It is currently Sat Feb 24, 2018 5:34 pm
 Post subject: Brand New Original parts
PostPosted: Wed Mar 26, 2014 9:58 pm
the 4dr version of 2nd swift are still manufacturing in China, so I can help to buy the Brand New Original parts if you need.
Only 1.3 SOHC 16V 4dr, EFI with OBD2, & body kit is little bit different
also, rear disc brake kit is provide
for reference only, a pair of front shock is around $100 usd, without shipment.
PostPosted: Thu Mar 27, 2014 2:26 am
Dash looks nice... did they do an update on the cupholders?
"We don't make mistakes here, we just have happy accidents... If you want sad things, watch the news. Everything is possible here. This is your little universe."
-Bob
PostPosted: Thu Mar 27, 2014 11:31 am
That's something to see, same basic chassis with a lot of updates. Rear suspension is completely different, see the two lower strut mounting bolts? They must have changed the actual floorpan itself somewhat to change rear suspension mounting points and such.
Did these come with manual crank windows in a 2dr hatchback? Sure be nice to buy brand new window rubber and regulator and finally have a true good working drivers window in the old ones around here!
Thanks for posting the pictures, it's interesting to see how these cars have survived for so long in different markets.
PostPosted: Thu Mar 27, 2014 6:44 pm
back rotor looks bigger.
PostPosted: Thu Mar 27, 2014 8:21 pm
no, I just take a wrong photo from Daihatsu Charade of the rear brake & suspension, it should be the same with the swift you are driving :lol:
this is the true 1 =)
PostPosted: Thu Mar 27, 2014 8:45 pm
I don't know how the old looks like
PostPosted: Fri Mar 28, 2014 1:22 am
Hell, if you could just pull that cup holder section of the dash you'd make a killing in the US. Our cupholder consists of a flimsy piece of plastic (only thing flimsier is the heater vents) and a little metal rod that can't fit anything bigger than 16 oz. comfortably.
-Bob
PostPosted: Fri Mar 28, 2014 9:59 am
Hey do they have the floor mats that say swift ?
PostPosted: Fri Mar 28, 2014 10:16 pm
Would that entire dash fit gen 2 cars? That alone would make for a nice upgrade, and look totally custom to boot!!!
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sat Mar 29, 2014 12:33 am
what mats you want?
PostPosted: Sat Mar 29, 2014 12:37 am
i don't know how's the dash you look like so I don't know will it fit or not, looks like u will need the hold center part. but there is a option very popular in China
PostPosted: Sat Mar 29, 2014 12:43 am
if you mean the hole dash board, it should be ok to install, but the electrical parts maybe not match or need to modify.
also, the dash is match for OBD2 ECU, so I don't know will it be fit or not, here is photo
PostPosted: Sat Mar 29, 2014 1:20 am
more photo, try to see what you are interested
PostPosted: Sun Mar 30, 2014 8:54 pm
KinFung wrote:
what mats you want?
factory mats that go on top of the carpet . where your feet are at.
PostPosted: Mon Mar 31, 2014 11:33 am
RP91gt wrote:
KinFung wrote:
what mats you want?
this?
PostPosted: Mon Mar 31, 2014 7:24 pm
A person could re-wire an older car to work with the newer gauge cluster. it looks the same as a gen 2 cluster (metro Canada, or Pontiac American, gti as well)
I am talking ENTIRE DASHBOARD- door to door, windshield to floor......that would be custom!! 8)
3 tech 6*gear
gti brake swap
PostPosted: Mon Mar 31, 2014 8:29 pm
Do you have a picture of the arm-rest fitted in the car? Do you know if it's a direct fit to a "regular" swift? How about price?
image_id: 22616
1993 Swift Gti
PostPosted: Tue Apr 01, 2014 8:15 pm
did u want 1 to try? look's like it fit if u replace the gear lever cover together \.
PostPosted: Tue Apr 01, 2014 8:17 pm
if u change all of that, I can't see any reason it won't fit 8)
PostPosted: Tue Apr 01, 2014 8:27 pm
arm rest is after market product
They didn't provide a pic really on Swift but it will fit & look like this
PostPosted: Sat Feb 06, 2016 5:28 pm
Dashboard with harness would be nice as the heater controls are diffrent
私はスズキスイフトGTが欲しい
