It is currently Sat Oct 21, 2017 2:19 am
PostPosted: Tue Jan 27, 2015 7:22 am
I use my Geo to run around the country to aquire transmission cores, distributor cores and engine core for rebuilding.
With my Geo suspension lowered one inch and wide 15" tires, I was rubbing on bumps the rear tires. This was with 5
transmission cores and a 1.3L short block in the back of the Geo.
I have now installed the AirLift kit that there tech support suggested I use.
http://www.ebay.com/itm/381091164140?_t ... EBIDX%3AIT
It took more time to run the air lines then install the air bags into the springs.
I am happy with what this kit did for me. 5 psi to keep the bags inflated inside the rear springs. 35 psi and the rear of the car
rides up 2 inches higher.
2907 airLift kit installed. I ran the fill nozzle up into the gas cap area.
Fainya
PostPosted: Thu May 28, 2015 10:02 pm
Is there a way to do this on the front also. I want to cut my coils so I can "sit low" but I want to hook it up to a small compressor to blow them up and drive around "comfortably"
Projects.
1993 Geo Metro LSi
1994 Toyota Pickup
