It is currently Sat Oct 21, 2017 9:26 am
PostPosted: Fri Oct 23, 2015 11:04 am
I have a 1994 G10 motor in a 1971 Honda N600 Sedan. Because of a lack of space I relocated the IAC solenoid on the fire wall. I can now hear the solenoid "tick" open and close. What is odd to me is it opens and closes continuously even above a few thousand RPMs. Is this correct? I would think it would be always closed if the engine is above idle. At idle it functions correctly, bring the idle up when there is a load on the engine like the fan coming on.
Nothing in the FSM addresses this.
Thanks for any help. Maybe someone can give a listen to their motor to see if this is typical.
1971 Honda N600 Transplant
w/ Suzuki G10 engine
and 5 speed trans
PostPosted: Fri Oct 23, 2015 4:14 pm
check the coolant temp sensor (clt) for proper calibration. the ecu looks at coolant temp and if it is below between 160 and 180 degrees the ecu remains in open loop and the iac operates as if the engine is cold.
there is a different idle up circuit for electrical load comprised of a network of diodes.
PostPosted: Sat Oct 24, 2015 9:04 am
The circuit works perfectly at idle. I only have the fan connected to the diode circuit and all is good. When the fan comes on at idle the ECU will compensate and bring the idle up to 850 to 1000 rpm. My question is what happens when the rpm's are above a few thousand. It is here that I can still hear the IAC solenoid contiguously open and closing. I would think it would be just stay closed once the engine was above idle.
and 5 speed trans
PostPosted: Sat Oct 24, 2015 4:22 pm
if the clt is out of spec the ecu thinks the coolant temp is low and stays in open loop operation. in open loop operation the ecu maintains fuel enrichment and fast idle control.
which is why i suggested running the clt work shop check from the factory service manual.
PostPosted: Sun Oct 25, 2015 11:21 am
I get it. Since I have no dtc'c being kicked I will check that the ECT leads are between 190 and 400 ohms with the engine warmed up.
and 5 speed trans
PostPosted: Sat Oct 31, 2015 9:11 am
Yesterday I checked out the engine temperature sensor and it appears to be functioning correctly. At 82 degrees ambient it reads 2.121 K ohms and at warmed up 128+ degrees (measured with IR thermometer on the (TB) ECT sensor end) is .438 K ohms.
At idle the circuit still functions corrrectly. I idles up with the fan "on" load. The problem is at above 1500 rpm the solenoid clicks contentiously speeding up and down with the rpm. Which does not effect the engine performance but I would think the solenoid would burn out doing this.
This can't be right. Any thoughts?
and 5 speed trans
PostPosted: Sat Oct 31, 2015 10:52 am
List the sensors you've hooked up.
PostPosted: Sat Oct 31, 2015 12:48 pm
The only item not connected is the EGR solenoid. All else is 94 Metro including the gauge cluster for the VSS. The harness is from the same car. The ECU is not kicking any codes and with a jumper I get 12.
O2, Vss, Map, IAT, TBS, CMP I think that's it.
The only issue is go above idle the IAC Solenoid clicks as described above.
It should be noted that the car runs great.
and 5 speed trans
PostPosted: Sat Oct 31, 2015 1:10 pm
What's the low speed and high speed NOx?
PostPosted: Sat Oct 31, 2015 6:39 pm
Not sure what your asking. This car does not get smogged so I don't know what the nox reading are. I can replace the EGR system in a few minutes but what effect would that have on the IAC solenoids operation?
and 5 speed trans
PostPosted: Sun Nov 01, 2015 3:54 pm
I weighed in on this thread for two reasons.
One, we had a Honda 600.
Two, we have an OBD-I vehicle similar to the '94 Metro he used as a power plant.
This is addressed in the FSM on page 6 of the fuel metering section...or are you trying to see if we remember?
:shock:
When you ask for help with a highly modified car/powerplant transplant make sure you include all salient issues.
In this case, you failed to note if the vehicle was standard or enhanced emissions.
Better, you could have included pictures showing your modified set up.
Asking people to go listen to their car, seriously?
Better you post a video of yours.
After all, you're the one asking for help.
The members here are pretty sharp.
So the more information you include with a question or problem, the better your answers will be.
You will find that your thinking is NOT correct, but it is logical.
The FSM page quoted will explain.
Much better it than me.
You will not listen to me.
I'm liking this guy.
He listens to the advice on the forum.
