It is currently Thu Oct 19, 2017 2:16 pm
PostPosted: Thu Feb 12, 2015 3:10 am
A few years ago a 79mm bore g13b block sold in Canada
DMWDave mentioned 3mm steel liner and 7mm alloy outer
casing the liner from factory.
Therefore 74/75mm g13/g16 respectively can be taken to
79/80 respectively by the sounds of it.
Has anyone hear other than 79mm for sleeve and grouting?
PostPosted: Thu Feb 12, 2015 5:35 pm
Hi,I'm building a g13b block with 78.5mm with steel liners having a problem keeping the compression in but hopefully will have the problem sorted now installed wills rings in the top of the liners.
PostPosted: Fri Feb 13, 2015 3:40 am
Compression is an issue atm !!! did you just bore stock sleeves or put new ones?
O-ring is recommended but must be tight for space yet bike engines are doing well with
what appears are just MLS style gaskets and ARP style caps
PostPosted: Sun Feb 15, 2015 8:31 am
Had to remove old liners completely and installed custom steel liners it is tight between them but should be ok. I'm tuning c/r 13.5:1 so hopefully it works out,I have the arp head studs installed now so read to put the head on just waiting on a deep 12 sided socket to fit down into the head to reach the new nuts that came withe the studs.
PostPosted: Sat Feb 21, 2015 8:31 am
Any chance of a pic of your efforts?
Can you advice on the liners you used? The ones that failed and the new steelies....etc
I was just thinking of using cast iron liners from a Vauxhall Ecotec (X20XEV) for 79mm
along with custom made pistons
PostPosted: Sun Feb 22, 2015 8:40 pm
Westwood cylinder liners in England made the liners to my size they will do any size you want.they are good to deal with.i cannot get the photos to upload but will try something must take a photo with less pixels or something.i got head studs fitted in the block now so ready to put the head back on now.ill keep you updated.
PostPosted: Mon Feb 23, 2015 3:12 am
try http://www.justcloud.com/
or
http://www.free-pictures-photos.com/clouds/
or
photobucket.com then link here you wont need to resize them
very easy to use
Good to hear you can get liners made out of steel
what did they set you back?
PostPosted: Mon Feb 23, 2015 6:37 pm
The liners were about 400 euro.
PostPosted: Mon Feb 23, 2015 6:42 pm
Here's a dtc view
PostPosted: Tue Mar 03, 2015 12:35 am
Thats a really sweet setup Shane, thank you for the info!
keep us posted its art :)
PostPosted: Fri Mar 06, 2015 8:10 am
:drools:
ImageET 13.138 at 120.2mph
