golf R32
PostPosted: Sun Sep 15, 2013 12:51 am
Thanks for your reply, but I already got the answers I wanted at Redline... http://www.redlinegti.com/forum/viewtop ... =7&t=52087
image_id: 22616
1993 Swift Gti
PostPosted: Wed Dec 04, 2013 9:38 am
I'm using a Tomei. If you plumb it from your return, you WILL see a pressure drop when revving the engine in neutral.
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Wed Dec 04, 2013 10:23 am
Maybe that's why you are having fuel-issues... your injectors are staying open apparently. I installed the stock fuel-rail and plugged a gauge in the return-line.... there's no pressure drop at all.
image_id: 22616
1993 Swift Gti
PostPosted: Sat Dec 14, 2013 11:34 pm
Why would injectors stay open because of fuel pressure? Injectors pulse based on electrical signals, not pressure. At least so I think. Let me hear your reasoning?
Btw, the problem was occurring before I put on the afpr.
~the other Ralph~
PostPosted: Sun Dec 15, 2013 12:01 am
I mean the fuel pressure should be the same... if you have a drop than the injectors are staying open longer than they should (which could be caused by sticking injectors) or you have a bad FPR.
image_id: 22616
1993 Swift Gti