Let's see what happens.
Oops. 'Contentiously'? Is that 'personification'? Are we giving this car personality? Or are you interpreting it as 'contentious'?
We didn't read the book. Or we checked out all the diagrams and thought how neat it was...
This CAN be right.
Where is the logic in your idea that the rapid pulsing from the ECM would burn out the solenoid?
Hint: The solenoid would last longer. Can you figure out why?
Just because your car isn't REQUIRED to be smogged, doesn't mean you can't have it sniffed.
Actually, it would help you KNOW if it is running great or not.
Tailpipe emissions will tell the readership exactly how great it is actually running.
You saying that it runs great is meaningless.
That's why they created exhaust sniffers.
Duh.
With all the money you spent on the car, why wouldn't you shell out a few bucks to find out what she blows?
That's the final test of good mechanic - see what she blows.
Do you even know how much it would cost?
You disabled the EGR, seriously?
I realize that the EGR has a bad reputation with the over 60 V-8 crowd, but if you go back and read the 4 pages of Section C-7 you will understand that there is NO downside to hooking it up.
Indeed, if you hook it up your car will burn cooler and last longer because of lower combustion chamber temperatures.
There are many many posts of burned exhaust valves from people who did exactly the same thing as you.
Learn from their mistakes and take care not to repeat them with your carefully crafted and treasured Honda 600.
I'd like to see you use this as a reliable and fun car.
It would be nice to trick it out.
As you know, there is a huge aftermarket support group here at Teamswift and GMF.
Indeed, you have many more posts over there.
I'm surprised no one has answered your question over there.
You might even read the answer and post it at the conclusion of this thread so that the others will know why you hear that 'buzzing' sound.
Look through some of 87 Octane's posts.
He has really shown how sharp he is.
At first he was against all things smog.
Now, he knows what the heck he's doing and why.
I am no different than you.
Years ago I hated all things smog.
Eventually, I learned about emissions equipment and why it is useful.
Now, I'm not scared of smog a bit.
I know what should be done and why.
When I run a car in for smog, it is to test how well I did my job.
Rarely will one of my cars fail.
Your transplant with OBD-I parts was more difficult than with OBD-II, as you'd have more sensors and better emissions monitoring.
Now that you're a part of the State of California, try to embrace the technology which puts clean burning power plants on the road safely.
Let go of the "I hate smog" past.
Your engine will thank you for it and look more like this inside:
even though it is pretty dirty on the outside:
I'm no expert, but I've been licensed by the State of California to smog cars for over 30 years...
On this site: http://geometroforum.com/index/
they call me member #15...and on this site,
I'm absolutely nobody!
:lol:
There's a meet in December about 40 miles due West (210/134/101) which might put you in with an appreciative crowd:
viewtopic.php?f=23&t=54827
These links may save you some time:
https://docs.google.com/file/d/0ByZnrvy ... prN2s/edit
https://docs.google.com/file/d/0ByZnrvy ... RpYU0/edit
(Concentrate on page 6 here):
https://docs.google.com/file/d/0ByZnrvy ... czSG8/edit
Class dismissed.
PostPosted: Wed Nov 04, 2015 12:45 pm
Pacapo
A little harsh don't you think...
You might be preaching to the choir. I was recently discussing, with the mechanic I work with, putting a cat and all the smog devices to see it would pass. Only problem is I don't think a smog tester can run it with out the state connection and the law says that it does not get smogged.
As for 6E2-C2-5 that is the section of the FSM that made me start this thread. It says that at idle it cycles 12 times a second and at higher rpm it is "on". Is "on" still cycling or is the solenoid just held open?
and 5 speed trans
PostPosted: Wed Nov 04, 2015 4:23 pm
I've done a lot of these cars and I sure think that solenoid does click above idle on them for whatever reason, normally it's mounted on the intake on rubber insulators so it's not noticed. I'd sure lean towards mounting it in stock location on the intake and calling it good if the noise is the only thing bothering you. If I had one here I'd run it up and see what it does, I'm curious and just can't remember for sure either way
PostPosted: Wed Nov 04, 2015 6:21 pm
codyb76
That's what I wanted to hear. Thanks for the help.
I am using that OEM bracket and I still have the factory vac lines, so it is an easy move. If I had some sound deadened material on the FW I doubt if I could hear it.
and 5 speed trans
Users browsing this forum: Bing [Bot] and 3 guests
