It is currently Sat Feb 17, 2018 9:06 pm
 Post subject: Transmission Gear Ratios
PostPosted: Sun Apr 30, 2006 10:24 am
Here are the gear ratios for all international model Swifts including 1.0L, 1.3L, 1.6L, SOHC / FWD / DOHC /MT / AT:
We know fuel economy is very much affected by gear ratios and in particular the resulting RPM's. In other words, if your engine revs higher than it must at any given time, you are wasting gas!
Notes: The ratios were taken from an official Suzuki/Germany publication of 1994. Data applies to international (European/German) models!
All of the following were sold as "Swift", none were sold as Firefly or Metro in Europe.
Regional or local market models, such as USA models, models for complying with unusual emission / lighting / road or safety regulations might be different. I will never find out unless somebody says so.
The tyres of these cars were as follows:
All had 155/70R 13 except
1.3L SOHC convertible: 165/65R 13
1.3 FWD: 165/70R 13
1.3 DOHC (GTI): 175/60 14
1.6, all: 165/65R 14
Manual transmission all except1.3 DOHC except all FWD, except all 1.6L:
1st gear: 3.416 (revised to 3.58:1 on US 1.3L 1995+ only ?)
2nd. gear 1.894
3rd gear: 1.280
4th gear: 0.914
5th gear: 0.757
Reverse: 3.272
Manual transmission, only 1.3 DOHC:
1st: 3.416
2nd: 1.894
3rd: 1.375
4th: 1.030
5th: 0.870
R: 3.272
Manual transmission only 1.3L FWD:
1st: 3.545
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
R: 3.250
Manual transmission, all 1.6L:
1st: 3.250
2nd: 1.772
3rd: 1.233
4th: 0.911
5th: 0.769
R: 3.250
Automatic:
1st gear: 2.810
2nd gear: 1.549
3rd gear: 1.0
Differential, MT:
1.0L SOHC: 4.105
1.3L SOHC: 3.523
1.3L SOHC/FWD: 3.944
1.3L DOHC: 4.105
1.6L SOHC: 3.722
1.6L SOHC/FWD: 3.944
Differential, automatic:
1.0L: 3.950
1.3L: 3.684
1.6L: 3.450
If you want to know how often the engine has to turn in a certain gear to make the tires turn once, here's how:
Take the gear ratio times the differential ratio. For example, a 1.0L/MT in fifth gear (0.757) times the differential ratio (4.105) = 3.107 That means 3.107 turns of the engine for one turn of the tyres.
The 1.3L SOHC MT in fifth gear would be 0.757 x 3.523 = 2.66
The 1.0L SOHC AT in top (3rd) gear would be: 1.0 x 3.950 = 3.950
Cheers,
Helmut
PostPosted: Sun Apr 30, 2006 2:28 pm
NICE!
sticky this, mod ;)
PostPosted: Sun Apr 30, 2006 8:53 pm
i thought i had read somewhere that the 1.0 manual transmission's ratios or final drive was different (taller) for cars with 12 inch wheels compared to 13 inch wheels. the U.S. XFI model was different as well from the regular 1.0 MT cars.
i'm hoping so, because i've got an extra transmission from a '92 (1.0, 12 in wheels) that i was thinking of trying in my '98 (1.0, 13 in. wheels).
i also have one from a 1.3 sohc. that one would probably be best.
... www.EcoModder.com
PostPosted: Sun Apr 30, 2006 9:08 pm
Unless I'm mistaken there are different ratios in the five speed manual transmissions - 3rd, 4th & 5th are different on the GT/GTi models -
PostPosted: Sun Apr 30, 2006 9:13 pm
helmut - sorry to muddy the waters...
but check these threads:
http://www.teamswift.net/viewtopic.php?t=14845
http://www.teamswift.net/viewtopic.php?p=163307
there are apparently differences for the 1.0 cars between the pre- and post- '95 versions, the XFi, and the convertibles.
unfortunately, it's hard to figure out what's correct.
PostPosted: Mon May 01, 2006 5:29 am
I've seen both from official-looking sources. :?
One thing to add:
The first-gear ratio has been revised from 3.42:1 to 3.58:1 to improve launch feel (1.3 Liter only)
This comes from GM and applies to the US cars (and maybe others?). I don't know the exact year the change took place, but I'm pretty sure it was during the MK4 (1995+) era.
PostPosted: Tue May 02, 2006 1:37 am
Thanks for the input! Sorry I didn't mention all models.
The original post has now been edited and all information i ever collected is included, even tyre size.
If you think I missed something or made a mistake, let me know so the original posting can be corrected again.
Maybe it can be made a sticky part of the FAQ section once nobody wants it changed...
Cheers,
Helmut
PostPosted: Thu May 04, 2006 9:10 pm
not yet mentioned is the 4.39 final drive in the 1.0L cars with 13 inch tires.
superf1y wrote:
from this thread: http://www.teamswift.net/viewtopic.php?t=14845
Any of the non-turbo cars with 13" wheels had the 4.39. It makes the final drive the same as 4.11 with 12's.
PostPosted: Fri May 05, 2006 4:51 am
geometro, I have no info whatsoever about 4:39 or any models to do with it, and also nothing about 12 inch wheels at all.
Nothing I ever saw made it to this part of the world, and perhaps not even to the international market. We saw only 13 inch wheels except a very few 1.6Lwith 14 inch. (We drive way too fast on the Autobahns for that sort of final ratio, especially with smaller 12' wheels.) I will gladly edit the original post, but need more details than that. Maybe send me a private message.
Perhaps someone would like to setup a ratio table for USA models?
