It is currently Mon Oct 16, 2017 5:47 pm
PostPosted: Wed Dec 17, 2014 4:13 am
Recently my '97 1.3L TBI (110k miles) has been stalling during operation and/or failing to start. After a stall, it may take up to 10 minutes before the motor will start.
I checked that there was spark (which there was) and took the opportunity to replace the plugs, cap & rotor. I also replaced the fuel pump and checked that the fuel filter (which was replaced two years ago) was not clogged. I started the car and it ran for about four minutes before dying. This continued with the motor sometimes restarting or taking a good 10-20 minutes before it would start.
While it was failing to start, I took the air cleaner off and watched the injector while a friend cranked the motor. There was no fuel coming out of the injector - even at full throttle. I checked the electrical connections for the injector and the ground on the throttle body but there was no change.
Before I order a new injector, I'd like to eliminate any other culprits that could be causing the injector to fail. Any ideas?
Last edited by BlueState4Ever on Wed Dec 17, 2014 7:26 am, edited 1 time in total.
PostPosted: Wed Dec 17, 2014 6:50 am
I will take a shot RUSTY GROUND.!...... Really check all your ground straps
even the one to the ECM
can I tell you a story about your car.?
The injector on your car must get a small (very small) voltage sig from your ECM to fire
after the ECM receives a signal from your crank sensor or distributor that say yup engine is rotating go ahead and fire injector......
If your ground straps or rusty the signal will be intermittent if any
best way to check if your injector is firing use a timing light shine it at the TB when it flashes you should see a small spray
if you can't see it in the flash then you know your injector is not firing.!
can you start it with Starting fluid.? will it run at all if any with starting fuild.?
Do you have any Codes from ECM.?
These cars are prone to electrical gremblins I,E catch in fire little stuff like that.
but with alittle maintnance they will go long and nothing on this car is very difficult to fix....
anyone with a computer
and basic hand tools can keep them in working order
Because I'm a giver
.look these over see if this helps
http://metroxfi.com/wp-content/uploads/ ... t_1997.pdf
.....and because I'm a lazy S,O,B don't want to do the leg work.... The mullett man has it going on
ECM codes
http://geometroforum.com/topic/638390/1/
PostPosted: Wed Dec 17, 2014 7:24 am
I got a second pair of eyes to watch for a spray from the injector at WOT and they also saw nothing. We noticed that the butterfly valve was dry after these attempts. I have a timing light so I can it another try and see if I can spot a spray.
No codes from the scanner but that is likely due to the battery going dead after all the attempts to start it this last time around.
I sprayed starter fluid in the throttle body and was able to get it to turn over but not start.
I'll go through all the grounds once more.
PostPosted: Wed Dec 17, 2014 11:41 am
If it wont start on strater fluid more then likley ignition related. Remember. You only need 3 things for an engine To fire. Fuel, compression and spark.
and seeing how its intermittent. I woukd follow jv&s and check every ground from the rad support to the back seat. Especially the ecm and intake ground.
PostPosted: Wed Dec 17, 2014 12:29 pm
Holding WOT while starting will trick the computer into flood mode and it won't spray fuel, after you stop cranking the motor does the fuel pump prime on?
PostPosted: Wed Dec 17, 2014 2:01 pm
That was an error. I never started with WOT. I just pumped it while a friend watched the injector for any spray. Nothing.
PostPosted: Wed Dec 17, 2014 2:04 pm
It turned over and stumbled on the starter fluid. I didn't continue spraying to keep it going as that was confirmation enough there was spark. I'm checking grounds shortly.
PostPosted: Wed Dec 17, 2014 2:57 pm
UPDATE: Grounds are fine. No corrosion and good contacts.
Question: Would an ECM failure cause intermittent stalls / no starting? How about a bad Map Sensor?
PostPosted: Wed Dec 17, 2014 3:45 pm
Have you tested the injector with an led? That's the only real way to test it, a multimeter won't pick it up as its to fast, get an led and check for pulsing while cranking, if there's pulsing then disconnect the fuel line and make sure there's good amount of gas coming in, if there's gas but no gas comes out from injector then it could be a stuck preassure regulator or clogged injector. Does the car misfire? Is the check engine light on? Crank it and see if the camshaft moves, if not then you might have a broken timing belt.
PostPosted: Wed Dec 17, 2014 3:49 pm
An ecm either is dead or it works, you state it starts once in a while so that means your ecm is ok. Have to done a compression test on the engine, it should eliminate blown head gasket or bad exhaust valves.
PostPosted: Wed Dec 17, 2014 4:25 pm
Car will occasionally start and runs smoothly before dying. I'm going to try the timing light method to check for spray from the injector.
PostPosted: Wed Dec 17, 2014 10:04 pm
no codes That is very odd
Gound look good.? OK?
I read your post and you say some time it runs and some times it doesnot That is Wiring issue
if it starts and the stumble i would look a the TPS
You injector needs 28lb-32lb to operate properlly
If this was my car My next move would be to disconect the battery and remove /Inspect/Clean the "Sandwich"
that is the Fuse block located under drive side dash look in all conectors for burn scorch marks
Let me look for a picture standby..............
