It is currently Thu Feb 22, 2018 2:30 pm
PostPosted: Fri Feb 06, 2015 2:35 am
Its ghetto but bright. I went to pick and pull and went and grabbed a third brake light out of a Hyundai santa fe. Did some trimming and vuela.
Vogtland lowering coils
Ngk plugs
8mm silicon wires.
PostPosted: Fri Feb 06, 2015 2:37 am
I used some electrical tape and covered the large areas that I could to stealth it put a little. But its bright. Im gonna make a actual enclosure for tgis light soon. I have the optical lense and soon a red one for it to look more "OE"
Ngk plugs
8mm silicon wires.
PostPosted: Fri Feb 06, 2015 2:54 am
This is with the car running, only the brake light on. Dismal street lightning.
Ngk plugs
8mm silicon wires.
PostPosted: Fri Feb 06, 2015 4:03 pm
I installed a flasher module last year for my 3rd brake. Flashes 3x fast, 3x slow, then stays on. looking something like this.
https://www.youtube.com/watch?v=T5lqYwPX9ds
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Fri Feb 06, 2015 4:28 pm
Im getting a flasher module soon. Needed the better light up first.
Ngk plugs
8mm silicon wires.
PostPosted: Wed Oct 18, 2017 11:10 pm
will check that out
PostPosted: Wed Oct 18, 2017 11:21 pm
I don't know why you need that action... so pure stupid and garbage.
Users browsing this forum: Majestic-12 [Bot] and 0 guests