Cheers,
Helmut
PostPosted: Fri May 05, 2006 9:27 am
Helmut wrote:
geometro, I have no info whatsoever about 4:39 or any models to do with it, and also nothing about 12 inch wheels at all. ... I will gladly edit the original post, but need more details than that. Maybe send me a private message.
unfortunately, i don't know anything more about it than what i read in those two threads that i linked above.
if i'm not mistaken, the majority of the mk3 1989-1994 1.0L north american cars came with 12 inch wheels. but i'm saying that based on my memory/observations.
i looked in my 1998 factory service manual and my owner's manual for gear ratios/final drive numbers, but couldn't find any figures. where did you find the information you posted?
PostPosted: Fri May 05, 2006 2:44 pm
The technical info was taken from official Suzuki advertising, from car catalogs.
Helmut
PostPosted: Sat May 06, 2006 2:27 am
I pulled the following info from various US brochure scans:
1989-1994 Swift 1.3L 5-speed:
1st = 3.416
2nd = 1.894
3rd = 1.280
4th = 0.914
5th = 0.757
GA/GS final = 3.523
GT final = 4.105
3-speed auto:
1st = 2.810
2nd = 1.549
3rd = 1.000
Final = 3.506 (1994)
3.684 (1989-1993)
1998 Metro:
1st = 3.42 (3.58 with 1.3L)
2nd = 1.89
3rd = 1.28
4th = 0.91
5th = 0.76
Final = 4.39 (3.79 Sedan)
Automatic '98 Metro same as older Swift ratios posted above except with a 3.61 final drive. Auto was not available on 1.0L '98 Metros.
Last edited by Gasoline Fumes on Sun May 07, 2006 2:47 am, edited 1 time in total.
PostPosted: Sat May 06, 2006 7:47 am
thanks for posting that, gasoline fumes.
for the first one, the swift 5-speed, i assume that's with the 1.3? in the cdn market at least, there was also a swift 1.0 available in that generation.
it's funny that info would be in the brochures, but not in: my owner's manual; chilton repair guide; factory service manual (unless i just missed it - the FSM is huge).
strange, eh?
PostPosted: Sun May 07, 2006 2:43 am
Correct, that's for the 1.3L. I don't think there was ever a 1.0L Swift in the US.
PostPosted: Mon Jun 08, 2009 2:20 am
In other words, if your engine revs higher than it must at any given time, you are wasting gas! :D
pret auto
PostPosted: Mon Jun 15, 2009 9:28 pm
So any 89 -94 1.3 manual swift non gt is a 3.52 ring gear?
PostPosted: Fri Aug 19, 2011 9:54 pm
i am looking for 1998 GEO METRO Manual Trans Manual Transmission i am planning to upgrade my 1995 GEO METRO Manual Trans Manual Transmission. what i have just found is the GEO repair from automd. anyone can help me with this?
PostPosted: Fri Aug 19, 2011 10:57 pm
http://www.autorepairmanuals.biz/site/5 ... P98M1-2-3F
First thing I bought before I started to work on my car, but the 2000 year. Best $135 I spent. Will give you the details.
PostPosted: Mon Mar 26, 2012 8:59 pm
So my wifes 99 Metro Auto has a final of 3.61?
How about my 89 GTI Auto?
Or my 92 1.0 Auto?
I was hopeing to get better milage with the GTI trans in the 99 Metro and the same for the 92 Geo Metro with the 99 into it?
PostPosted: Fri Jul 27, 2012 8:01 am
Some good info here. Nobody wants to waste gas, especially nowadays. You can check with your local mechanics to make sure you're getting good enough MPG as well.
Speed costs money. How fast do you want to go?
PostPosted: Mon Oct 06, 2014 11:53 pm
I build transmissions.
My results are as follows
All with 13" wheels 155/80-13 tires
97 1.3L auto with 4.10 ring and pinion.
highway 40 mpg 70 mph
92 1.0L vert auto 4.39
highway 36 mpg 65 mph
97 1.3L 5 speed 3.79
highway 40 mpg 70 mph 45 mpg 65 mph
92 1.0L vert auto 4.10
highway 41 mpg 65 mph
97 1.3L 5 speed 3.52
highway 35 mpg 70 mph
92 1.3L 16 valve DOHC 5 speed
As for the transmissions having different gear sets, of the 20 transmissions I have built, they all have the same teeth count
on 1st, 2nd, 3rd, 4th, 5th, and reverse gear.
The only thing I see different is the ring and pinion teeth count.
Width of ring and pinions... Thicker gears on 1.3L sohc and 1.3L dohc.
Fainya
PostPosted: Tue Oct 07, 2014 4:32 am
Not quite sure why you are dragging up old posts, but I'll clarify this once again... all North American 1.0/1.3 rod change gearboxes have the same 1-5 ratio's, gti's sold in the rest of the world got a lower 3rd(1.373), 4th(1.03) and 5th(0.871) gear, the exception to this is the very late 90's when they used a lower 1st and rev gear.
As a rule the 3cyl versions have narrow crownwheels and 4cyl's have 1' wide crownwheels.
PostPosted: Thu Jan 14, 2016 10:45 pm
gclub
 Post subject: Re:
PostPosted: Wed Mar 30, 2016 3:59 pm
Nothing I ever saw made it to this part of the world, and perhaps not even to the international market. We saw only 13 inch wheels except a very few 1.6Lwith 14 inch. paris cdg transfer (We drive way too fast on the Autobahns for that sort of final ratio, especially with smaller 12' wheels.) I will gladly edit the original post, but need more details than that. Maybe send me a private message.
Cheers,
Helmut
That sort of final ratio is more interesting
cron
