It is currently Fri Oct 20, 2017 9:53 am
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Mar 03, 2010 9:14 pm
This is what my wife drove in the street studded tire class of the Ontario ice racing championship.I drove a '91 civic si to the class and overall champion,I believe the geo can be even better so it'll get some lovin' in the off season.
PostPosted: Wed Mar 03, 2010 9:24 pm
I like it.
PostPosted: Wed Mar 03, 2010 11:01 pm
cool i like the rims they look like something off of an rc car
1994 suzuki sidekick 4 door
PostPosted: Sat Mar 06, 2010 7:29 pm
Thanks,the wheels are factory snowflakes from an AE86 corolla.
PostPosted: Sun Mar 07, 2010 11:31 pm
THis is my 1998 3/5 .It's a WIP but still a daily driver.
PostPosted: Mon Mar 08, 2010 1:33 am
That's not a Metro, that's a Firefly. :lol:
PostPosted: Sat Mar 13, 2010 12:04 am
You're correct but the names have been changed to protect the innocent. :mrgreen:
PostPosted: Sat Mar 13, 2010 2:09 am
I've been single handedly instrumental in getting Swifts to cost more than a similar year Metro to insure in this province. :lol:
$770 to insure a 98 Metro
$792 to insure a 98 Swift. 8)
PostPosted: Thu Mar 18, 2010 1:12 pm
I took some shots of the mk5 today, so you can see that hatch with the rims.
PostPosted: Sun Apr 18, 2010 8:23 pm
Lowered on H&R Sport Springs
Raised on '86 Maxima wheels with 195/55/15 Dunlops.
I know the tires are a bit big, but I got them real cheap. I also know the wheels are a bit of a squeeze, but again, got them cheap - about $180 overall for the wheels and tires, mounting and balancing. I'll go a bit smaller on the tires after these wear out. The fronts rub a bit on the front of the fender liner at high steering angles, and the rears rub a bit worse on the top of the inner fender when the suspension is compressed. Spacers are out of the question unless I get longer wheel studs, as the fat wheels only leave enough to get about 6 turns on the lug nut, as opposed to 10-11 turns on the stock steel wheels. For the cheap money, I'm happy for now.
1995 Suzuki Swift
SOHC 8V G13B, rebuilt with .020" oversize pistons, decked block ~ 9.8:1 comp, mild head porting, same old worn out camshaft, 2" cat-back w/cherry babomb, factory CAI modd3d with spray paint cap, urethane motor mount, TT front chassis brace, gutted rear interior, Razo RA25 shifty knobbzor, extra seat belts, H&R springs, '86 Maxima wheels with 195/55/15 Dunlop SP Sports.
PostPosted: Thu Aug 05, 2010 3:07 pm
Here is my 97 Geo Metro
PostPosted: Sun Oct 03, 2010 5:02 am
The wheels rub a little but I will get lower profile tires soon. It has limo tint and I painted the back hatch black to give it the wrap-around look.
:P
If we did the things we are capable of, we would astound ourselves. ~Thomas Edison
2000 Chevy Metro 1.3L
PostPosted: Tue Dec 14, 2010 11:54 pm
my astro, metro, and my vino , (metro and vino were sold last year)
where can i get a nicer tach (that the needle will LIGHT UP), mine is SHITTY, the needle is so dim and the thing is not easy to read. pretty useless.
but this is how i choose a tach : any help?
the top rpm of the tach must not be more than 6000 rpm because this car wont go up to 5000 rpm, if you have a 10000 rpm tach, the needle will always stay at the bottom of the gauge all the time , its pointless,,
second is,, the tach must be small enough to fit there, ( i dont want monster tach stick on the dash its too ricey),
anyone can tell me which tach is good for my need ?
PostPosted: Sat Jan 08, 2011 11:53 pm
From the pic at the top of this page from last season to this season;
PostPosted: Sun Jan 09, 2011 10:30 am
Yeehaw.
Looks awesome!
PostPosted: Sun Jan 09, 2011 12:31 pm
The angle the head on pic was taken makes the top of the flairs look canted in,I assure you they are level. :)
Also the camber is set up for counterclockwise track direction(the direction we usually run on saturdays)hence the - camber and tucked wheel on the passenger side versus the 0 camber and flush drivers side.
PostPosted: Sat Feb 26, 2011 6:32 pm
this' my DD beat up car :-) been very useful this winter, hopefully i can fix her and drive her again before summer :-)
PostPosted: Sat May 26, 2012 2:51 pm
ilove my metro
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue Dec 18, 2012 8:04 pm
You ever go to sell anything off this car I'll take the front fenders off you!
PostPosted: Sat Dec 29, 2012 7:18 pm
They are actually pretty easy to make,a thin cut wheel in a grinder,some masking tape,body metal cut into a cresent shape to match the existing fender curve and the new pulled fender curve,welder to make them as one and some bondo,sanding and paint your done. :)
Don't plan on doing the rear unless you mean it,they are a bitch with the compound curves,inner fender extension required and the fuel filler that will need to be a part of it for a street car(my fuel tank is where the rad used to be).
PostPosted: Sun Aug 24, 2014 5:16 am
1995 Swift, the way it looked the day I brought it home. Been too hot to do much work on it, but I did change the brake pads today.
1993 Swift GT aka "The Golf Ball" (RIP)
1995 Swift aka "Jelly Bean"
PostPosted: Sun Aug 24, 2014 5:38 pm
Waiting for the bumpers to be painted, then I'll tint the windows, install the stereo, and should be done for the year
PostPosted: Wed Feb 18, 2015 2:51 pm
Here's a few of 1999 swift race car!
PostPosted: Tue Sep 22, 2015 1:32 pm
Hey Everyone!
New to the Forum and just wanted to show off my 2000 Suzuki Swift I bought 3 weeks ago. So far so good and its been a pretty fun ride. :D
PostPosted: Tue Mar 01, 2016 4:15 am
these are so cool! awesome guys!!! :) :) :)
คาสิโนบาคาร่าออนไลน์คาสิโน
