It is currently Mon Oct 16, 2017 6:01 pm
PostPosted: Sat Oct 12, 2013 9:21 pm
So according to my research the oil pumps from the G16 engines have more flow than the ones from the G13 engine, but could somebody tell me how they differ physically from each-other? I've a few spare oil pumps in the garage, but I'm not sure which one is from what engine...
Also, do you guys know if the oil pumps from the G13 engines were the same for SOHC and DOHC models?
Thank you
image_id: 22616
1993 Swift Gti
PostPosted: Sat Oct 12, 2013 10:21 pm
The 1.6 pump has wider "gears" with a different tooth profile.
The turbo3, SOHC, and DOHC all have different width gears in their pumps.
I'll try to show some pics tomorrow.
PostPosted: Sun Oct 13, 2013 8:09 am
Ok great, thanks. I'll take pictures of the ones I have too... just need to find them first.
image_id: 22616
1993 Swift Gti
PostPosted: Tue Oct 15, 2013 5:15 pm
According to my research the 1.6L pump should look like this:
And the 1.3L like this:
So that's settled.
But what about the 1.3L pumps? Is there a way to see the differences between the DOHC and SOHC models?
image_id: 22616
1993 Swift Gti
PostPosted: Tue Oct 15, 2013 7:52 pm
I didn't have a 1.6 pump in my tickle trunk, as they liely got used on 1.3's, but there was a bunch of 1.3 pumps in there. They all look the same on the outside, it's just the width of the gears that is different. I recall the GTI one has 9.5 mm wide gears.
PostPosted: Tue Oct 15, 2013 10:59 pm
Thanks, I'll disassemble them when I get a change. I hope I have the Gti models...
image_id: 22616
1993 Swift Gti
