It is currently Wed Oct 18, 2017 1:48 am
 Post subject: Header advice
PostPosted: Tue Mar 01, 2016 6:45 pm
I have a 1991 metro conv with the 1.0 and just acquired a new header last weekend.
Wondering if any benefit to installing on vehicle
I know the egr port would be blocked and also could not use the factory converter
would this be a problem ?
Thanks Jeff
 Post subject: Re: Header advice
PostPosted: Wed Mar 02, 2016 5:05 pm
If you have EGR, blocking the exhaust port may throw a code. My 91 hatch does not have EGR. Blocking the exhaust port, with my header, is a non issue.
Header benefits, on a G10, is debatable. The stock exhaust manifold is pretty much a header design to begin with. Nice aftermarket converters are available from Summit, Jeggs, etc.
PostPosted: Wed Mar 02, 2016 8:56 pm
You can't really take advantage of items such as headers if you can't change the mapping in the ECM. It is also very unlikely that your aftermarket header is a better design than the OEM one.
Now I take all that back if you have a carburetor because in that case you are the ECM and you can to crazy things to make the engine match your exhaust system.
1971 Honda N600 Transplant
w/ Suzuki G10 engine
and 5 speed trans
