It is currently Tue Jan 16, 2018 10:34 am
PostPosted: Fri Feb 05, 2016 12:07 am
The parcel shelf sits and pivots on two pins that I believe are supposed to have a rubber sleeve covering them .
Any idea where to get these ,or can someone post a pic of one , so I can fab something suitable ?
Thanks!
Al
PostPosted: Fri Feb 05, 2016 1:19 pm
EDIT: Posted pictures below..
1989-1994: Pivot shaft snaps into spring clip mounted in side brackets. No rubber.
1995-2001: Pivot shaft snaps into cavities moulded into side brackets. No clips or rubber.
PostPosted: Fri Feb 05, 2016 8:53 pm
Thanks so much for the quick reply!
Now....just gotta find some clips.....
Cheers!
Al
PostPosted: Sat Feb 06, 2016 1:16 pm
Are you looking for the male or female parts? The male parts are available from the dealer.
PostPosted: Sat Feb 06, 2016 2:45 pm
Looking for the retaining clips that would be the female portion................
Thanks for commenting !
I'll be making a small list of other bits I need shortly, since I just picked up a nice '91
Al
PostPosted: Sat Feb 06, 2016 2:46 pm
Making a list of bushings.....Whiteline......from Oz ??
PostPosted: Sun Feb 07, 2016 4:52 am
When mine were stuffed it was the male bits that broke and they just slid new ones in. The problem is that they used some horror epoxy self help fix I had to remove first.
I'll try to ring the dealer tomorrow and see if the female bits are available...
PostPosted: Mon Feb 08, 2016 8:23 pm
I believe the clips I need are Pt# 87435-82000
Again, thanks for inquiring!
Al
PostPosted: Sun Feb 14, 2016 5:03 am
For bushings check out superflex.co.uk
Great range for our cars.
INCREASE THE PEACE
PostPosted: Tue Mar 01, 2016 4:14 am
I also need to find this parts. Thanks for information ! :) :) :)
โป๊กเกอร์คาสิโนบาคาร่า
PostPosted: Wed Mar 02, 2016 3:52 am
Both the male and female parts are available here ex Japan.... Your part no for the female part was correct.
Looks like less than $US 10.00 each including me shipping them to the US. They'll be here in about two weeks
