It is currently Sun Oct 22, 2017 9:24 am
 Post subject: 1.6 16v swap
PostPosted: Thu Nov 20, 2014 4:01 pm
G16 on g13 transaxle. Just lowered it in last night. More later.
GEO MAFIA!
14 ford Mustang v6.
 Post subject: Re: 1.6 16v swap
PostPosted: Thu Nov 20, 2014 5:04 pm
I've read that you need an adapter plate to use the G16 trans on G13 engines. You are doing the oposite, but I don't see a plate. Could you provide more details on whats going on here?
image_id: 22616
1993 Swift Gti
PostPosted: Mon Nov 24, 2014 7:27 pm
jus enlarge the two upper holes and you drill the block for the two lower holes and use a nut ant bolt. been doing it that way for years, with no issues even had a gti box on my J18 in latter stages.
All or nuttin
PostPosted: Mon Nov 24, 2014 9:58 pm
You must have to use the 1.3 flywheel. What flywheel fits the small bell housing with th j18? They do make a large bell housing for the rod shifted tranny, they come in a g16 Esteem.
PostPosted: Sun Nov 30, 2014 12:16 pm
j18 flywheel was cut down n use gti/gs ring gear. j18 has 8 holes compared to g series 6 bolt flywheel.
i know about the 1.6 baleno setup but they are not so easy to come by here.
All or nuttin
