It is currently Fri Oct 20, 2017 12:42 am
PostPosted: Tue Jul 19, 2016 10:02 pm
Any one had over torqued their cylinder head? I just machined the head and installed a new gasket, i was using an extension to get to the bolts so i set the torque wrench to 62 instead of the manual 54 to compensate for the extension. Any one had any experience if this would be a problem?
PostPosted: Tue Jul 19, 2016 10:17 pm
I forgot to mention it is a 94 3 cyl engine
PostPosted: Thu Jul 21, 2016 9:54 am
I would bet that it will not be a problem. That's not a huge amount of over torque. All torque wrenches will have some variance and I'm sure manufacturers build a small mount of error factor into the specs. I'd say 44-64 would probably do the job and not cause problems, but of course as close to exact spec as possible is always best!
PostPosted: Wed Jul 27, 2016 7:17 pm
Thanks man! At least it gas been working fine, i noticed that the cooling of the engine has bern a bit better so i asume that maybe my previous gasket was a bit under torqued and it was letting some compression get into the coolant passages, not much but mayyybe a slight amount. So i guess thst maybe my torque wrench needs to be either calibrated or replaced.
PostPosted: Tue Nov 29, 2016 10:24 pm
of course as close to exact spec as possible is always best! :(
จีคลับเข้าไม่ได้
