It is currently Sat Feb 17, 2018 7:32 pm
PostPosted: Thu Jun 16, 2016 6:33 pm
i know i can go with the 13 inch tires, but how about the geo metro brakes?
the sprint has press fit disc, can you swap out the entire wheel/spindle assembly?
will the geo metro 13 inch spindle mount up to the existing sprint suspention?
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
PostPosted: Thu Jul 21, 2016 9:46 pm
edit
PostPosted: Fri Jul 22, 2016 7:18 am
get the entire knuckle/ bearing/rotor/caliper/caliper mount from a vert, or a newer 95+ Suzuki.
it will bolt right on. check your ball joints while in there, if in doubt change the lower control arms
as well.
much better braking, more rotor/pad options, easier to maintain. :wink:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
