It is currently Thu Oct 19, 2017 10:46 am
 Post subject: Confirming Gearbox
PostPosted: Fri Jun 10, 2016 7:37 pm
I have just purchased 1993 GTI swift it has g13b engine and want to confirm which gearbox is in it ( what gear ratios), how do I do this.
Hope you can help
 Post subject: Re: Confirming Gearbox
PostPosted: Fri Jun 10, 2016 8:44 pm
Start by posting in the correct section.
PostPosted: Fri Jun 10, 2016 9:08 pm
My apologies I am new member , where should I have posted it
PostPosted: Sat Jun 11, 2016 5:40 am
viewforum.php?f=9
PostPosted: Sat Jun 11, 2016 6:55 pm
Being an Oz car it would have been sold with the close ratio gearset, but may have been replaced by a Cino gearset at some point. Search posts by Dattman. There is a special extra casting on a GTi box and if yours has this chances are its has never been replaced.
PostPosted: Sun Jun 12, 2016 9:30 am
Ok thanks everyone for your help i am sure the box has been replaced with a 1.3 sohc box.
will a 1 liter box fit the 1.3 dohc engine as the ratios are close enough for what i want
PostPosted: Tue Jun 14, 2016 3:02 am
It will fit, but the differential, and final gear are different. The already weak differential in the 1.0 is smaller and less likely to handle abuse, but will work.
