It is currently Sun Feb 18, 2018 7:18 pm
PostPosted: Thu Jul 22, 2004 2:00 pm
I have the full service manual for all Mk1 SA413 GL/GC/GS & Gti swifts.
The manual covers procedures for diagnosis, maintenance adjustments, replacement of componants and disassembly and assembly of all major parts including the following:
Heating & Air Conditioning
Body & Sheet Metal
Steering, Suspensioin, Wheels & Tyres
Drive Axle
Brakes
Engine
Transaxle & Clutch
Electrical Systems
The manual is quite large comprising about 1,000 pages but if there is anyone who requires any specific information on a problem they have then I can scan the relevant pages in and e-mail them direct.
Note that this manual only covers Mk1 Swifts and not Mk2 or 3.
Dara
Mk1 Gti Rally Photos @
http://homepage.eircom.net/~kellsstainless
PostPosted: Thu Jul 22, 2004 4:37 pm
I got code 12!!! woohoo!!!
could you scan and email me the page on how to set the ecu in diagnostic mode?
If there is?
hmm, it's a bit wierd, but I got code 22 and then code 12 and so on.
Could it be the tps is a bitt off, need to adjust it?
Send me the pages for the tps and how to adjust it also maybe?
I HATE LIVING IN NORWAY!!
no parts, and stiff prices for my "zuki" (mk1)
One example: TPS - 550 USD!! :shock:
PostPosted: Fri Jul 23, 2004 2:56 am
Razor
PM me with your e-mail address as I have the info scanned in.
Also let me know if you need parts as I have a good few Mk1 bits including spare TPS, AFM's etc...
Dara
PostPosted: Fri Mar 09, 2012 9:28 am
hello people sorry for my bad english but iam still lerning, ive read that Mad_for_Tar1 has the service manual of my loved car. sir would you send me a copy of the pages where is says about the break system and its spects, i dont know if i can still use the break drums of my car or if i need to replace them. thanks in advance my email is salvaramirez@live.com
PostPosted: Fri Mar 09, 2012 10:54 am
Here you go, Salvador
Drums:
Linings:
Do not polish the lining with sandpaper.
Hard particles of sandpaper can be trapped by the lining and damage drum.
When it is necessary to correct lining, replace.
PostPosted: Fri Aug 12, 2016 10:27 pm
hi iam chasing mk1 dohc wiring diagram cheers john
PostPosted: Mon Aug 15, 2016 2:30 pm
PM me your e-mail address and I can send it to you.
Regards
Dara
