It is currently Thu Jan 18, 2018 11:20 am
 Post subject: 97 Geo Metro Swap
PostPosted: Mon May 25, 2015 8:32 am
I have a 97 Geo Metro Lsi that the motor blew up on me. I have a 2000 chevy metro lsi engine that i got for a good price. Can someone tell me exactly what I will need and need to do to make the 2000 engine work in my 97?
 Post subject: Re: 97 Geo Metro Swap
PostPosted: Tue May 26, 2015 3:22 pm
Are they both 1l or 1.3?
You can swap like for like if they're both 1.0
If it's a 1.3
You will need the engine harness and ecu as well as the fuel pump out of the 2001
08 Civic Wife's car
PostPosted: Sun Jun 07, 2015 5:37 am
97 is throttle body fuel injected. And distributor.
98 and up used port injection. Because of this you will need engine harness and PCM
off of a 98 and up car. no distributor on these so you will need the coil packs too.
Fainya