PostPosted: Wed Dec 17, 2014 10:22 pm
just because the Grounds/ wiring harness look good doesn't mean they are clean and dry
This car had run issues and headlights issues I was able to bring this car back and drove it daily
also go throught the Boxes located just behind the battery your fuel pump relay and start relay are in there
might be loose and or dirty...........JV&S
PostPosted: Wed Dec 17, 2014 10:54 pm
No codes as the battery went dead while I was cranking. In my experience it usually takes a good day or two of driving before I will see codes and since I'm not able to keep it running I'm out of luck. A professional code scanner at a shop could probably do it's own diagnostics but that would mean towing it.
It does not start and stumble. It starts and runs fine then after a minute dies and will not start for at least 15-20 minutes. When it does restart, the same thing happens.
I was able to start it just a few minutes ago and watched the injector while it idled for a minute but I couldn't see the spray.
I will also checked and clean the grounds.
I will check the fuse sandwich.
Could the ECM or any of the sensors be shutting everything down?
PostPosted: Wed Dec 17, 2014 11:42 pm
If it was a sensor then there would be a code stored. Next time its running then dies do not turn it off. Check for codes immediately.
PostPosted: Thu Dec 18, 2014 1:47 am
Do you use a computer to read the codes or the flashing cel way?
PostPosted: Thu Dec 18, 2014 2:23 am
Fashing cel
Back to The OP problem ....
it will run then die's and can't start for 15-20 minutes Deffinetly what they call a Hot Soak issue...or ..Heat Stressed issue
Like what you would find in a electrical connection when wire or connection gets hot the resistance
would be to high and ECM senses the high resistance value and shut it down ....
or a connector somewere get hot and wires loosen up in it's plastic holder then cools down wires go back together to make a connection
or resistance high TO or IN The Ignition system I,E, Dizzy, Dizzy connector,Ignition modual, Ignition Coil
(Usually the ignition modual is a go no go thing)
Coil possible.?
Pull a plug wire off any will do when cold crank the engine over check to see if you get a strong spark
after it dies and wont run
pull the same plug wire see if the spark doesnot get weaker if it does you might get lucky find a weak coil or connection in the wire to the dizzy
deffinetly not a fuel issue
if your battery is dead enought to not run the car but still might have enough minimal voltage to store codes.....
I believe you reset the ECM codes by pulling the dome light fuse ( not 100% sure on that for this year)
.........JV&S .. and yes my spelling is not correct it creative.!
PostPosted: Thu Dec 18, 2014 3:01 am
Using this bad boy:
http://www.harborfreight.com/can-obdii-code-reader-with-multilingual-menu-98570.html
PostPosted: Thu Dec 18, 2014 3:08 am
Fashing cel
It now only runs for about 30 seconds before dying.
Coil possible.?
I swapped out the coil for another one and no change but I will try this test just to confirm. I also opened up the sandwich and everything looks clean.
My battery is weak. It's about four years old and I get about five cranks attempting to restart before I notice it becoming weaker (dome light dims). My code scan tool will clear codes but there are no codes to clear. I'll try the flashing cel method.
PostPosted: Thu Dec 18, 2014 11:20 pm
I've had ecms be fine one minute and shit themselves the next. 2 minutes later it's running fine again.
When it's dead check injection pulse with a noid light. If it's good take a resistance measurement of the injector. I'm betting the injector is going open.
PostPosted: Mon Dec 22, 2014 1:37 am
Okay, so the issue has still not been resolved and I'm starting to get a bit frustrated. To recap, here is what I've replaced:
1. Distributor Cap & Rotor (Replaced)
2. Ignition Coil (Replaced)
3. Fuel Pump (Replaced)
4. Fuel Filter (2 years old, removed and blew through it - no restrictions)
5. ECM / ECU (Replaced)
6. Fuel Pressure Sensor (Replaced)
7. Ignition Ignitor (Replaced)
7. Pickup Coil (Replaced)
8. Idle Air Control Valve (Replaced)
9. Fuel Injector Resistor (Finned Aluminum behind left shock tower with yellow connector)
I have done the following diagnostic work:
1. Cleared the fuel and return lines.
2. Checked and cleaned all grounds.
3. Checked fuse sandwich box (under dash)
What could be causing the motor to shut down after 20-30 seconds of idling? Again, I am able to restart after 15-20 minutes but the same thing will happen. It dies quickly as though the fuel stops. Could a faulty TPS sensor be shutting off the fuel? Injector?
What do y'all think?
PostPosted: Mon Dec 22, 2014 11:10 am
PostPosted: Mon Dec 22, 2014 2:09 pm
I had similar symptoms a few years ago to yours. After intermittent failures shortly after cold start/warm up, I checked everything other than the fuel injector itself. After a few weeks of inconvenient stalling in traffic, I bought a used injector, and took the old injector out and took them both to a fuel injection/turbo service shop. They tested and confirmed the old injector was shorted. (explains why it took a few minutes after engine warm up before failing). They disassembled my used injector and did a cleaning for about $30 and did not charge me for testing the old one. I now keep a known good injector in my parts bin for this sort of test scenario. (Pic n Pull charges I think $7 for a used fuel injector)
PostPosted: Tue Dec 23, 2014 12:17 pm
That was it! I pulled the injector (right) and the housing was collapsed, the o-ring disintegrated and I imagine the unit was shorting causing gas to back-up. I pocketed a used injector out of a junked Geo at Pick-A-Part (left) and popped it in. Viola! Problem fixed. Thanks.
PostPosted: Tue Dec 23, 2014 6:01 pm
Very good. Will keep this one in the books incase it happens again.
