It is currently Fri Oct 20, 2017 3:32 am
PostPosted: Sun Mar 01, 2015 4:04 pm
OK, so heres the deal. I am putting a 13B GTI DOHC engine in a '25 T roadster. I am going really old school and using twin SU carbs. I need a distributor with vacuum advance. Everything I have read says use a distributor from an '89-'91 Swift. Found these reman Cardone 31-523 on ebay. Before I hit "Buy it now", just want to be sure. Can anyone absolutely verify this is the right one. Don't mind spending the $$$ for the right one, just don't want to spend the $$$ for the wrong one ! HELP :)
Cheers,
Stewart.
PostPosted: Fri Mar 13, 2015 7:52 pm
I read that you are putting a g13b in a T roadster. That sounds real cool and real original one of a kind. Keep us posted. By the way i have heard of guy's using sammy dizzy on cb g13b.s.
PostPosted: Sun Mar 15, 2015 3:35 pm
That one will work with carb or TB. It is a basic vac carb that is not computer controled. And it is for the 4 cyl.
PostPosted: Sun Mar 15, 2015 9:39 pm
How does one know the timing curve of such a dizzy?
2003-EVO7 GT-A
PostPosted: Sun Mar 15, 2015 11:54 pm
Set up a timmng light and take readings every few hundred rpm. Its no different that a gm hei dist that you can swap out springs and weights to get a different curve. They are just under everything so not as easy.
PostPosted: Sun Mar 29, 2015 7:31 pm
Thanks guys, got one on its way.
Not sure if my project will be of much interest to you guys, plus I wouldn't know which section to post it under!
It will be very light, aiming for about 1100lbs, very low, and nimble. It will be a spaceframe of 1" round and square 16 ga, with the sheet metal just hung on the outside. Originally was going to use a 3 cylinder engine, even got a ported head and cam package from 3Tech, but gave in to a big block!! I've got a Samurai 5 speed that fits behind it, so the whole engine/trans combo will weigh less than 200lbs.
Just started scabbing the sheet metal together at the moment, and then I can plan the spaceframe to fit the body.
If there is any interest, I could do a build thread, if someone could tell me where to put it :wink:
Thanks again for the help. I have zero knowledge of these engines, so came here for help.
Cheers,
Stewart.
PS, why 2 vacuum ports, and do I need both?
PostPosted: Fri May 22, 2015 4:43 pm
I think it is G16 dizzy.
It will work if it is 4 cylinders but you have to change shaft to 3 pots in order to work.
Atchi
PostPosted: Thu Mar 03, 2016 11:29 am
Any update on this?
2003-EVO7 GT-A
