It is currently Sat Oct 21, 2017 5:37 pm
Post new topic Reply to topic  [ 178 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Sun Oct 27, 2013 12:23 pm
fear enough... does your 365/210 work with standard valvetrain components??
The engine has to use standard valve sizes, but porting is allowed. I'm Limiting my revs to 8500 rpm max and compression to 11-1 max... i dont want every last bit of power, cause engine is mines and i prefer it to be reliable more than anything. plus the car weights 590kg without driver.
All or nuttin
PostPosted: Sun Mar 30, 2014 12:38 pm
85-88 3cyl/85-94 1.3/1.6 8V
358/212
375/216
395/226
420/254
448/240
How much for this cam for the 8v?
PostPosted: Sun Mar 30, 2014 1:45 pm
$150 on your cam core, plus shipping.
PostPosted: Sun Mar 30, 2014 8:01 pm
This is your full race grind i assume? what are the other valve train requirements.
anywhere i can get a core in canada, easier that way or can i pay u for a core?
PostPosted: Mon Mar 31, 2014 7:40 pm
u have a core yes or no? how long does it take to grind?
PostPosted: Mon Mar 31, 2014 7:53 pm
I might have one, but it might be a little rough. I will look in the next day or so.
PostPosted: Tue Apr 01, 2014 5:20 am
let me know all things being well would like to make a purchase this week..
What is the power band for the cam?
im circuit racing a mk1 swift at 1640 lbs min weight with driver with 4.9:1 final drive, so would like the wildest cam u have.
ps. As a cam guy, to you, which head works best gti or sohc 16v?
PostPosted: Tue Apr 01, 2014 6:14 pm
You building car for the new Bushy Park circuit ???
PostPosted: Tue Apr 01, 2014 9:19 pm
I have a core. It's not perfect, but it's useable. I'll give you a deal on it.
The GTi head is better for a number of reasons. The valves and springs in the SOHC 16V are too short for serious performance, and the rocker/follower setup is also a limiting factor.
PM me for details if you want the cam.
PostPosted: Tue Apr 01, 2014 9:44 pm
pm sent :twisted:
PostPosted: Wed Jul 16, 2014 7:01 pm
yeah on its first outing, used the sohc 16v but wasnt impressed.... will get cam from 3tech for 8v and build a swift instead..
PostPosted: Wed Jul 16, 2014 7:23 pm
what cams would I need for a bigger lope and good street/track use in a 92 swift gt? something bigger than stock
PostPosted: Wed Jul 16, 2014 8:02 pm
for street/track with an otherwise fairly stock DOHC, I would recommend the 210/340 grind. Rough idle, excellent power, and there is a chip available that was developed specifically for that profile.
PostPosted: Thu Sep 18, 2014 6:04 pm
e-mail sent from raphael.fresteves@gmail.com! :twisted: :twisted: :twisted:
PostPosted: Sat Sep 20, 2014 1:08 am
OK back at this again.
98 esteem 1.6 sohc 16v engine in swift. Stock swift ecu.
340/200
355/204
Need to pass obd2 readiness test but that's it. No sniffer. Willing to wire in safc and injectors/fuel pump to supply addl fuel if needed.
Car has gti dohc exh manifold and 2" exhaust with big cat and well flowing muffler.
As I said before I think you recommended the 340/200 but I can't find the PM. Think the 355 will be happy in my setup?
I'm ready to purchase and have a core if needed but would prefer to not deal with shipping.
PostPosted: Sat Sep 20, 2014 2:12 am
I'll have to go through my list of grinds and see what I still have for that application. Pretty much everything I do for that head is for street driven 1.3's and the 192/198 cam works great for them. Obviously you want more.
Give me a few days to look into it.
PostPosted: Sat Sep 20, 2014 2:34 am
I was just going off what's in the first post. I'm looking for something drivable with good power and not stupid. I don't mind some lope at idle. Granted I don't know how any of those cams sound/drive.
Clearly I can't go above the stock 6500 rev limit thanks to the dinky bottom end these have :(
PostPosted: Sat Sep 27, 2014 10:10 pm
PostPosted: Mon Nov 17, 2014 1:20 pm
We've been crazy busy around here the last few months. It's slowing a bit, so I'm going to spend some time on this cam this week. I was not 100% happy with the numbers on the first couple of cams I put together for this motor, that's why I came up with the latest 1.3 street cam. Since that's pretty much 99% of the market, I haven't had any reason to come up with anything else. I will try for something in the area of .340"-.360" lift and duration around 204-206 intake and about 210-216 exhaust.
PostPosted: Thu Nov 20, 2014 12:50 am
Excellent. Thank you.
PostPosted: Sun Dec 21, 2014 9:52 pm
I'm interested in a bigger cam too. 1.6 needs more
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Mon Dec 22, 2014 8:27 pm
We can do the 355/204 int 365/204 exh
PostPosted: Wed Dec 24, 2014 12:24 pm
I'll be in after the holiday season and my checks return to normal
PostPosted: Wed Dec 24, 2014 2:02 pm
OK.
In the meantime I'll see if i can find another master for the exhaust side with a little more duration.
PostPosted: Wed Sep 21, 2016 12:40 am
It would be cool to have some video examples on the different type of profile that ppl are using so we can all see the difference of the rough idle.
If you have the cams installed please share a video.
