It is currently Sat Oct 21, 2017 6:38 am
PostPosted: Fri Jul 11, 2014 10:01 pm
Does anyone have a dyno sheet showing these cams with stock pistons? I have them currently but have not installed them yet only because I am still a bit skeptical of loosing low end power. As I have heard a few people said they did not loose any low end power but if I could see a dyno sheet that would be great.
I have dyno sheets of my fairly stock motor and will be getting some done soon with my newly acquired chips from 'teeth'. After I install my set of cams I will run on the dyno again for some of you guys to benefit!
PostPosted: Mon Aug 25, 2014 9:54 pm
Well I ended up purchasing the cams setups and doing the dyno runs for the benefit of Teamswift members.
Run 2 is with the hybrid cam
Run 7 is with the stock cam
PostPosted: Fri Aug 29, 2014 12:10 am
Nice plots there bro! Maybe you should also post your mods.
~the other Ralph~
Certified Suzuki Owner:
