It is currently Sun Oct 22, 2017 12:42 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Mar 18, 2014 6:54 pm
use a caliper side for straight edge (shown with red line on picture), put it on shims that are on bearing and then measure clerance with those (2nd picture): (i don't know how to call them in english :P )
i can take a picture for you tommorow since i have one gearbox with missing 5th gear in garage atm :)
also, if you use same counter shaft and same gears (only new synhrons and bearings, which are SGP) stock shim should be the right one..
PostPosted: Tue Mar 18, 2014 8:02 pm
Teeth wrote:
I sort of doubt that's your issue, but I am really not an expert here :huh:
I agree, I doubt it's the issue. Next time I have to open a box, I will use your shim making idea, but maybe thin steel sheet.
My solution was to buy another transmission. Shifts like a dream.
Ofensus Racing
Rally Racing Geo Metro
PostPosted: Tue Mar 18, 2014 8:04 pm
[quote="lukak"](2nd picture): (i don't know how to call them in english :P )/quote]
Feeler guages. I just didn't know if there was a technique to it besides just measuring (eg. must be in this gear, etc.)
Thanks both of y'all for the info.
Ofensus Racing
PostPosted: Fri Mar 21, 2014 3:58 pm
@Teeth, you know those shims are hardened right? Those are very hard to keep them from compression when it goes from load on, to load off, then back again. Soft shims wear thin, then wear out, and run around inside the unit to who knows where. Also using a snap ring can do the same thing. One end gets loose. Then its in your gears.
PostPosted: Fri Mar 21, 2014 5:47 pm
One guy on gmf made a shim from cardboard and surprisingly is still going fine, not ideal but better than lots of free play I suppose.
The shims are still available new from suzuki dealers but thats not much help to US folk now I guess.
PostPosted: Wed May 07, 2014 2:44 pm
Hmmm.
Well, I was aware that aluminum is compressible, so that's why used the thickest stack that would be within spec. Better than cardboard, but I do have to admit that my transmission just dropped 3rd, 4th, and 5th.
I believe the problem was a massive bearing failure and I don't think it was caused by the shims, but I guess I'll take my transmission apart and find out :cry:
I am sure I screwed something up :oops: as everything looked pretty good when I buttoned it up. On the other hand, running it hard at the autocross probably didn't help either.
PostPosted: Wed May 07, 2014 3:11 pm
well small piece of silicone (or whatever you use to seal housing together) that drop into box can close a hole in shaft for lubricating or something.. or small piece of metal can damage bearing enough that in time it will fall apart..
for racing we often take it apart and just check everything (maybe replace few parts if needed,..) and put it back together..
after you do it let's say 1x per month it's not that complicated anymore :wink:
PostPosted: Mon Jun 23, 2014 12:57 am
wondering if you where having the same issue I am. Mine shifts from 1-2 no problem but it wont shift down from 3-2 no grinding just wont go I was thinking its a syncro.
02 bmw 330ci zhp
'98 Chevy K2500
'76 Harley Davidson FXE
PostPosted: Wed Feb 11, 2015 11:40 am
is there anywhere to buy the gears if mine ar chewed up?
PostPosted: Wed Feb 11, 2015 12:40 pm
best is to get another used gearbox.. for spare parts or to change it with your current gearbox..
PostPosted: Thu Feb 12, 2015 4:56 am
but thats $130
PostPosted: Thu Feb 12, 2015 11:14 am
how much do you expect to give for parts? not sure for usa, but in eu only bearings, seals and synchros cost 200eur or even more...
and for gears, there are only used gears from another used gearbox.. i doubt anyone make new ones..
PostPosted: Thu Feb 12, 2015 11:24 am
Exactly. In general I'm currently the only source of gears and internal trans parts (I assume this because I get requests from all over the world now and again). I sell most orders at about $100-150. If I don't see enough its not worth the hassle of tearing them down and cleaning/shipping parts. If these parts could be purchased new, the cost would be ridiculous. Toyota matrix c59 trannies have issues, I've priced out the two gears for 5th at $500+. It's what makes manual trannies so tough to rebuild at shops, one or two hard parts and they become cost prohibitive, that's why I try and offer parts for teamswifters when I can so they can repair gearboxes rather than park the cars.
PostPosted: Sat Feb 14, 2015 12:46 pm
i can get a synchro/bearing kit off ebay for $90
PostPosted: Sat Feb 14, 2015 2:19 pm
So can I. Discussion was on replacing chewed up gears. A bearing synchro kit won't include gears.
PostPosted: Sat Feb 14, 2015 3:42 pm
DMWdave and myself are also selling 2nd hand gearbox parts, most of the stuff I ship is to the States because you can't get new parts easily in North America, the fact is parts like 2nd gear are still being made today, they are exactly the same as the ones in the new k series boxes available worldwide except NA, new low speed syncro hubs are available new EX-Japan but at around US$300 it makes more expensive than most metros, cheaper to buy a complete good condition box for $200.
PostPosted: Sat Feb 14, 2015 6:07 pm
in usa yes.. last time i ordered it to EU it was 125usd + shipping + import tax.. that was 180+eur at that time..
still cheaper than buying original SGP parts from dealer.. only bearings are 150+eur.. (both differential bearings and small one on input shaft are standard bearings so i can get those for around 20eur, both seals on differential are like 2-3eur each, seal on input shaft is like 5-10eur, depends on quality (it's not exacly right one but it's work for street use and rally n/a gti (up to 9000rpm))
so i buy those standard bearings and seals, order non-standard ones from suzuki dealer (still 100+eur) and try to get some used 1.0 3cyl (non turbo ofc) gearbox with low km's.. (around 60eur if lucky, there was alot 1.0 3cyl and 1.3 non gti swifts around) then i took apart my gti box and donor one, and use best parts from both (everything except differential, FD and 3-4-5 gears are the same in all those boxes)
ohh, and if possible try to get japan made box (EU market mk2 and mk3 - up to around 1996 i think) and not hungary made (mk4 - 1996-2002 i think) they used some parts a little better (from my experience)
PostPosted: Sun Feb 15, 2015 4:45 pm
any 6 speed boxes that would fit? lol
PostPosted: Sun Feb 15, 2015 7:45 pm
Make love, not moderators
It might be time to start using the larger frame boxes.. Someone needs to make a jig to drill to box for the mounting and produce a kit to adapt the intermediate shaft...
PostPosted: Mon Feb 16, 2015 2:20 am
DMWdave in Australia already makes the parts for the large frame box conversion, still a very expensive option, best thing you can do is repair your box the first sign that it 'snicks' changing into 2nd gear, then you only need 1st and 2nd syncro rings and some seals, the longer you drive on it the more parts you'll need to replace.
PostPosted: Mon Feb 16, 2015 5:14 pm
the problem is.. gearbox fall apart before end of first event after rebuild :D
PostPosted: Fri Mar 06, 2015 7:05 pm
Does the the short flange on one side of the high speed hub on the input shaft face toward 4th gear and the longer flange on the other side face toward 3rd gear or do I have it backwards?
PostPosted: Fri Mar 06, 2015 8:02 pm
i don't have anything apart to check, but put 3rd gear on and then "selector hub" if turned right it will go all the way on 3rd gear.. if turned wrong it won't go competly on 3rd gear..
http://i282.photobucket.com/albums/kk27 ... rans12.jpg
if you look this pic (copied from first post) you can see difference on hub engagment teeth for 3rd and 4th gear.. also, as on pic, some gearboxes (but not all) have 3rd gear side more rounded on hub than 4th gear side..
PostPosted: Wed Mar 11, 2015 10:24 pm
Thanks. The small print on the fsm does say left, but I had to think which left. Of course it is the standard direction orientation while in the vehicle. The first time through is always nerve wracking when you really don't know where everything should sit.
PostPosted: Mon Feb 27, 2017 5:53 pm
A little further discussion on getting the shim correct that preloads the bearings on the output shaft:
After the PBR can fix shown above, my next "solution" to this problem was a thin piece of steel cut with shears from an aerosol can. That worked better, or at least, other than possibly some under-torqued screws holding the plate, I found no damage or issues that could have been in any way related to the shim now that I've got the box torn down again :roll:
That being said, I am determined to "do it right" this time:
For reference, here are the Suzuki part #'s for the shims:
09170-33421-040 SHIM (T: 0.4)
09170-33421-045 SHIM (T: 0.45)
09170-33421-050 SHIM (T: 0.5)
09181-33001 SHIM (T: 0.55)
09181-33002 SHIM (T: 0.6)
09181-33003 SHIM (T: 0.65)
09181-33004 SHIM (T: 0.7)
09181-33005 SHIM (T: 0.75)
09181-33006 SHIM (T: 0.8)
09181-33007 SHIM (T: 0.85)
09181-33008 SHIM (T: 0.9)
09181-33009 SHIM (T: 0.95)
09160-33003 SHIM (T: 1)
09160-33004 SHIM (T: 1.05)
09160-33005 SHIM (T: 1.1)
09160-33006 SHIM (T: 1.15)
I am pleased to report that I was actually able to purchase a complete set of the middle part numbers, 09181-33001 through 09181-33009 at http://www.boats.net (because, you know, that's where you would think to get obsolete Suzuki parts right?) for $18.17 plus shipping :D
