It is currently Sat Jan 20, 2018 1:12 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Aug 30, 2012 6:18 pm
That engine bay pic is just sex!!! :yeahyeah
I see now you did something to the car flares. Also to the rear wing. Care to share a few close up pics? :D
I have Suzuki's fiberglass fender flares installed on my '89 project. I also have a modified OEM wing on it which looks very similar.
Awesome car you have there.
2003-EVO7 GT-A
PostPosted: Tue Jan 22, 2013 12:11 am
This is a really inspiring project, you have going on here :wink:
I noticed you mentioned a 95% volumetric efficiency on your first post.... what equation did you use to come up with that number?
I ask because I've been doing some calculations on intake and exhaust flow and according to my equations, your engine should be way beyond 100% VE in order to generate those numbers.
By example the B16 generating 160 hp = 97% VE and a stock G13B 100 hp = 86% VE
image_id: 22616
1993 Swift Gti
PostPosted: Thu Jan 24, 2013 9:03 pm
dang, this car gets all 5 stars, really impressive. inspiration for my current project
u ever consider bringing this machine over here to jamaica and give them evo this and sti that guys a good run? i would love to see this in person.
doing a rebuild now (on a budget) looking at the p29 floating pin pistons i see on ebay. high compression & boost later.
PostPosted: Thu May 19, 2016 11:09 pm
Hi Guys,
Does anyone know where I can locate a dry sump oil pan for the G13B motor? I don't have the means to make one.
dry sump motor.jpg [102.8 KIB]
Not downloaded yet
PostPosted: Fri May 20, 2016 10:24 am
There was a fella a few years back that posted pics of a g13 in a super seven, rwd and dry sumped, Im sure it was custom, isnt there any fabrication shops near you?
Have a look, you know you want to!
Swift. http://m.flickr.com/#/photos/11473969@N02/
Evo. http://m.flickr.com/#/photos/100754123@N04/
PostPosted: Sat May 21, 2016 3:14 pm
Here is the post on the guy with a dry sump.http://www.teamswift.net/viewtopic.php?f=4&t=60867&p=446056&hilit=lotus+7#p446056
PostPosted: Sat May 21, 2016 6:08 pm
Hey, thank for the link. I sent him a PM some weeks ago but reply as yet.
Cheers,
MF
PostPosted: Sun May 22, 2016 12:59 pm
Found this link http://www.drysump.com/
PostPosted: Mon May 30, 2016 8:45 am
Subscribed for the dry sump...
I'm in the process of dry sumping mine as well... My biggest hurdle is mounting a drive gear to my pulley
PostPosted: Mon Apr 03, 2017 10:52 am
Hi Guys,
I had to abandon the dry sump project because of the group/class rules :( I am looking for recommendation on a good high volume / high pressure oil pump and a high capacity oil pan w/ baffling.
Thanks in advance.
MF
PS. Please PM me your comments if you don't feel comfortable posting in this thread.
PostPosted: Tue Apr 04, 2017 9:11 pm
MF89 wrote:
Hi Guys,
Thanks in advance.
MF
I will be using the g16 pump this year and I am also looking for a high capacity/baffled oil pan..... I think I will have to custom modify a factory one.... I do believe Moroso will custom make pans but they need a drawing to build by.... so unlessyou are good with CAD or at making blueprint drawing then we are both in the same boat.
PostPosted: Mon Jun 26, 2017 9:48 pm
