It is currently Tue Oct 17, 2017 12:08 pm
PostPosted: Mon Sep 12, 2016 8:10 am
i see the king racing and acl race bearing, but i don't know who is better.
PostPosted: Mon Sep 12, 2016 11:08 am
Acl race main 5M8337H and rod 4B8336H.
but i need 0,25mm
PostPosted: Mon Sep 12, 2016 6:10 pm
As long as you stay with the racing series they are both very good! My opinion Acl is slightly better.
PostPosted: Tue Sep 13, 2016 11:06 am
and SEALED POWER Bearing? it's good to?
PostPosted: Wed Sep 14, 2016 9:18 pm
They are decent but not near as good as the Acl or King race series bearings. If car is just a street car then the sealed power will be fine but if it's being raced or some track days then I would stick with a race bearing.
PostPosted: Tue Oct 04, 2016 8:55 am
ok, tank's.
my cranckshaft need to go for 0,25 mm. this is bad?
PostPosted: Thu Feb 02, 2017 12:22 am
ACL, King or Mahle...nothing else.
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Thu Mar 02, 2017 9:30 pm
I used stock sized king bearings on my 89 g13b rebuild have had no problems,
PostPosted: Sun Mar 05, 2017 10:48 am
I have a set of ACL racing mains and Con rod bearings on the way. I'm using std size since my crank was within tolerances. I'll be plasti-gauging before installation to make sure clearances are right.
93' Suzuki Swift Gt Turbo
